Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 02-05-2008, 03:15 PM   #1
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Windows and front body protection
Has anyone used a bra type set up for windows and front body protector?
I talked to a canvas shop that makes them for cars, boats, trucks and RV's and are easy to put on and take off due to the use of SS snaps. She also mentioned that the people that have them like the fact that they can take them off and store them when not towing.
They make the bra to fit the wrap around windows, with extra padding and exposed front for @ $300.00. Would this work insted of rock guards?
John
Argy 78 is offline   Reply With Quote
Old 02-05-2008, 03:30 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
I would be concerned that the canvas-style bra would flap on the skin and abrade or mar either the clearcoat or paint. Aluminum is more flexible and fragile than steel like on a car. Also, I don't think they would be heavy enough to protect the front from dings...just keep it cleaner. Most rockguards/windowguards are either metal, plastic or fiberglass which are more protective than fabric would be.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 02-05-2008, 04:08 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hi John -- You participated in this recent thread and there just aren't that many people who've gone your direction. The plastic rockguards can also be subjected to impact strong enough to crack the plastic -- but it's always held a couple inches away from the glass underneath. Your proposition puts a pad/canvas directly on the glass. Imagine the 60 mph impact of a 3/4" rock or bolt thrown up from the road -- easy to do and you don't even have to go to the gawd-awful Al-Can highway to find such road hazards.
The larger factor should be the absolutely irreplaceable clear glass wing windows. It will cost the greatest part of $1000 installed to replace one -- and the only wing windows available are tinted. Talk about heartache...
5 meter Langford Nahanni
Old 02-05-2008, 05:22 PM   #4
cloth bra's for windows.
Cloth bra's will not protect the glass or aluminum from rocks.
It would also flap in the breeze, ruining the appearance of the sheetmetal.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-05-2008, 11:07 PM   #5
1960 22' Safari
in the wilderness , The great Mojave Desert
If those windows are a $1,000.00 to replace and you have two of them I would opt for the highest level of protection possible.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 02-05-2008, 11:38 PM   #6
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
2005 25' Classic
1988 23' Excella
Daphne , Alabama
Stone protectors
Avion used a soft front rock protector held on with velcro,it did not flap and it did protect the alum.The 1986 and 1987 avion had these covers Also on the Gulf Coast they make hurrican covers for windows made of canvas and are approved for high winds oner 100 mph Both could be effective. My old 87 Avion 34 had the the covers and they worked verry well and the hurrican covers on the house made it through Katrina without a broken window. I would go with the factory steel personally, i just like the looks . You might want to look at diamond plate for the front also.Hope this is helpful
Beaubill is offline   Reply With Quote
Old 02-06-2008, 01:34 PM   #7
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Thanks once again for the priceless information.
John
Wrap around windows - front and rear? SilverToy Windows & Screens 6 07-17-2023 03:44 PM
Argosy Airstream MH front windows the same? Jim Lee Airstream Motorhome Forums 9 02-23-2008 09:26 AM
help on front side windows Zeppelinium Windows & Screens 8 05-23-2006 11:22 AM
Front windows on 2000 Excella FireFighter Windows & Screens 2 05-28-2004 05:20 AM
front wrap-around windows Daryl Windows & Screens 6 11-28-2003 08:29 AM
