We've talked about this method and the diagram is in many Airstream manuals. I think it is high time we had a better point of reference in the Forums. This will be a how-to for using simple materials and a bathroom scale to weigh the hitch (a.k.a. tongue) weight. Refer to the diagram attached to this post.
Do this only with the trailer on level ground and wheels chocked. Make sure the scale is capable of weighing at least 250 pounds (300# better). You can weigh 2 to 4 times the scale capacity with this setup, therefore you might be able to make this measurement for up to a 30-footer depending on vintage (newer trailers being much heavier). Refer to Airstream's FAQ page numbers on your
trailer's curb weight (without options). This simple measurement will help you understand where your tongue weight falls in relation to the empty trailer number. For real world relevance I would advise having WD gear & your bars on the A frame, having LP in the tanks, and even taking the hitch bar/ball off your TV and setting it on the A frame too (we are aiming for the tongue weight load imposed on your TV after all). Whether you have any personal items in the trailer is up to you -- just factor in an allowance if the trailer is empty. Weighing at a CAT truck scale should be more accurate than a bathroom scale; use the search function if you want to find more on that.
These instructions from Draw-Tite are clear and I don't want to put this off until I can retrieve the manual from our stored trailer.
"Tongue weight (TW) is the downward force exerted on the hitch ball by the trailer coupler. In most cases, it is about 10 to 15 percent of GTW. TW of up to 300 lbs. can be measured on a household scale by resting the trailer coupler on the scale and placing the scale on a box so that the coupler is at its normal towing height. The trailer must be fully loaded and level.
"For heavier tongue weights, place a household scale and a brick that's as thick as the scale three feet apart as shown in Figure 2. Set a length of pipe on each and rest a beam across the pipes. Re-zero the scale to correct for the weight of the beam and pipe. Securely block the trailer wheels. Rest the trailer jack on the beam as shown, one (1) foot from the brick and two (2) feet from the scale.
"To obtain the TW, multiply the scale reading by three (3). For greater tongue weights, place the scale and brick four (4) feet apart, rest the jack on the beam three (3) feet from the scale and multiply the scale reading by four (4)."
Be sure and use beefy enough lumber and maybe put a piece of plywood on your bathroom scale to spread out the forces concentrated under the pipe.
