Old 06-26-2007, 11:56 PM   #1
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Well, its DEAD!
Sigh -
My 1st major problem with the TV happened today....
Left the house on errands with all 3 kids in the Burb... No AS. Drove into town (17 miles) with all running well as usual... Get to town, make a quick stop to run into a store - left it running with the kids in it (watching a video) and come out to find a stalled vehicle. Just quit.
Cranked, but no catch, no start, nada.
Added fuel just to be ABSOLUTELY CERTAIN it wasn't outta gas... it wasn't.
Tow truck driver, after getting outta his rig, said... '80 to 90K, cranks but won't start...?" Yup. 'Fuel pump!'
Checked the VIN as he explained that the Mexican made (VIN starts with a 3XXX...) seem to have a bit of a history of this.... Dealer says $700-800 bucks.... Yeah right! Local place will get it up and back to tip top condition for 1/2 that....
Getting the rotors resurfaced, new pads and such while it's there....
Guessing at $800 total... we'll see....
Anyone else know of this 'fuel pump' issue with Chevys????
SilverToy is offline   Reply With Quote
Old 06-27-2007, 01:08 AM   #2
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
My 2000 Yukon/XL needed a fuel pump at ~150,000 miles.
1984 310 Limited Motorhome
guy99 is online now   Reply With Quote
Old 06-27-2007, 06:37 AM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Though not a Suburban, my '96 Impala SS needed a new fuel pump too. Folks say that since the pump is in the tank that the tank should never be let run dry or near empty as the gas actually cools the pump. Seemed like snake oil to me, but since never getting far below 1/4 tank, I've never had the issue surface again...maybe just by chance, I don't know.
Old 06-27-2007, 06:37 AM   #4
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I would not assume that it was a fuel pump untill it has been fully checked out by a quilified mechanic.
Old 06-27-2007, 07:08 AM   #5
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I had a similar dilemma with my 2001 2500 Suburban about 2 years ago. We were in Orlando on a trip when the fuel pump went out at 140,000 miles. We had the repair/pump replacement done at a local shop vs. the Chevrolet Dealer and saved about $150.00 over the dealer. Smart move---NOT! The new fuel pump turned out to be bad out of the box. About two weeks later, after we returned to Santa Rosa Beach (400+ miles from Orlando), the fuel pump went out again. The local shop waranteed their work and the part, but I would have to return to Orlando to have it replaced. Obviously, this was out of the question. I had the Suburban towed to the Chevrolet Dealer in Fort Walton Beach, and had the fuel pump replaced again.
This incident taught me a costly lesson. If you do any amount of traveling, have expensive repairs done by the dealer. If I had had the fuel pump replaced at the dealer in Orlando, the dealer in Fort walton Beach would have replaced it under the GM repair warranty. That $150.00 I saved ended up costing me over $1,200.00
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 06-27-2007, 07:20 AM   #6
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
The Mexican Connection
Mexican-produced light trucks of that era had an issue with the sending unit/fuel pump. The fix is to replace both, which comes as a "module". The other problem is the gauge stops registering.
It is no old wive's tale about the fuel level. Even my old Ford owner's manual advised me rather strongly not to let the level drop below 1/4 tank, as the pump is immersed in fuel, which does keep the pump motor cool.
Since the truck stopped running, I would have it checked over, rather than just assuming the pump is bad. You know what happens when you assume.
Since you were having problems on the way in to town to begin with, you may have other issues.
Change is inevitable, except from a vending machine
AIR#2611
Old 06-27-2007, 07:26 AM   #7
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Originally Posted by SilverToy
Sigh -
Had the same thing happen. Only mine did not stall, but rather refused to start at times. A sharp rap on the bottom of the tank fixed the problem temporarily, got me going again about 10 or so times.
I found an OE pump and strainer assembly, and was able to replace the pump only, re-used the old bracket and sending unit.
In my case, I was able to drive the truck intl the tank was almost empty, making the job of dropping the tank somewhat easier.
I have not had a running problem since.
