Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 06-29-2003, 10:12 PM   #1
drboyd
drboyd's Avatar
Profile:
Hitch ball height...
...off the Airstream web page at http://www.airstream.com/airstream/p.../weights-1.pdf
Where is that measured to? Top of the ball?
I know this is a dumb question.
Sorry!!!
Don
Old 06-29-2003, 10:48 PM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Don!
I have just completed resetting my hitch after having some rear suspension work completed on my '75 Cadillac - - raised the ride height by nearly 2". In addition, the hitch was set up for my '64 Airstream that needed 18.75" rather than the 18" for the Minuet that I am preparing to tow with the car. I found the following "pdf" file from Reese to be invaluable in the process of making these adjustments:
Reese Hitch Head Adjustment Directions
Basically, what I learned through following these instructions was that the suspension on my Minuet has settled resulting in a level ride hitch height of 17". Following the directions in the "pdf", I set the hitch height to 18" (measured to top of ball the additional 1" is to compensate for tow vehicle squat as per Reese directions). After reading these instructions, if I were setting up the hitch on my Suburban and I could get sufficient drop, I think that I would set the hitch height to 17" as the Suburban doesn't squat at all when the Minuet is hitched to it and 18" is resulting in a nose high attitude for the Minuet
The result is a very smooth towing experience with the Minuet and Cadillac combination.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 06-30-2003, 05:29 AM   #3
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Normally, yes, to the top of the ball. If you think your trailer suspension has sagged, get the trailer level, then measure from up inside the ball coupler to the ground. You'll have to add a bit (maybe 1/2" or so) to compensate for the truck sagging, even after weight redistribution.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Hitch Ball Height RivetED Hitches 4 03-21-2004 08:25 PM
truck mods & hitch height changes silverback Hitches 13 12-31-2003 07:54 AM
Hitch Ball size for 1971 31' Sovereign? westeagle Hitches 2 12-07-2003 11:04 AM
silly ball height question. AV8 Hitches 7 11-09-2003 05:32 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
