Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 08-23-2008, 07:07 AM   #85
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
visited CAT scales - the numbers are in...
At some point I would look through all the numbers:
1. TT Length, Hitch Ball Center to TT Rear Bumper:
2. TT Tongue Weight:
3. TT Hitch Center to Rear Axle Center:
4. TV wheelbase:
5. TV Rear Spring Capacity:
6. TV Rear Overhang (axle center to hitch center):
7. Length of bars:
A. TV Steer Axle, Solo:
[1] TV Steer Axle, Loaded:
B. TV Drive Axle, Solo:
C. TV Weight Bias, FF/RR, Solo:
[1] Loaded:
D. TV Weight, Solo, Gross:
E. TV Weight, Loaded, Gross:
F. TT, Tongue Weight:
G. TT, Axle Weight (all axles):
H. TT, Axle Weight (front):
I. TT, Axle Weight (rear):
J. [TT, Axle Weight (center):]
I. TV, FF, height, solo:
II. TV, FF, height, loaded:
III. TV, RR, height, solo:
IV. TV, RR, height, loaded:
V. TT, height (fenderwell), solo:
VI. TT, height (fenderwell), loaded:
The two dozen numbers can be useful for further tuning or understanding; ideally, one would also have all eight [8] INDIVIDUAL wheel weights (SRW TV and dual axle trailer) for weight biases FF/RR and side-to-side.
One may also use NickCrowhursts spreadsheet:
Load distribution hitches-an analysis
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 08-23-2008, 07:49 AM   #86
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
4. TV wheelbase:
7. Length of bars:
[1] Loaded:
That may be all well and good.
However, the vast majority of owners, won't get into that program, nor are they really interested in doing so.
The hitch manufacturers are not interested enough to do that research, based on the fact that that information would not be in agreement with what they have all preached for way to many years.
But, the vast majority of owners, we think, "are" interested in the simple "bottom line," as we have outlined numerous times.
But, no big name wants to step up to the plate to provide that simple bottom line, since it would clearly demonstrate the erroneous information that has been shoved on the general public, for way too many years.
As an example, the Reese chart is totally misleading, as some members have already so posted and agree with that statement.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 10-18-2008, 07:55 PM   #87
norsea
norsea's Avatar
Profile:  2008 30' Classic
On the road since 2000 , norseaodyssey.com
5000 miles later....
Since changing to the 600 pound bars and readjusting the hitch we have traveled from Shady Cove, Oregon to Jackson Center, Ohio, then south to Anderson, South Carolina and back to Jackson Center where we will be for the next week getting the new cabinets installed in the front of our trailer.
We have only traveled I75 north from Dayton, Ohio to the Jackson Center turn off twice. All of the remainder of the trip has been on different roads that range from interstates to the steep, twisty, narrow roads of West Virgina.
This is the first time we have gone anywhere and NOT incurred damage to any of the hitch components. We be "happy campers"!
I would like to transfer an additional 200 pounds from the rear axle to the front axle.
I am concerned about increasing the load on the existing spring bars and wonder if it would be best to use 700 pound bars rather than the 600 pound bars. But, I have no way of knowing if the stiffer bars will in fact accomplish my goal without causing the problems we experienced initially when we were using the 1000 pound bars.
Anyone have any ideas?
We are travelers with an attitude. We get to go anywhere, anytime, and have attitudes about what we see and hear.
"Travel is fatal to bigotry, prejudice and being narrow minded."
norsea is offline   Reply With Quote
Old 10-18-2008, 08:51 PM   #88
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
What type of damage did you have in the hitch that you attribute to the bars.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 10-18-2008, 09:29 PM   #89
norsea
norsea's Avatar
See post #3...
See post number three...
Old 10-18-2008, 10:12 PM   #90
Shacksman
Shacksman's Avatar
Profile:  1967 22' Safari
1960 28' Ambassador
Avonton , Ontario
Can someone tell us how to tell the weight rating of the bars? I don't see anything marked on the bar.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 10-18-2008, 11:20 PM   #91
Commercial Vendor
Who is the manufacturer of your hitch bars?
Inlandrv.com
800-8777311
Old 10-19-2008, 08:57 AM   #92
Shacksman
Shacksman's Avatar
1960 28' Ambassador
Avonton , Ontario
Andy, the bars are the dual cam bars. The heads have cast into them, Reese RL109.
They are 1 1/4" square where they enter the head and are 25" long from the head to the end.
There is the remains of a tag on the bars but unreadable.
Another set I have says "Quality s" cast into the head, same measurment.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 10-19-2008, 09:14 AM   #93
HowieE
HowieE's Avatar
Images: 11
Reese has lost any level of quality control with their products. The last two items I purchased retail I had to return directly to Reese for replacements.
A set of mounting plates for the cam arms were so poorly aligned that the bolts would not even pass through them let alone position the arms correctly. Even the replacements they sent were bad and I ended up rewelding the holes closed my old ones and drilling new holes and using them. Sent all 4 new plates back to Reese for credit.
I just installed the newer type cam system and one of the cam arms was so misaligned, by more than 15 degrees, causing the bar to ride high and off center to the point on minimal contact.
Old 10-19-2008, 09:57 AM   #94
norsea
norsea's Avatar
Wow!
I am happy to say that the equipment that was shipped to me had no such problems.