Uwe
Old 06-27-2007, 07:36 AM   #8
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Well, its DEAD!
I too, have had the inevitable dead fuel pump on both my Suburban ('99 K2500/7400 VORTEC) and my father's S-10 Blazer Tahoe ('94 4.2 Liter V6).
With the Suburban, the pump gave ample warning that it was failing; but I didn't properly interpret the warnings -- unpredictable stumbling at highway speeds -- something that it hadn't done before, but did for about two weeks prior to the failure. At the time of the failure, the truck was 8 years old and had 166,000 miles on the odometer; and at my mechanics suggestion, I had never run the vehcile to less than 1/4 tank of fuel.
My father's '94 S-10 experienced its pump failure at 129,000 miles. With his truck, the fuel level rarely was permitted to fall below 1/2-tank. His truck displayed the same unpredicatable stumbling at highway speed that my Suburban did -- he asked me to drive it and I thought it was acting just like my Suburban, and headed to the Chevrolet garage -- made to within two blocks of the garage before the pump quit.
In both cases, the pump replacement was approximately $750.00 at a Chevrolet dealership. The new pump in my Suburban has been trouble free from the beginning and the truck now has 183,000 miles on the odometer. My father didn't have quite as good of luck with his S-10 -- the first replacement pump lasted about two months and 2,500 miles while the second replacement pump lasted about three months and 4,000 miles -- it is going strong with the third replacement pump and now has 146,000 miles. The defective pumps were both replaced by the Chevrolet dealer at no additional charge -- the dealer even paid for the towing.
Kevin
Kevin D. Allen
AIR #827
Old 06-27-2007, 07:38 AM   #9
Streamin 65
Streamin 65's Avatar
Profile:  1965 26' Overlander
Marysville , Ohio
Images: 14
I've had some problems too..!
My '97 Chevy 1500 truck is on it's 3rd! The factory one gave up the ghost within a week of purchasing the truck (used) @ 50k miles. Just wouldn't start one morning. Dealer replaced at no charge. The next one went out @ about 100k miles. It cost me $325 plus $50 for a tow. Again, no warning signs, it just stalled at an intersection and wouldn't start. Good thing I was in town when it happened! The truck is now at about 160k and I'm wondering if (when?) it'll fail again! After fixing the last pump, I was also told to keep it above 1/4 tank and it'll prolong the pump life. To determine if the fuel pump is bad, I simply poured a small amount of gas (a capful or so) down the intake. It would start and run for a few seconds, then stall. Sometimes I miss the old mechanical pumps, they cost about $15 and could be changed out in 1/2 hour by me with a few basic hand tools. --dave
Streamin 65 is online now   Reply With Quote
Old 06-27-2007, 09:49 AM   #10
uwe
418
uwe's Avatar
Images: 40
Makes me want to put a spare one in the tool bag. I don't want to be stranded without pars in the middle of nowhere with my Airstream on teh hitch. Plus, I run my tank low all the time, not out, but low. Definitely below 1/4 tank.
Uwe
Old 06-27-2007, 10:01 AM   #11
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Huh?
Uwe,
I thought it was Goin camping who drove a tank?????
John
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 06-27-2007, 10:07 AM   #12
overlander63
Images: 58
Originally Posted by TIMEMACHINE
Uwe,
John
But he doesn't tow his Airstream with it. He can't find the correct WD equipment.
AIR#2611
Old 06-27-2007, 10:12 AM   #13
uwe
418
uwe's Avatar
Images: 40
Uwe,
John
Tank, Shmank.....
Uwe
Old 06-27-2007, 11:05 AM   #14
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Our friends jettisoned their 2001 Yukon for the same reason. Family of four, wife stranded for the FOURTH time... new fuel pumps every 10 months or so....
They too were told not to run the tank low, but come on, that's why the fuel's there! Ok, off soapbox.
Good luck.
Marc
dead battery-revisited PeterH-79MH Airstream Motorhome Forums 41 12-12-2002 06:38 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
help dead short pk63 Batteries, Univolts, Converters & Inverters 6 05-29-2002 08:56 AM
