05-02-2013, 05:18 PM
#1741
2012 25' Flying Cloud
Battle Lake
Joe
Thanks for the response, a broken Hensley is certainly a good reason to get another hitch.
I agree with your statements on the Andersen here, but have serious other concerns of my own about it, which I have described. I just finished 2,000 miles with the Propride, including lots of mountains, with never a "Hensley bump" (I was looking for it).
doug k
05-02-2013, 05:29 PM
#1742
Battle Lake
Originally Posted by Ramble On
dkottum,
What kind of tow vehicle do you have?
2012 Dodge Ram Express 5.7 reg cab 4x4 with 120" wheelbase, towing package. I also used the Andersen on my 2006 Tundra.
I use the bed of the truck for two light bicycles and trailer external hookup stuff. My bride and I have traveled all over the country with our Airstream, what a hoot!
Why?
doug k
05-02-2013, 05:40 PM
#1743
Princeton
, New Jersey
doug k
Maybe if you ask nicely Joe will post a picture of his failed HaHa and comment on HaHa's response when asked for help.
I think I ask you this before but if not are you interested in selling your Andersen? There are a few unhappy RVers here that would like to be happy.
2004 Excursion 4x4
05-02-2013, 07:35 PM
#1744
2004 28' International CCD
rockwall
Why?
doug k
I am really new to this and I am trying to get grasp on whether I want to change out my hitch. I currently have a reese and I am looking for alternatives. The PP3 and hensley are expensive and are heavy, although I understand that they do an outstanding job. The Andersen seems to be a fit for me because of the simplicity and lower weight. To answer your question as to "Why?", I want to confirm that you were towing with a comparable tow vehicle and trailer. I don't mean to sound condescending, but my tow vehicle is a little more robust than your Dodge. My last truck was a Dodge that I drove for over 11 years and it was the best truck I ever owned. The jury is out on my new F 150. but it's has great towing and payload capacity for a 1/2 ton and that's why I choose it. Time will tell.
05-02-2013, 09:56 PM
#1745
Battle Lake
Ramble On, the Andersen is not compatible with the coupler on your Airstream. You can add to the expense of the Andersen cutting off and putting on a different coupler.
Andersen is not forthcoming about this and that bothers me. They continue to sell these hitches without a warning in advance, or notifying people who already have them the hitch could break the coupler latch and come loose from the tow vehicle.
Then there is the issue of inadequate weight distribution.
My other beef with Andersen is the great stress that the design places on its mounting brackets, and their subsequent movement. I thought I had solved this by drilling the mounting hardware into my frame, but after removing it discovered the holes had become elongated from the pressure. I don't believe the mounting hardware is adequate as designed.
Although the Andersen is an ingenious design, I don't think it is fully thought out and tested. We are doing the testing; my impression is that it needs to go back to engineering for development. Hooking it to a standard Airstream coupler is dangerous, you could loose the trailer as it wears out the coupler latch.
doug k
05-02-2013, 11:41 PM
#1746
1974 Argosy 26
Morrill
, Nebraska
This is getting to be a really old read. Obviously people have made up their minds in both directions when it comes to the Andersen.
I don't believe that any WD hitch can compensate for poor driving habits. But it can sure mask them. And it won't compensate for driving too fast or in poor weather conditions, be it slick roads or heavy winds. It just provides a false sense of security. "Oh! I have WD so I can drive faster."
I also have to ask where the physics lies. Placing tension on the frame of the TV, the receiver hitch mechanism and the trailer frame. If you can transfer weight from the rear axle to the front axle. Then it is possible to transfer too much weight making the rear axle unstable. Anyone knows that a pickup truck with no weight in the bed has lousy traction characteristics. Lousy traction equates to lousy handling. Whether it be front or rear axle stability.
But I don't see the Andy's of the A$ world commenting on the possibility that a WD system when not set up properly can be just as much or maybe more of a risk than not having one at all.
I also don't see anyone going after A$ about the lousy Atwood coupler design they are installing on these very expensive trailers. No one here could talk long enough to convince me the the force applied by the Andersen hitch could even come close to the forces applied to the coupler when the TV has brakes and the trailer doesn't. Any coupler design should be able and expected to handle these forces.
