Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 09-27-2006, 10:39 AM   #1
flynmike's Avatar
2005 30' Classic
Sacramento , California
Need to lower reciever hitch
The receiver on my Dodge 4X4 in two inches too high, even with my Reese Dual Cam set on the lowest setting.
My plan is to shim the hitch down two inches with two inch solid steel bar. Since I'll need longer bolts, what kind of bolts should I ask for? Hardened or something like that?
Any thoughts from the forum? Do you think this is a good plan? It will put my hitch height right where it needs to be and I think it will be safe and solid.
Mike
'05 30' Classic rear queen with an '11 Dodge Cummins Turbo Diesel tow vehicle
Avatar is inflight refueling of an F-15 over Nevada...best job ever!
flynmike is offline   Reply With Quote
Old 09-27-2006, 11:05 AM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Sorry, but I think you are asking for trouble or a serious accident. By lowering your receiver, you would be changing the dynamics of your hitch design. A properly designed receiver hitch doesn't carry the weight on it's own, but transfers it to the frame of your tow vehicle. Moving how and where it attaches would change that and you would be setting yourself up for hitch failure IMO.
Grade 8 (automotive grade) bolts are the strongest readily available bolts and they wouldn't hold up to the additional stress you would be subjecting them to - I've used them to repair my recliner at home and they've snapped off, more than once! (poor recliner design, I only weigh 200lbs )
Your correct plan of action would be to get either a drop hitch of the right height, or an adjustable hitch that slides into your reciever. They are widely available.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 09-27-2006, 11:25 AM   #3
nymphfishin's Avatar
1977 Argosy Minuet 6.0 Metre
Del Norte , Colorado
Images: 30
[quote=flynmike]The receiver on my Dodge 4X4 in two inches too high, even with my Reese Dual Cam set on the lowest setting.
Mike
I had the same problem could not find a hitch low enough, even the adjustable hitches were to high.
I took mine to a welder and he cut the drop portion off the hitch and rewelded it under the draw bar part which dropped the ball 2'. Then he welded a couple of triangular pieces to reinforce it.
I hope this makes sense?
I think he charged $20 bucks.
That 2" bar requires a heavy duty weld.
Don
nymphfishin is offline   Reply With Quote
Old 09-27-2006, 11:36 AM   #4
McLogger's Avatar
Columbia , South Carolina
I too have had this problem. I recently bought a 10" drop bar with 8 pre drilled holes. Have you looked at any of the drop systems? How far off are you from the top of your receiver to the top of the coupler on the trailer??
Happy Camping
McLogger, AIR # 16452
McLogger is offline   Reply With Quote
Old 09-27-2006, 12:43 PM   #5
flynmike's Avatar
2005 30' Classic
Found the right drop
In all my research before buying the Reese Dual Cam I never saw the third size drop bar....until now. I found it on the Reese website!
I did not know there was one size longer than the one I have....oh well it's the old "live and learn" again.
Thanks a lot to you guys for setting me straight and now all I have to do is buy this longer drop ($100.00) and I'm set!
Mike
Old 09-27-2006, 03:11 PM   #6
McLogger's Avatar
Yes, I spent around $100. as well good luck
Happy Camping
Avalanche Front reciever knunut Hitches, Couplers & Balls 2 12-04-2006 08:32 AM
lower on one side? bradk Axles 8 06-18-2006 01:59 PM
How do I lower the spare? 3x2x4sp389 Classic Motorhomes 1 04-26-2005 10:02 AM
is there a way to lower the hitch weight BobNetherlands Hitches, Couplers & Balls 1 10-29-2003 10:46 AM
Lower a Caravel? amfab Axles 2 01-28-2003 01:39 PM
