05-23-2017, 08:39 PM
1974 29' Ambassador
1976 25' Caravanner
trenton
, Missouri
Lug nut torque
I converted my wheel bolts to studs and nuts some time ago. What is the correct torque for original aluminum wheels on 74 Ambassador? I need a number for my tire man.
07-18-2017, 09:39 AM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
All I can tell you is that on the 2017 models lug nut torque is 110 ft-lbs for aluminum wheels.
07-18-2017, 01:17 PM
I'm In
, Kentucky
From my 2006 owner's manual:
Torque aluminum wheels to 110-120 ft. lbs. and steel wheels to 95 ft. lbs.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
09-08-2018, 06:37 PM
2004 19' Bambi
Houston
Simple wheel torque solution.
The wheel nuts require checking regularly. Pulling 100 -110 ft.lbs with a 18in torque wrench low down on the ground is not easy, especially for a woman. My guy buddy created this hack.
Solution. Get the right size 1/2 in socket, 1/2 drive bar, extension drive, a 4ft length of 3/4 steel pipe (Lowes about $20) - preferably galvanized, and a 25lb weight from a weight set (Academy). Connect up the socket, drive and pipe, to nearly horizontal and gently lower 25 lb weight onto the end of the pipe. If the torque is correct, there will be no movement. If it moves, remove everything and tighten the nut and check again. Do each nut. 4 ft x 25 lbs = 100 ft.lbs. That's within the accuracy of most torque wrenches
09-08-2018, 08:19 PM
Retired.
, At Large
You're making the process harder than it needs to be.
Get a decent torque wrench, put the correct socket on the end, put the wrench on the lug nut, and PUSH DOWN. Do not lift.
09-08-2018, 08:30 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
[QUOTE=NancyJane;2153512]The wheel nuts require checking regularly. Pulling 100 -110 ft.lbs with a 18in torque wrench low down on the ground is not easy, especially for a woman. My guy buddy created this hack.
Solution. Get the right size 1/2 in socket, 1/2 drive bar, extension drive, a 4ft length of 3/4 steel pipe (Lowes about $20) - preferably galvanized, and a 25lb weight from a weight set (Academy). Connect up the socket, drive and pipe, to nearly horizontal and gently lower 25 lb weight onto the end of the pipe. If the torque is correct, there will be no movement. If it moves, remove everything and tighten the nut and check again. Do each nut. 4 ft x 25 lbs = 100 ft.lbs. That's within the accuracy of most torque wrenches[/QUO
NJ,
Easier solution....get a wench made for the job😏
09-08-2018, 09:20 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
[QUOTE=ROBERT CROSS;2153540]
NJ,
That there wrench in the box will not measure torque and your wrists are not calibrated.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
09-11-2018, 03:59 PM
2004 19' Bambi
Houston
I tried a torque wrench and was unable to reach the 100/110 ft. pounds torque. Thus the hack.
09-11-2018, 04:39 PM
2007 30' Classic S/O
Somewhere
, South Carolina
NancyJane,
25 lbs at 4’ horizontally from lug nut is 100 lb/ft.
If you can handle the 25 lb weight comfortably I say you are hitting the spec.
But I also agree that’s a lot of effort that a torque wrench with a longer handle is capable of handling. Forgive me, a ladies version torque wrench.
Maybe a solution is a small tray of muffins or sweet rolls at a camp will locate a volunteer torquer. You hand out the torque wrench (yours) ask for help and reward with pastries.
At any camp I’ve been at if asked to check lug nuts I’ll help. I carry tools.
Tip o’ the wrench to you.
Gary
09-11-2018, 05:25 PM
2004 19' Bambi
Houston
lug nut torque hack
Here is the picture.
09-11-2018, 05:29 PM
2004 19' Bambi
Houston
I understand that there is most always a nice man to assist a gray headed lady, but I am determined to understand my trailer and to be self sufficient.
09-11-2018, 05:59 PM
Somewhere
, South Carolina
Nancy,
Kudos, tip o' the hat, nice attitude and a chair for you at our campfire anytime.
Gary
09-11-2018, 06:08 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
[QUOTE=bwoodtx;2153551]
Yes but in 75yrs no wheel has departed any vehicle I've used it on 👍...plus if you tighten it as tight as you can, (up on one side, down on the other), you will most likely be able to get it off. 😂
Think of it as an organic impact wench.
Ck regularly...how often? What about the TV?
I've never even had a wheel loosen.
Mating surfaces clean & free of corrosion, ck that?
Ever tighten a hot wheel/tire? To what torque setting?
09-12-2018, 12:32 PM
Hiawassee
, Georgia
[QUOTE=ROBERT CROSS;2154940]
Originally Posted by bwoodtx
Yes but in 75yrs no wheel has departed any vehicle I've used it on ..
Yes, same here, but a tandem axle trailer is different than a car. In tight turns the trailer tires/wheels get a lot of force applied sideways. That has a tendency to loosen things.
I don’t know anyone who retorques the lugs on their car wheels every trip.
For a trailer you really do need to do it. Especially after having remounted a wheel.
09-12-2018, 01:53 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Well I admit, I do 're-torque' at least once a Season. 👍
