05-30-2016, 02:10 AM
1960 26' Overlander
Wervicq-Sud
, FRANCE
Tightening Torque of ball mount ?
Hello,
I have to change the direction of the ball but I don’ know the tightening torque of the screws
126 lbs.ft ?
Thank you !
05-30-2016, 02:21 AM
1991 25' Excella
Stanfield
Look it up in the onwers manual that came with the hitch. If its not available then contact husky directly.
05-30-2016, 02:26 AM
1960 26' Overlander
Wervicq-Sud
, FRANCE
Thank you for your quickly answer but I haven't the owner manual.
I have only for the hitch, not for the ball mount.
I'm looking for to contact husky service.
05-30-2016, 04:21 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Gael: I don't have a Husky, but found this site and if you scan down you will see installation instructions, my bet is the various torques will be there. http://www.huskytow.com/ Good luck
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
05-30-2016, 04:33 AM
05-30-2016, 05:39 AM
2016 25' Flying Cloud
Holly Springs
, Mississippi
On the Curt, it's 200 ft. pds. if that's of any help.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
05-30-2016, 06:16 AM
1960 26' Overlander
Wervicq-Sud
, FRANCE
Thank you very much, you help is important.
As the document, you show, the indication is : 260 lbs.ft (page 5)
Is relatively the same than 35 m.kg but Bob, where have you seen 200 lbs.ft ?
Thank you
05-30-2016, 04:50 PM
Holly Springs
, Mississippi
Thank you
The Curt install instructions. Curt uses 3/4" bolts for the hitch-to-shank connection. If your bolts are also 3/4" diameter I'd think the torque would be the same, but if you have the instructions for your hitch, and it says 260 ft. lbs., that is what I would use.
2016 FC 25' FB twin
05-30-2016, 05:20 PM
1974 Argosy 26
Morrill
, Nebraska
I doubt the bolt is 3/4". It may take a 3/4" wrench or perhaps a 7/8" or maybe a 15/16" wrench. Which would be 1/2", 9/16" or 5/8" bolt size respectively.
You can look the torque specs up on the Internet. Just find the correct size and grade. There is nothing special about these bolts. From the photo it looks like they are grade 8.
05-30-2016, 05:29 PM
The dirfference in torque may be due to different screw finishes.
The torque for Grade 5 plated 3/4"-10 cap screw is 200 ft-lb.
The torque for Grade 5 plain 3/4"-10 cap screw is 266 ft-lbs.
05-30-2016, 05:43 PM
, At Large
The bolts are 3/4", and require a 1 1/8" wrench and socket.
05-30-2016, 06:15 PM
1974 Argosy 26
Morrill
, Nebraska
I stand corrected. You can still find the torque specs for the specific bolt you are using on the Internet.
05-31-2016, 09:40 AM
2005 19' Safari
Jackson
I guess this shows my ignorance, but I've never heard of that concern before. I've got a. 19' Bambie. The TV is a Ford F-150.
How important is that torque?
05-31-2016, 10:05 AM
In Tennessee it would be "pretty tight, but don't break it off".
05-31-2016, 10:45 AM
Airstream - Other
Bosque Farms
I use this method: Use your biggest wrenches and tighten as much as you can with the strength you've got. Which will probably turn out to be somewhat less than what is called for in the specifications.
Lynn
ACI Big Red Number 21043
05-31-2016, 11:48 AM
1960 26' Overlander
Wervicq-Sud
, FRANCE
Husky firm confirms me that is 260lbs.ft
06-01-2016, 06:34 AM
2005 19' Safari
Jackson
Torque umph
Thanks for the Armstrong Torque comments. That's what I've used for years ---- so far so good :-)
06-01-2016, 08:09 AM
2007 30' Classic S/O
Somewhere
, South Carolina
This is slightly off topic but still related.
I carry a 3/4" drive hitch ball socket and a 40" 3/4" breaker bar.
At any AS rally or such I've shared this combo with any one interested in checking the hitch ball nut that has been tightened by some oh yeah that's tight method. Lost count of the number of loose ones, found a couple that were tight and replaced 3 hitch balls that showed damaged threads or shanks from being loose and banging around. Latest ones this past weekend a loose one for a newbie including loose shank bolts and a lets throw that hitch ball away from a veteran tower.
The loosest one could be snugged with channel lock pliers by the owner before I came back with correct socket.
06-07-2016, 02:37 AM
1960 26' Overlander
Wervicq-Sud
, FRANCE
06-07-2016, 03:44 AM
, At Large
Did you tighten the ball? Torque is on the order of 400 foot pounds.
