11-14-2013, 12:56 PM
#121
Livingston
Originally Posted by Sean Woodruff
For anyone who wondered what the "ripple" in an earlier post may have been you can actually zoom in and see the paint on the chain. I know there are quite a few people who do not believe the chain is strong enough to cause any damage but here is some more evidence for the judge.
The evidence I see in that photo shows "ripple" damage which might have been caused by a properly-routed, but too-short, chain.
The damage appears to have been caused when the TV and TT were aligned nearly straight ahead.
The chain might have been pulled too taut if the rear tires of the TV were in a dip or if the TT was being backed up an incline with the TV on the level.
The "evidence" I do not see is any marking on the driver's side WD bar which would indicate a tensioned safety chain was dragged across the top of the WD bar.
It does look like some paint has been removed from the inside of the passenger-side WD bar -- such as might have been caused by a safety chain which was properly routed between the two WD bars.
Ron
11-14-2013, 01:52 PM
#122
1994 30' Excella
alexandria
, Kentucky
Maybe the topic for another thread but a serious question for a customer...
Would you recommend that we cut the stop shorter, increasing the turning radius, so that anyone using a 3P hitch will come in contact with the frame or the trailer in those situations?
I'd have to test how much shorter I can get it.
If the Propride has the same turning angle as the Hensley then I would vote NO. Hitch components are far easier to replace than damage to the TV or trailer.
The bending of the stinger seems like it is no more than a person who is not experienced in backing a trailer (no offense to newbies - we were all there once).
I have backed my trailer at many extreme angles, made highway U-turns and have never touched the tow vehicle to the trailer or bent any hitch components.
The driver must keep control of the trailer when backing or use a long arc sweep if doing a U-turn - common sense. If you get into to tight of a turn then you must stop. Experience will show you to not get at an angle that is tighter than what can be easily straightened with a turn of the steering wheel. If you have ever backed a hay wagon you know what I mean.
From the pictures I doubt there would be any damage to the A-Frame but I would definitely inspect the hitch components and the welds on the tow vehicle receiver.
A manufacturer of a PPP style hitch should make mention in the owners manual that the turning radius is tighter than a standard hitch but there are limits that the operator of the tow vehicle should observe. There is also the risk of undue strain put on hitch components and trailer running gear.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
11-14-2013, 02:22 PM
#123
Livingston
Originally Posted by HowieE
Now back to the fact that Annie has bent her stinger. The force necessary to do this could have only been exerted by counter forces produced at the wheels of both the TV and the trailer. Those forces had to be conveyed through the frames of each vehicle.---
Howie, you're correct about the load path -- but it might be good to try to estimate the magnitude of the forces and torques involved.
The photo posted by dkottum in post #34 indicates the vertical bar of the adjustable hitch twisted at the bottom about its vertical axis.
This means the yield stress of the vertical bar was exceeded due to a torque applied about its vertical axis.
That torque was applied via the bottom (horizontal) portion of the adjustable hitch.
If the vertical bar had a solid 2"x2" cross-section, and if we assume the yield strength of its steel is 36,300 psi,
the amount of torque required for the steel to reach the yield stress would be about 65,000 lb-inch.
However, the vertical bar does not have a solid 2"x2" cross-section.
It has several 5/8"?? holes drilled through it -- one of which is almost in line with the top of the horizontal bar which applies the torque.
Presence of the holes means the vertical bar has less torsion capacity, but let's assume it could handle the 65,000 lb-in of torque.
When the ProPride hitch reaches its angular limit of approximately 83 degrees, the two linkage bars become parallel to each other, and the TV is trying to push the trailer sideways.
The TT's tires generate a sideways load on the TT to counter the pushing of the TV.
If we assume the distance from the vertical bar of the adjustable hitch to the midpoint between the axles of Annie's TT is 220", the force exerted by the TT's tires to produce a torque of 65,000 lb-in would be about 65,000/220 = about 300#.
With that in mind, if the rig were mine, I would want to have the frames inspected. On the trailer the point I would assume would show deflection first is the point where the A frame enters the trailer body. Inspecting the sealant on the outside of this point should show if movement has occurred. If the TV is a framed vehicle I would look receiver first for bending and at the rear most body mounts looking to see if the marks of the mounts to the body show movement. While these point are acting in tandem, and thus sharing the load necessary to bend the stinger, they are both significantly weaker point than a 2 in. square steel shaft.
I would not be concerned about either the TV's frame or the TT's A-frame or body.
It appears that the vertical bar of the adjustable hitch was the weak link in the system because that's where the obvious yielding occurred.
However, I would have the TV's receiver and attachment points closely inspected for signs of cracking.
The receiver and its attachments should be able to handle the roll-axis torque due to tongue weight and weight distribution,
but I don't know if they are designed to handle the amount of yaw-axis torque which caused the vertical bar of the adjustable hitch to yield.
