Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 10-03-2007, 06:19 PM   #1
ctdair's Avatar
Seal Part #'s for Hensley
Have taken my Hensley apart for repainting and need to replace the seals has any one else allready done this and have seal part #'s . Hensley claims no part numbers to supply and not really set up for selling them but they would. Faster and cheaper locally I would guess. Tech service at first said disassembly possible and then when I asked if there are preload torque specs they started to discourage me from attempting disassembly. The hitch is now in pieces on the floor awaiting cleaning and painting. I felt disassembly was straight forward and I am comfertable enough with bearings that this will be no problem to reassemble . Hope my paint job lasts/works better than the factories.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch.
Pulled by a 2019 F350 Superduty Limited.
ctdair is offline   Reply With Quote
Old 10-03-2007, 07:22 PM   #2
1984 31' Excella
Broken Arrow , Oklahoma
Images: 11
Seals
If you have a good accurate dial caliper(machinists or reloading), measure the inside diameter of the hole the seal drives into, the outside diameter of the rotating shaft and the thickness of the seal. Take that information and an old seal to a good bearing and seal place such as Applied Industrial Technologies and they can match it up.
If the bearings are tapered roller bearings like in your trailer wheels the preload should be the same. It is for the front end of a 1936 Cord 810.
Beginner
Beginner is offline   Reply With Quote
Hensley points down... Buttercup Hitches, Couplers & Balls 23 08-26-2006 05:43 PM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
Help - Transmission Rear Seal Part No? swebster Mechanics Corner - Engines, Transmission & More... 8 02-29-2004 02:49 PM