You never know when you won't have brakes on your trailer. Something as simple as a broken wire or corroded connection could cause you to lose the brakes. If the sheared "fin" as it is now known can cause the trailer to come uncoupled. Why are we not hammering on Atwood about their design? One situation of no or poor brakes on the trailer and the requirement to stop suddenly and you may shear the fin unknowingly. And the coupler could lift off of the ball.
I know there will be those who will say "you shouldn't be towing a trailer without brakes". I say " you should be driving all the time like your trailer doesn't have brakes"
I'm sure this thread will continue on for another 117 pages. And a year from now there won't be any difference in what is being written.
05-03-2013, 05:12 AM
#1747
2005 28' Safari
saline
, Michigan
I think Doug is right when he says Anderson had not done the proper testing on this hitch before introducing them. My first complaint was with the goofy stinger. Adjustable with 1.5 inches between holes but flip it and there is a 3 inch gap which I and other posters reported had to cut and weld to fix. Then the obvious poor design to hold the brackets to the trailer which will slip in nearly every case. And now the Atwood incompatibility which I am faced with.. Well I am doing nothing this year as I am not taking any big trips and so far I see nothing on my coupler to be alarmed by, but it's a ticking bomb and I know it. So those of you with QB couplers keep posting as to your experiences. I will have to decide before next year what I will do.
05-03-2013, 07:44 AM
#1748
Harlingen
Originally Posted by Kosm1o
............so far I see nothing on my coupler to be alarmed by, but it's a ticking bomb and I know it. So those of you with QB couplers keep posting as to your experiences. I will have to decide before next year what I will do.
"ticking bomb"? Aren't we getting a little dramatic? I have only read of one failure of an old worn out coupler which did not result in any serious damage.
05-03-2013, 08:12 AM
#1749
2005 28' Safari
saline
, Michigan
It is , of course, my opinion, just as yours is yours. But it is likely to fail , in my opinion, because of the reports of issues posted here. These issues might be caught in time. It is a problem that Anderson recognizes or they wouldn't cover their butts with the warning about the Atwood. I am most interested in better couplers that will work with this hitch which is why I ask for continued reports. If you look at earlier posts on this thread, you will see concerns right from the beginning about the integrity of some couplers to handle this type of hitch. At least one has come uncoupled. What do you suggest?
05-03-2013, 08:35 AM
#1750
1974 Argosy 26
Morrill
, Nebraska
Quick Bite or Bulldog. They seem to be the most robust couplers out there. Not cheap, but neither is the TV or coach.
05-03-2013, 08:43 AM
#1751
Princeton
, New Jersey
I thought I had followed the tread closely and have not noted this. Please advise who, when, and how this happened.
2004 Excursion 4x4
05-03-2013, 10:18 AM
#1752
2013 27' FB International
El Dorado Hills
Communication with Andersen Regarding Atwood Issues
For the record, here's the transcript of response from Andersen when I asked them about the Atwood coupler compatibility issue. I got this response within a couple of hours just a couple days ago.
Myself, I'm not that concerned about the problem. It seems pretty clear it develops over time, not all at once, though I will eventually need to replace the coupler. Several stores sell the Atwood 81911 for about $35, and welding another $150 or so. While I suspect the Propride/Hensley are better overall, at almost ten times the cost and almost four times the weight, I'm willing to suffer a while with the simpler Andersen.
___________________________________
Dear Andersen:
I purchased the weight distribution hitch new a couple months ago in anticipation of using it on a brand new Airstream trailer I plan to pick up and tow home next week. I've since read of some possible compatibility issues with the Atwood coupler that is probably welded onto the front of the trailer.
Can you confirm or clarify any known incompatibility issues with this hitch? If so, do you have any suggested remedies?
Response:
Great question Kurt. Only the Atwood 88xxx series couplers are incompatible with our Weight Distribution Hitch. ALL OTHER Atwood couplers are fine (80xxx, 81xxx, 82xxx, etc). We are still doing testing, but our initial findings are that the best solution for the 88xxx series is to change out the coupler. Luckily it is not a common coupler, but is popular on Airstream trailers. Below is our official announcement which we are putting out tomorrow.