I continue to be curious as to how I can transfer two hundred pounds more from my rear axle to my front axle.
I had hoped that Andy might have some "words of wisdom" for me. I am very happy with the performace of the current set up. But, my rear axle weighs in 400 pounds heavier than the front axle.
Old 10-19-2008, 11:20 AM   #95
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Jim, can you lower the ball height on the truck by an inch? That would move weight from the rear trailer axle to the front.
Old 10-19-2008, 11:55 AM   #96
HowieE
HowieE's Avatar
Images: 11
Hi Jim
Well I went out and played around with the bars and I can see when and how it is possible to bend or brake the trailing arms on the newer Reese hitch.
On a turn the head of the inside bar moves in under the tongue and up off the cam causing the bar to become closer to the heavy casting part of the trailing arm. The fewer chain links used between the hanger and the cam the sooner the bar will contact the heavy casting. At the point the bar and casting come in contact, this is greater if the hitch point is dropped with lower than TV and trailer as in a slight valley, at which time there would be extreme force applied to the cam end of the trailing arm forcing it outwards. I assume when you saw a bend in one of your trailing arms the bend was outwards at the end of the trailing arm.
The easy cure would be to increase the number of links between the hanger and the cam thus increasing the angle between the bars and the trailing arm. This increase would reduce the potential contact. Yes head angle adjustment would also be required to maintain proper front axle load.
If increasing the number of chains links is not possible grinding some relief on the bottom edge of the casting would work. There is more than enough material there to allow some removal.
I have posted 2 pictures. The first shows the relationship of the bar to the trailing arm. There is clearance between them. The second shows how the bar has moved in,during a turn, to a point of contact with the trailing arm casting.
The correct solution would be for Reese to rotate the casting 90 degrees greatly decreasing the potential contact point. This would also require them to drop the bolt point holding the trailing arm to the frame to give frame clearance to the casting.
I am going to have to hook up find a gully and do a 90 degree back up across that gully to see how close my bars come to the casting. From my playing around it doesn't look like I would make it across a deep gully while backing into a campsite without contacting the casting.
ID:	69837   Click image for larger version
Old 10-19-2008, 04:09 PM   #97
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Howie, not sure in the pic, but is the chain point to point verticle?
Also a while back I had Resse tech support on the phone and this guy who sounded very knowledgeable said you should always strive for 5 links no more no less.
I did that by the adjustments and went over 20,000 miles since.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 10-19-2008, 04:56 PM   #98
norsea
norsea's Avatar
What caused the sway control to bend/break?
Overlander63, HowieE & LIPets,
First, as to changing the angle of the ball. Yes, I had it set with more rearward angle when I first put on the 600 pound bars. This gave me two things I wanted and one I did not want. The first was more weight transfer to the front axle (good). The second was the hitch was approximately 3/4 of an inch higher off the ground (very good; this put it at 19.5" where as currently it is at 18.75".
The third thing this did was really put a lot more bend in the bars. I was (am) very concerned about over stressing the bars at hitch time. If I do this I fear that it could be possible for the bars to bend much, much too much when encountering road conditions I find all too often on our interstate road system which causes the defection of the truck rear end and ultimately results in several very large movements up and down (like proposing). I do NOT want to take the chance of breaking either bar.
As to the cam arms, when mine bent and/or broke I did not find any evidence of the trunnion bar making contact with the large part of the cam arm where the threaded rod from the sway control passes through. But, I can see where it would be very easy to have this happen if the trunnion bars were adjusted such that they worked in the fashion described by HowieE. And yes HowieE, the bending was away from the A frame of the trialer.
As HowieE and I discussed on the phone, I am of the opinion that the heavier the trunnion bars the less free play there is in the area of the sway control where the trunnion bar rests when making extremely tight turns. Also, when an off camber condition is added to a decreasing radius turn the forces at the cam itself being exerted by the trunnion bar appear to me from observation to have a great potential for lateral movement of the trunnion bar itself which acts like a lever against the side of the area where the trunnion bars rests on top of the sway control. This is very different from making contact with the large area the threaded rod passes through. Hope this makes sense.
As for the chains and how they pull, in my first post to this tread I stated, "Also note that there is a plate between the trailer frame and the chain pull up mechanism that is a quarter inch thick piece of aluminum. I found I had to do something to get more space between the bars and the "knuckle" of the dual cam."
This, in my opinion, does a lot to reduce the angle of the chains being pulled in towards the A frame of the trailer. My objective by adding the plate was to insure that the chains were perpendicular to the A frame and not angled in to the A frame.
It should be noted that twice when the sway control rods were bending with the heavier trunnion bars the plate that the chains attach to was bending as well. In one case it was bent so severely that I could not turn it to remove it from the sway control.
Any rate, as I stated earlier, I am happy enough with how things are set up now but I wonder if the use of 700 pound bars would allow me to transfer more weight to the front axle and raise my hitch up an additional 3/4" to 1" without altering the angle of the trunnion bars in relation to the hitch and sway control (and therefore not changing the ball angle), thereby not putting so much stress on the trunnion bars as is necessary by changing the angle of the hitch ball at the hitch with the 600 pound rated bars I am currently using.
Jim, who appreciates everyone's input to this thread and is looking forward to hearing from Andy about all this...
