08-14-2010, 08:15 AM
1971 27' Overlander
Antlers
, Oklahoma
Trim above wheel well
Does anyone know where I can get the trim and the transition pieces for the wheel well. My 71 Overlander does not have it on either side. If not, has anyone ever manfactured something to work. Thanks
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
08-14-2010, 08:36 AM
1964 28' Ambassador
Oklahoma City
, Oklahoma
You can buy the j-molding at Vintage Trailer Supply. Look under the tab "even more exterior". The long part of the j-molding fits between the skin and the wheel well (don't try to encompass both skin and wheel well in the groove). If you want to replace the compound curve portion of the molding, you have to heat the material and bend it around a suitable diameter pipe. The use of clecos is a must when doing this part. It's a time-consuming job to do it correctly, but it sure sets off the wheel wells.
Hope that helps, and good luck!
08-14-2010, 09:41 AM
1975 29' Ambassador
Reno
, Nevada
re: "don't try to encompass both skin and wheel well in the groove." -- but this is the way you get the seal around the wheel wells.
The lip of the wheel well and the skin of the trailer both slide into a groove on the extrusion that goes around the wheel well on my trailer. Then a dressing trim attaches to that.
Am I missing something?
09-01-2010, 04:44 PM
1967 24' Tradewind
Greenville
, South Carolina
bryanl,
I've been communicating with Andy on this and he says from 1974 to 2011 has same wheel well mouldings. I need some for my 1967 and Andy says the new type moldings will work with the additional benefit of adding some structural integrity. Any chance you could take a picture of yours so that myself and others can see exactly what they look like. There is an inner and outer.
09-02-2010, 07:55 AM
1975 29' Ambassador
Reno
, Nevada
re: "take a picture" ... will do. give me a couple of days.
09-02-2010, 09:54 AM
Corona
Some owners install the wheel well moldings that Airstream started using with the 1974 models and up to today.
They are in 2 pieces, an inner and outer molding, for each side.
They are available for single, tandem and tri-axle trailers.
Attached are the photo's.
09-02-2010, 11:12 AM
1967 24' Tradewind
Greenville
, South Carolina
Andy,
How malleable is that trim? My wheel wells look to be a different shape than what you have pictured.
09-02-2010, 11:44 AM
Corona
Originally Posted by SilverHoot
Andy,
Those moldings can only go via UPS.
In order to use them, you must cut away some of the side sheet and outer wheel well. That gives the tires more visibility, if you wish.
09-02-2010, 02:32 PM
1971 27' Overlander
Antlers
, Oklahoma
Hum - do not like the - you must cut away - might keep looking
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
09-02-2010, 03:47 PM
1967 24' Tradewind
Greenville
, South Carolina
Mwells4654,
Kinda what I'm thinking also. Hope to see what others have done. I know VTS sells a J-molding but some have had a problem getting it to make the bend for the fenderwells.
09-02-2010, 04:26 PM
1961 16' Bambi
Las Cruces
, New Mexico
ok SilverHoot asked inland rv:
Andy,
and as near as i can tell inland rv responded:
Andy,
i, also would like to how malleable is that trim. i figured that it was a mailable item ....
but can you shape it to fit your needs?
09-02-2010, 05:33 PM
1975 29' Ambassador
Reno
, Nevada
here's a project to look at - wheel well trim
this trailer has a mismatch between the wheel well and the skin that left quite a gap on the forward end of the wheel well. The skin appears to be aligned with the wheel well towards the rear but drops almost an inch lower in the front. The plan is to trim the outer skin to match the wheel well so the gap in the inner trim will capture both as it appears it is intended to do.
The trim is not malleable, or at least I would not try to do much to it without better metal expertise and the right tools. For me, there is too much cross sectional shape that I would fear breaking. The outer trim is more of a maybe and it is the one that really gets beat up, especially where it wraps under with the bananaskin.
Part of my wheel well gap was due to water pump leaking. That corroded the furnace casing and rotted the floor between the battery compartment and the wheel well. There may have been some impact from frame droop (its a 76 overlander with lots of rough road miles and elephant ears). The curbside is worst but the roadside also appears to have a similar problem. The repair effort started with removing tons of goop tossed in to try to fix the leaks - ugh, hate how some folks try to fix things.
If you don't like the idea of trimming the outside skin, you can always do what the shop manual suggests and add to the wheel well.
09-03-2010, 08:48 AM
Ottawa
, ON
Definition of MALLEABLE
1: capable of being extended or shaped by beating with a hammer or by the pressure of rollers
2
a : capable of being altered or controlled by outside forces or influences
b : having a capacity for adaptive change
Mailable: ability to be put into US Post's delivery system
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
11-03-2010, 08:01 PM
2012 25' International
Gloucester
, North Carolina
My '72 Safari was missing one of the transition peices (see photo). I got a replacement from Ryan ( rvrevive@aol.com) at rvrevive.com, photo also included. He might be able to help you.
11-04-2010, 07:01 AM
1971 27' Overlander
Antlers
, Oklahoma
Thanks- I am going to send him you picture if that is ok. That is the piece I need - I have only one of the 4 still attacjed to the trailer. Now if I can find the rest of the wheel well trim - I will be doing great.
I love this site and the prople on it.
Thanks Again.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
11-04-2010, 09:06 AM
Gloucester
, North Carolina
You're welcome, and please feel free to use my photos. Ryan might even have the straight piece of trim you need.
Another salvage resouce is Colaw RV Salvage > Home
Good luck!
11-04-2010, 09:27 AM
1971 27' Overlander
Antlers
, Oklahoma
Thanks - Crookedroad - Sent him and e-mail and also a request to Colaw - I need to just drive to Missouri and see what they have. Only 4 1/2 hour away.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
11-04-2010, 10:35 AM
Gloucester
, North Carolina
Mel- Hopefully between the 2 they will be able to help you.
Let us know how it works out.
John
11-04-2010, 11:29 AM
1971 27' Overlander
Antlers
, Oklahoma
Colaw called and said no - they have nothing.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
11-04-2010, 05:10 PM
Gloucester
, North Carolina
That's too bad. Here's another possibility:
Trailer Buff Inc
732 Rockfish School Ln
Afton, VA 22920
434-361-2500
