02-27-2015, 07:30 AM
#121
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
I watch the pressure rise and it goes up about 10% or less when underway (75 psi cold rises to 81 or 81 psi). The tire temps do seem to be nearly 35 to 40 degrees above ambient air temperature with the sun shining.
04-19-2015, 04:58 PM
#122
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
04-19-2015, 06:22 PM
#123
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
I like them, have the same, Tell me is your trailer high in the front or is it an illusion in the first picture on top. Mine actual rides the same, I've got a 30', towed by an F350 with an equalizer hitch set up and she rides just a little high.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
04-19-2015, 07:52 PM
#124
Castle Rock
Nitrogen was put into very high performance, very high speed, very hot tires to prevent the oxygen from igniting the tire from the inside. It has nothing to do with the pressure.
04-23-2015, 05:25 AM
#125
CapriRacer
I'm in the
, US
Ah ...... Mmmmmmm ....... actually, no. Tires don't operate anywhere near their self-ignition temperature - even in severe racing conditions. The only time they will burst into flames is when something else overheats - such as brakes. And even if N2 is used, they will burn.
04-24-2015, 11:13 AM
#126
1964 26' Overlander
1964 19' Globetrotter
OlyPen
And now back to our regular programming folks... tires, rims and wheels
04-24-2015, 06:36 PM
#127
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent
, Oklahoma
I know I've seen it somewhere, but what is the torque on the lug nuts?
Have a blessed day !
TAC OK-5
04-24-2015, 07:40 PM
#128
2005 28' Safari S/O
Paradise
On my 16" Sendels Airstream recommends 125 to 130 ft.lbs.
Steve
"THE OLDER I GET, THE BETTER I WAS"
04-24-2015, 09:16 PM
#129
Nomadic
, USA
I torqued mine to 125lbs
04-25-2015, 05:59 AM
#130
Upper St Clair
, Pennsylvania
Did you get that info on Sendel torque someplace from AS? The info I received from them on our 2015, with the Sendel 16" was no different than the stock 15" - 110 Pounds?
Bud
04-25-2015, 07:52 AM
#131
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent
, Oklahoma
I read about a thousand posts on tire/wheels, 15"/16". I changed my mind 20 times, back and forth. I argued for and against, both ways. Almost purchased one or the other twice. I finaly just did it, Discount tire said $99 on sendel TO2 16", so I bought them. I dont know if I need them,but they look great, I put BF goodrich commercial tires on them. I simply decided that I liked them, and if I can drive faster with less worry, thats a plus.
TAC OK-5
04-25-2015, 09:57 AM
#132
2005 28' Safari S/O
Paradise
Bud
This was off another post in the forum from last fall, so unless they changed it it should be good info. Their max load tire info is wrong...s/b 2680.
Steve
04-25-2015, 07:34 PM
#133
Stoughton
, Wisconsin
Nice looking rig Bold! Are the truck wheels aftermarket?
04-26-2015, 07:44 AM
#134
2014 31' Classic
Apache Junction
I took that image in Post #132 above while at the factory lounge in January 2014 while our Classic was being built. The tire load rating is incorrect, but the needed info was the torque value for the wheel lug nuts.
04-26-2015, 08:46 AM
#135
2005 28' Safari S/O
Paradise
Thanks, Switz!
Steve
04-26-2015, 07:44 PM
#136
Nomadic
, USA
Thank you, those are factory Laramie wheels, circa 2010.
And yes, I need a new drop shank, but look how pretty it all is, lol.
04-27-2015, 05:43 AM
#137
Stoughton
, Wisconsin
A lot nicer than my boring tundra wheels! Maybe next year I'll get some new chrome ones.
05-14-2015, 11:11 PM
#138
2004 30' Classic Slideout
Denver
, COLORADO AND West Yellowstone, MT
Mr. Canavera,
I also own a 2004 Classic S/O and have a telephony background from years ago. I would like to converse with you. "MontanaPat" pfgartland@msn.com.
05-19-2015, 09:05 AM
#140
Nomadic
, USA
Those are nice looking wheels!
