Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 09-22-2013, 09:35 AM   #1
1973 23' Safari
Smithfield , Virginia
Skin damage near steps.
After towing my Safari 2300 miles this summer, I noticed this problem a couple of days before getting home. I’m not sure what’s causing it and more importantly I need to know how to repair it. attached are some photos. Any information how to address this problem is greatly appreciated.
ID:	196194   Click image for larger version
ID:	196196   Click image for larger version
jasmith58 is offline   Reply With Quote
Old 09-22-2013, 10:00 AM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
It looks like corrosion has taken over and caused a weakened area of the aluminum wrap, which then caught on the edge of the stair and tore. I would get in there and sand the step cavity and then POR 15 to prevent further rusting. As for the aluminum, a temporary patch could be a simple as some duct tape. Or you could rivet a patch on to stabilize it. Or you could cut out a larger section, and rivet in a patch. Or you could replace the entire wrap.
arktos55343 is offline   Reply With Quote
Old 09-22-2013, 10:07 AM   #3
Kevin245's Avatar
It looks like bimetallic (galvanic) corrosion. I would power wire brush and paint the steel then apply an aluminum patch.
William C. Swinney
Old 09-22-2013, 01:04 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the license plates in your state are made of aluminum. They make great patch material.
The rust on the outriggers appears to be surface rust. You can clean it up and paint it. But it will only make a cosmetic difference. The backside of the outriggers will still be rusty. Unless you remove the sheet metal to gain access.