Ron
11-14-2013, 02:24 PM
#124
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by Ron Gratz
Doug, it shouldn't be necessary to do either.
With or without a spotter, the driver should be able to tell when the TV and TT are about to make contact. Denting your truck/Airstream when backing is relatively easy to avoid.
Bending you hitch bar when using a 4-bar linkage hitch is more difficult to avoid unless the driver has been educated about the angle limitation.
As Steve Rankin's photos show, it is not obvious when that angle is about to be reached unless the hitch has some markings and the driver knows what they mean.
And, as Steve's photos show, the hitch limit can be reached with good remaining clearance between TV and TT and with no obvious interference between hitch components.
Ron
I don't know if this is true.
With an 85 degree limit the ProPride may actually be able to turn as much or more then a conventional hitch without damage due to the extra 8-12" of clearance between the coupler and TV rear bumper.
11-14-2013, 02:57 PM
#125
Livingston
I agree with what you say.
What part of what I posted do you think might not be true?
I think we're saying the same thing.
Ron
11-14-2013, 03:05 PM
#126
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Ok...
....ask the obvious question.
How many of us towing with the HA-Pride has ever reached the point of... "can't go no further?"
I know I haven't, backing, turning or whatever.
Rare occurrence.
Consensus?
The bent stinger was in fact caused by passing the limit....consider the lesson learned, cover it in customer orientation, store it in your memory banks and Stream Safe.
11-14-2013, 03:08 PM
#127
Princeton
, New Jersey
Ron
It has been 50 years since I had any strength and materials classes and really had little use for them while working, thus I did not attempt to show the math.
However I do remember that a cantilevered beam, the tires to the hitch, has a uniformly increasing bending moment along the beam. A beam designed for that would have no problem supporting the load we are talking about here. My point is the trailer frame was not designed with this type of load in mind and thus I suggested looking at point where displacement would be most likely to show up.
2004 Excursion 4x4
11-14-2013, 04:23 PM
#128
1988 32' Excella
Robbinsville
, New Jersey
Ron
It seemed that you were saying there is a smaller limit of the angle then with other hitches.
Unless you just meant people need to be told sheet metal damage might not be the limiting factor with this type of hitch.
11-15-2013, 06:56 AM
#129
Livingston
That is what I meant to convey when I stated, "And, as Steve's photos show, the hitch limit can be reached with good remaining clearance between TV and TT and with no obvious interference between hitch components."
IOW, you can reach the hitch limit before there is any sheet metal damage.
Ron
11-15-2013, 10:51 AM
#130
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Fifth Wheel hitching problem
A buddy of mine has a Silverado. I met him when I asked "What on earth happened to your truck? I thought a tree might have fallen across it as the sides of the bed were all crushed down.
Somewhat redfaced, he told me that he had been towing his fifth wheel when it came off the hitch and KA-Boomed on his truck. He hadn't yet left the campground and was only going about 5 mph... but Oh the humiliation and drama! Then he said he normally lies and says he just got it super cheap with a salvage title!
Now there's a story that makes me even happier I never considered a fifth wheel. I hate to ever be on the side of more government regulation but has anyone ever seen an RV dealer that offered a "newbies guide to towing?" It's kind of remarkable how few of us DON'T get hurt or killed making newbie mistakes on our first few trips.
I remember years ago that a local municipality decided to save vehicle costs for road and sewer maintenance trucks by putting utility trailers on them The idea was that carrying a lot more equipment per vehicle would allow the crews to get to work faster and that they could send one or two trucks out to a project instead of three or four and still have everything on hand they needed to do the job. Worked fine, except for the number of accidents the (almost totally male) crews started having. The city concluded that they'd just all assumed that the men could "handle it." $40K in damages convinced them that no one is born knowing how to hitch, tow or back up safely (surprise surprise). So they put in a 3 day seminar with classroom and real driving/backing practice. The accident rate went back down to pre-trailering levels.
Brings me to a hijack - we ask for volunteer inspectors. How about a "forum manual" of good hitching practices and safe towing suggestions" - or even have volunteer mentors for the newbies? I say that with a grain of caution as a "geezer" told me to simply twist my chains to shorten them when I first started. BAD advice. Even my new EB Airstream came with the emergency breakaway cable threaded through the chains... (Another BAD idea.) I left it alone for the first trip... and sure enough the chains were a tad too long and got a tiny bit of road rash. I shortened them one link. The cable looked badly damaged so I took it out of the chain and "tested" it by pulling on each end. D'oh, it popped apart. Got a nice replacement one - it is six feet long, but it sprials so it rides well clear of all the things that can pinch or sever it. It's also covered in red plastic so it's easy to notice that it's hooked up right.
