03-04-2004, 08:33 AM
trans flush - your opinion
2004 2500 Suburban with 5,300 miles.
Thinking about having the transmission flushed as a preventative maintenance step.
What is your opinion?
Dave S.
03-04-2004, 08:45 AM
The fluid can be cooked by a single instance of over-heating, perhaps when backing a trailer at an angle into a campsite. I always change the fluid on a vehicle I buy used, but after that I check by color (bright red is good, brown is bad, for the fluid I use), and smell (cooked fluid is acrid). I then take out the dipstick and let a drop of the fluid fall onto a piece of clean white tissue paper. After a few minutes, the stain should be an even pink color. If there are rings of different color, with a dark ring on the outside, the fluid is burnt, and must be replaced immediately. This technique is used in chemistry laboratories to analyse mixtures of chemicals, and is known as paper chromatography. I fit a temperature sensor to the output fluid line from the tranny and attach this to a temperature gauge under the dash. I keep the temperature below 200 degrees at all times, and change fluid at the recommended intervals for towing vehicles as in the manufacturers book. Fluid is cheap, trannies are expensive. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
03-04-2004, 08:50 AM
Thanks Nick,
That sounds like good advice. My suburban has a built-in trans temp gague and i wil keep my eye on that.
What about other contanimates which might result from initial break-in and towing on a new unit? Any concerns there?
Dave S.
03-04-2004, 08:56 AM
2004 28' Classic
huntsville
, Alabama
nick has the right idea. i would do the paper test and determine if the fluid needed to be changed. or for peace of mind change it . if you do it your self it is only $20. if you get Mr good wrench it is about $100.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
03-04-2004, 08:58 AM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
I am in for a lesson
Seems we have some good experience here today,
I have heard many horror strories on changing tranny fluid, of course they are stories.
Can anyone dispell the myths. I have heard of people pulling into tranny shops for a fluid change and the vehicle never moves again or does not last long after the fluid change. Any truth to these stories?
Smily
03-04-2004, 09:13 AM
Ken,
I have heard of such stories also. One of the reasons i am interested in getting a broad range of opinions/experiences/
Dave S.
03-04-2004, 09:23 AM
1967 26' Overlander
Huntsville
, Alabama
Here's one story
Years ago, a buddy of mine worked in quick oil change type of place. Management's rule was that if a vehicle had over 50,000 miles, and the transmission oil had never been changed, they would strongly recommend against changing it.
Their explanation was that crud builds up in the transmission after the detergent additives in the oil wear out. Replacing the oil had a tendency to clean the insides with its new batch of detergents. Sometimes it would result simple leaks. Other times, it seems the crud was holding something internally in the proper position. Once the crud was dissolved, the transmission would not work right.
I found it believable. If nothing else, management thought strongly enough about it to lose a sale.
Tom
03-04-2004, 09:40 AM
2004 30' Classic Slideout
Fenton
, Missouri
I have had this done on multiple vehicles and for all intents its preventative maintenance. Now the real issue is how do you change the fluid.
One theory is to drop the pan and replace the filter while draining the oil. The positive on this is that you get a good picture of the state of the transmission, metal shavings etc., and you are dealing with a clean filter. I have used this method.
The negative is that this method will not change all the fluid since some is still trapped within the transmission. The defense most shops give you is that they clean the pan, replace the filter, and that what oil is left in has minor effect once new oil is added.
The other theory is to do a fluid exchange which I also have had done. In this case they open up a line going into your transmission cooler and while the engine is running the extract the transmission oil and inject new oil. The positive on this method is that they can completely change the oil, although I'm not sure how they can do make this statement since new oil will mingle with the old.
The negative is that you have not dropped the pan to check the condition of the transmission and you have not changed the filter or cleaned the pan. The defense on this method is that transmissions filters don't get cloged like oil filters do, and that any large debris are held by the filter, and that stuff in suspension is removed in the exchange process.
So that's my take on the process. Bottom line you need to perform this maintenance. I'll change it either by color or by towing conditions.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-04-2004, 10:21 AM
1967 26' Overlander
Huntsville
, Alabama
Torque converter
If you are going to change the oil yourself, remember the torque converter holds a lot of oil (like maybe half of the total volume?) that I believe stays in place when the engine is off. Some torque converters have a drain plug you can remove to get the oil out.
Click and Clack of CarTalk fame seemed to think highly of the machine flush (open a line) system on one episode. As I recall, most of the old oil is removed, and replaced with some sort of flushing compound. Then that is removed, and replaced with new oil.
03-04-2004, 10:29 AM
Cartoon Character
2004 34' Classic
On The Road
, U.S.A.
When it comes time to changing the trans fluid ... I'll be going to the Ford dealer. My TorqShift uses a new type of fluid that I can't find anywhere ... plus the dealer has a special "sucking device" to extract the fluid trapped in the trans ... and the money in my wallet.
I don't know about the GM trucks .. but the trans temp gauge on the Ford is useless .. so I installed the X-Monitor on my a-pillar to track my pyro, boost and trans with an easy to read digital display. You can also set alarms for each and check your peaks after a run. So far so good ... the trans has remained below 200 at all times.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
03-04-2004, 12:36 PM
1999 34' Limited
2002 19' Bambi
Allen
MERCON V fluid
Porky,
Bet your Ford tranny calls for Mercon V, which is a pure sythetic fluid made specifically to Ford standards. This stuff is not all that difficult to find, but you do have to look OR ask specifically that Mercon V be used. There are even "upgrade" fluids that claim to make other transmission fluids meet the MERCON V standard, but I am question how Ford would respond if such had been used vs true MERCON V.