With thousands of units on the road over the last 2 years, we have had tremendous success and customer satisfaction with the Andersen “No Sway” Weight Distribution Hitch.
In the last 7 or 8 weeks we heard a few reports of an issue that was specific to the Atwood 88000 series coupler. Although there were only about 10-12 reported cases, it was enough to concern us, and we are currently performing in-house testing of the coupler.
The issue: A few customers reported the potential of the Atwood 88000 series coupler to come unlatched over time due to wear.
NOTE: The Atwood 88000 series (stamped on the coupler as "Atwood model 88xxx" - xxx being any digits) is the ONLY coupler design in the RV market we have found that has this potential issue is the . All other Atwood couplers work fine. The similarly designed Marvel coupler also works just fine with the Andersen WD Hitch.
What we have found so far:
We have been performing in-house testing of the Atwood 88000 series coupler, as well as consulting with engineers and RV Technicians. At this point we have not experienced the unit unlatching, but we can see there is the potential for the possibility of this happening over time with the Atwood 88000 series so we are taking the issue very seriously. From the reports given we were told that it is something that happens over time, not immediately.
What can happen:
Because of the particular design of the Atwood 88000 series coupler, there is a lot of extra movement inside the coupler as compared to other couplers on the market. When combined with the reverse pressure that our Weight Distribution system places on it, over time, the slack in the internal mechanism of the some of these couplers slowly works its way backwards trying to unlatch from the top 'fin' - and eventually it can wear the fin down enough that it does not fully latch any more.
The solution:
At this point our official position is that the Atwood 88000 series coupler is incompatible with our Weight Distribution Hitch, so the ONLY current solution we endorse is to replace the coupler. A good quality and sturdy replacement is the Atwood MPD 81911 coupler (seen below). However any coupler other than the Atwood 88000 series will work just fine. We have checked with several welding shops who told us that it would take about 1 hour of shop time to change out the coupler, averaging about $60–$100 in shop fees.
Atwood MPD 81911 Trailer Coupler, A-Frame Tongue (10,000 lbs tongue)
Other solutions:
Although we have heard of a few Airstream owners who have had some success with modifying the latch mechanism and greasing the paw and ball, Andersen Mfg. does not officially endorse any solution other than replacing the coupler itself.
In the interest of convenience Andersen Mfg. has the Atwood MPD 81911 coupler available for $49 retail, which includes shipping to most states in the continental USA.
Please feel free to contact us if you have further concerns or questions.
05-03-2013, 01:03 PM
#1753
Livingston
Originally Posted by TG Twinkie
---No one here could talk long enough to convince me the the force applied by the Andersen hitch could even come close to the forces applied to the coupler when the TV has brakes and the trailer doesn't. Any coupler design should be able and expected to handle these forces.
This post is not to convince but, hopefully, to inform.
To make an educated estimate of how much force is exerted between ball and coupler when TV is braking and TT is not, we need to know 1) the weight of the TV, 2) the weight of the TT, and 3) how much stopping force can be produced by the TV's brakes/tires.
For simplicity, we can choose the TV and TT to weigh 6000# each.
To estimate how much stopping force can be produced by a typical TV, we can use braking test data reported by http://special-reports.pickuptrucks.com/2008/11/braking.html.
The data show that, on average, the six trucks were able to stop within 163' under maximum braking from 60 mph.
This corresponds to an average deceleration of 23.7 ft/sec/sec ofr about 0.74G.
To decelerate a 6000# truck at 0.74G requires an average stopping force of 4440#.
Since the TT is assumed to produce zero braking force, the TV must stop the combined 12,000#.
This means the combo will decelerate at 4440/12000 = about 0.37G.
To decelerate a the 6000# trailer at 0.37G would require the ball to push rearward against the coupler with a force of about 2200#.
For comparison, in the SEMA video, Ryan Andersen stated that 1/4" of bushing compression gives a chain force of about 2000# per chain and the two chains would be "pulling the trailer forward with 4000# of force".
However, I've not seen any data to indicate the 4000# can be achieved.
