Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 01-13-2009, 02:42 PM   #1
Augie R.
1960 22' Safari
carlsbad , California
First tow with the bumper
Hey there folks ,
So I finally got my AS home from the storage lot. I towed it hooked up to the bumper... I know its not safe but it was only like 12miles to home. But I noticed that there was no problem pulling it at all... I had some up hills that i thought was gonna be bad but it made it no problem. I tried putting on a reese tow hitch but it dosn't work I have to have it welded on. But I know that it if does not fit it was not meant to be on there so I'm still looking for a TV that can handle it. Enjoy these pics.
Name:	first trip home.jpg
ID:	73837   Click image for larger version
Name:	First panel off.jpg
Name:	tounge to bumper.jpg
augier is offline   Reply With Quote
Old 01-13-2009, 03:05 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Go to:
|| REESE PRODUCTS ||
There are a number of bolt on Reese hitches that can be installed without welding if you got to the product selector. I took a look at S-10 pickups and found four that might work, unless you've modded out the rear end somehow.
That trailer, particularly empty should pose little issue in it's current state, but long term, I'd want a frame mounted hitch, and sway control.
Old 01-13-2009, 04:03 PM   #3
1963 24' Tradewind
San Diego , California
augier: now that it's home the fun begins. Hope all goes well with the restoration of your new "60" Safari there in sunny Carlsbad Ca. It's nice to work on them year round. I know it has to be 80 in Carlsbad today or close to it.
Good Luck !!
Sixty3TW4US is offline   Reply With Quote
Old 01-13-2009, 04:08 PM   #4
Kevin245's Avatar
It looks like the load on your S-10 was fairly light. Other than breaking several DOT regs it looks like your bumper handled the load well. But if you were in a panic stop situation...It would'nt be pretty. Get the TV and hitch situation straightened out, then add some safety chains and break-away setup before hitting the road agian. It will give you piece of mind and save you from a potentially expensive ticket, or an at-fault accident.
I had someone cut in front of me many years ago when I was coming into a toll booth on I-95. The pavment was wet and the trailer brakes did not actuate (company rig) because the brake connection wire broke inside the pigtail. I slide for what seemed to be an eternity and barely missed the jerk that was jockeying for the shorter line.
I did pinstripe the driver seat a lovely shade of Brown though.
William C. Swinney
Old 01-13-2009, 05:07 PM   #5
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Good to see an older fella receiving some TLC. Good luck on your project.
94Tri is offline   Reply With Quote
Old 01-13-2009, 05:47 PM   #6
Road Ruler's Avatar
Images: 38
Well you now know what we all know..........
distance from the bumper safari 28 Hitches, Couplers & Balls 18 02-12-2008 05:25 PM
69 bumper tracker Bumpers & Bumper Storage 1 06-11-2007 06:59 PM
How to clean up bumper yukionna Bumpers & Bumper Storage 6 06-28-2004 11:55 AM
rear bumper harlanghoffman@sbcgl Bumpers & Bumper Storage 4 09-17-2003 06:07 PM
Bumper dents rfield54 1997 - 2004 Bambi 0 09-03-2003 10:46 AM