Paula
11-15-2013, 02:12 PM
#131
Wise Elder
2010 30' Classic
South of the river
Good question. I always thought the turning angle was limited mainly by the inherent geometry of the hitch. I don't think I've ever hit it but I have had the yoke dislodged when maneuvering in difficult (hilly/muddy) terrain. One of the things I want to try is painting marks on the hitch somewhere so I can determine without unhitching how much turn angle is left.
11-15-2013, 02:43 PM
#132
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
A back-up camera, a hitching stick on the receiver,
.... use the stick as the vertical crosshair, when the tank becomes un-covered, get out and check, continue increasing the angle, repeat as needed. Burn it in the memory banks.
11-15-2013, 03:27 PM
#133
2002 25' Safari
Fountain Inn
, South Carolina
Paula
Well stated Paula. I received a very small amount of instruction from the technician that setup my first new SOB. The rest of my skills were learned the hard way and on this forum and the rv.net.
Bud
11-15-2013, 03:45 PM
#134
2014 30' FB FC Bunk
Hoover
, Alabama
Guess how dealer initially installed chains? I noticed immediately and corrected
I'm staying at dealer tonight and reading the manual before we pull off
11-15-2013, 03:54 PM
#135
Livingston
Jammer, I think you're correct about the turning angle being mainly limited by the inherent geometry.
The above plots were generated for the Hensley Arrow linkage, but I think they apply to the ProPride as well.
At 0 degrees you can see the slightly greater center-to-center spacing of the rear pivot points.
This gives the hitch the "converging" geometry which causes the trailer's pivot point to be "projected" forward about 52".
At 19 degrees, the ball has reached its maximum lateral displacement of about 4.8".
The geometric limit for the hitch occurs at about 83.5 degrees when the right-hand linkage bar has rotated more than 180 degrees and becomes parallel with the left-hand linkage bar.
At this angle, the hitch is attempting to push the trailer sideways.
It looks as though the physical limit for the linkage would occur at about 88 degrees when the left-hand WD bar swings far enough to make contact with the right-hand WD bar.
Relationships for the ProPride 3P might be slightly different from those shown above.
Ron
11-15-2013, 03:59 PM
#136
2005 30' Classic
Burlington
, Ontario
This subject has also got me interested!
I too assumed that at some point the four bar link would just reach the end of its travel and lock up - never really checked it though or gave much thought to what the result of that might be!
I just quickly went through our Hensley manual and didn't see any advice or warnings about backing up - I went through it quickly and might have missed something - I will re-read!
At times, I have backed at some pretty sharp angles and always thought it was a bonus that the extra length of the Hensley setup allowed me to do that.
But now I have some new concerns about maybe causing damage and how to know when i am close to doing that!
Annie - it is an ill wind that blows no good! You have got many of us thinking!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
11-15-2013, 05:07 PM
#137
Livingston
Brian, according to former Hensley Arrow owner, Steve Rankin, and as shown in the above photo,
when the corner of the orange cover lines up with the center of the draw bar,
you have reached the limit.
In the photo, the limit has not quite been reached.
I have not verified this. You might want to check it out.
Ron
11-15-2013, 05:29 PM
#138
2005 30' Classic
Burlington
, Ontario
Thanks Ron,
Looks like pretty darn near a ninety degree angle! Not often I back up that sharply I don't think so maybe I don't need to worry after all!
Reminds me of a time when we checked into an RV park at Apache Jct. It was one of those places that are 90% park models with the odd spot open for rent in amongst them.
Roads seemed pretty narrow and I'm not the best backer-upper and so I was a bit concerned about my ability to get into the tight spot that was oriented ninety degrees to the road (why, oh why, do they design RV parks like that!?).
Anyway, they sent an older gent with me to help me back in. He was a gruff old guy a bot like a drill sergeant (but all in good humor), and instructed me to do exactly what he told me.
He had me execute a whole series of first cutting the wheels full lock one way, backing up a bit, then cutting the wheels to the opposite lock, going forward a bit and then repeating this cycle many times.
I was very impressed how well the trailer went in and decided to remember that technique next time I encountered such a situation.
Mostly been in pull-throughs or well angled back-ins ever since. but i still remember how well that worked in a spot I thought was going to be a real challenge!
Brian
2005 Classic 30'
11-15-2013, 06:03 PM
#139
2012 27' Flying Cloud
W
, New England
First - congrats!
Second - spot on! Put those chains under!
Third - you might also want to take up a little slack on them. They look pretty close to the ground.
Enjoy!
11-15-2013, 06:40 PM
#140
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Originally Posted by SteveSueMac
First - congrats! Second - spot on! Put those chains under! Third - you might also want to take up a little slack on them. They look pretty close to the ground. Enjoy!
Also, the chain coupler may not be the correct strength for the job at hand and you might be able to stretch your cord a bit so it doesn't pull out in a tight turn? All fun stuff to muck with in the rain. Jim