I think a more likely value would be around 3000#.
One also must consider the duration of the applied force.
On a typical towing day, the TV and TT might be coupled with WD applied for 8 hours.
This means the Andersen-induced static force of 3000# would have a duration of 480 minutes.
The duration of the "no trailer brakes" maximum TV braking force scenario is anybody's guess.
I'm guessing at a duration of less than 10 minutes -- if any.
So the comparison should be:
"no TT brakes" maximum force of 2200# acting for less than 10 minutes -- if any
versus
Andersen-induced force of 3000# acting for 480 minutes.
I'm sure we could debate endlessly about choice of "typical" values, but I think it's unrealistic to say that the force applied by the Andersen hitch could not even come close to the forces applied to the coupler when the TV has brakes and the trailer doesn't.
Ron
05-03-2013, 02:36 PM
#1754
1974 Argosy 26
Morrill
, Nebraska
While not debating the numbers. It's the hammer force of the trailer slammed into the back of the coupler by the braking action of the TV that would cause the fin to shear.
If there is any slop between the ball and coupler the hammer force can do considerable damage when taking up the slop.
I don't think the standard torsion bar WD hitch would prevent the slamming action. Whereas the cushioning provided by the bushings on the Andersen may.
I still have not convinced myself that the Andersen is the way to go. But we are headed on a 4,000 mile journey in 3 weeks. This trip should give me an indication of how it will perform.
My coach has a Marvel coupler rated at 20,000# so the Andersen may not be a problem. However, I will be keeping a close eye on it. Especially the brackets on the tongue. Looking for any movement. I have scribed lines on each side of each bracket, making it easy to identify the slightest change.
I will report any problems here. During and after the journey.
Just in case, I have installed a safety chain over the coupler to prevent it from lifting off of the ball.
So, we will see how it goes.
05-03-2013, 02:42 PM
#1755
Harlingen
My truck will decelerate much faster than it will accelerate. Doesn't this prove that more force is applied to the coupler in braking than in towing? How much force is required to maintain 60 mph? Certainly not as much as when hard braking. Your 480 minutes assumes maximum force being applied the whole time, doesn't it? It takes a lot less force to maintain 60 mph than going from 0-60 or 60-0.
05-03-2013, 03:24 PM
#1756
2012 25' FB Eddie Bauer
Fairbanks
, Alaska
Without getting into a bunch of calculations the problem with this analysis is that braking force available isn't the limiting factor to stop an unladen pickup. Weight transfer that unloads the already light rear end is. This results in rear wheel lockup or ABS activation long before max available brake force is reached. If you check this out 2010 HD Brake Tests - PickupTrucks.com Special Reports. You will see that some of the trucks tested, see the GMC 3500 actually stopped quicker with 2000# added to the bed of the truck.
By the way you will see these 3/4 and 1 ton trucks stopped shorter than the 1/2 tons of a few years ago.
Bottom line is that a truck brake system can generate much more force than it can use in an unladen condition so trying to predict max force available from those stopping distance's is not feasible.
I am going to use my Anderson with my AS and see what happens.
versus
Ron
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
05-03-2013, 03:31 PM
#1757
Salem
, Oregon
Hi, [my opinion] I don't believe this statement to be true; Otherwise we would hear of many more failed couplers. I believe the cause is a combination of a dry hitch ball, pulled tightly against the pawl, and the hinging effect at the ball forcing the pawl upward. This would in turn put undue pressure on the fin, as we call it. Therefore this is an Andersen only, concern.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-03-2013, 04:57 PM
#1758
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
I agree with that Bob.
Annette
05-03-2013, 05:25 PM
#1759
Harlingen
Wouldn't the dry hitch ball be a problem for all couplers, not just the Andersen?
05-03-2013, 05:38 PM
#1760
Mantua
, Ohio
The trailer slamming into the hitch under braking can be eased by adjustments to the brake controller. If the trailer brakes come on earlier would that not tend to drag the tv back and cushion the blow to the hitch. I hope I am saying this correctly. I know from my experience setting the controller this way helos to eliminate the bump the trailer does to the tv and hence to the hitch. Jim
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jpnoack