I had my tranny fluid exchanged at about 20K miles as the factory fluid seemed to be just a bit off in color. No unusual odor or banding when dropped onto paper, but not quite that nice pink. My local lube shop did the fluid exchange using almost twice the total fluid capacity of the transmission, just to make sure that they got all the old fluid out. I also added a thermostatic, electric fan cooled Hayden Transcool in addition to the original factory unit. This way, I have good transmission cooling even in slow forward speeds. The fluid first goes thru the radiator cooler, then the factory external and finally thru the Hayden before returning back to the transmission. The thermostat on the Hayden fan is controlled by the temp on the return tube after the Hayden, so as to preclude it running when not needed.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
03-04-2004, 01:10 PM
Cartoon Character
2004 34' Classic
On The Road
, U.S.A.
Re: MERCON V fluid
Originally posted by dtbw
Porky,
I wish it was Mercon V ... for the TorqShift the correct fluid to use is Mercon SP. So far ... only available through Ford Dealers ... but this will hopefully change in the future.
Porky
TrailerGypsies.com
-- Willie Dixon
03-04-2004, 02:42 PM
1996 28' Excella
Okemos
, Michigan
Don't do it in the driveway.....
At first glance it seems easy to drop the pan by crawling under the truck, but unless you love the smell of tranny fluid, have someone else do it. You will wind up drenched with fluid. Then comes the fun of scraping off the old gasket.....
It's worth the money to have Mr. Goodwrench get wet.
03-04-2004, 03:01 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
trans fulsh - your opinion
I have followed the general rule of having my transmission fluid and filter changed every 30,000 miles for a number of years. My current Suburban (1999 K2500) has been treated to a complete flush and new filter at the GM dealership every 30,000 miles since it was new; at 124,000 miles, all is well and the transmission behaves just as it did when the truck was new. The same maintenance schedule has been applied to my Cadillac since I purchased it in 1995 at 95,000 miles - - it will be due for its second servicing since I purchased it this summer (currently has 122,000 miles) -- my GM dealer also handles its maintenance and has used the flush and new filter process for it as well. Thus far, I haven't had any transmission failures or repairs beyond this regular service routine - - before starting this routine, the transmission in my '71 Buick Sportwagon failed at 49,000 miles.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
03-04-2004, 03:04 PM
Fenton
, Missouri
Kevin, the key thing I'm looking at is the word "flush". Has your GM dealer explained the process that they use for you? Have they offered you synthetic trans fluid as an option?
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-04-2004, 03:11 PM
Moderator Emeritus
1964 26' Overlander
Anna
Greetings Jack!
Yes, I am aware of the exact process (I have actually watched the entire process through their observation port in the customer lounge) that they utilize on the flush and filter change; in fact I do pay a premium for the service as it combines the two processes typically discussed as follows:
1. Vehicle is placed on transmission flushing apparatus and the cycle is run according to their usual procedures.
2. The pan is then removed and the filter is replaced. New gasket is installed and pan reattached. The transmission is then topped-off with fluid.
If my memory is correct, I believe that the flush portion of the operation runs just under $70.00; while the filter replacement part of the service runs about $90.00. The last time I had this service performed was at 120,000 miles on the Suburban, and the total bill that included an oil change and fuel injector cleaning was just short of $270.00.
I am planning to keep the Suburban until it has at least 300,000 miles so it is treated to excess service. On the Cadillac, they just performed the first part of the process the first time I had the transmission serviced - - I don't know whether I will have the two-part process on the Cadillac this summer or if I'll just continue with step one only.
Kevin
Kevin D. Allen
AIR #827
03-04-2004, 03:34 PM
Fenton
, Missouri
For what transmissions cost, and with the questionable results of repairs or remanufactured transmissions, it probably makes sense to pony up and do it the way you described. When these things fail on the road you are really up a creek.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-04-2004, 03:40 PM
Retired.
, At Large
Re: I am in for a lesson
Smily
Did a complete trans service on my Dakota, went to the mountains towing the trailer, came back and the trans died a horrible death in a total of about 3,000 miles after service. I don't think that was a contributing factor, though. It had never had a sevice done on it, and when I bought it, I serviced it. Transmissions should have their fluid changed about every 15,000 miles, or more frequently while dragging our aluminum houses around.
03-04-2004, 08:38 PM
1986 25' Sovereign
Southern Middle
, Tennessee
This is part of the reason I bought my 2500hd with the Allison transmission. The external filter can be changed whenever you want (changed mine around 26,000 miles) and will change again around35,000 to 40,000 when I change over to synthetic ATF Amsoil.
If I was running a 4 sp. auto transmission, I would probably change filter and fluid no longer than every 35,000 miles but would have to base this on how close to max trailer weight I was towing and the towing terrain. If I was towing many of these miles and it was through mountainous terrain I would probably change out every 25,000 miles. Filters are the life blood of any engine/transmission and heat will destroy a transmission in a heartbeat. For this reason I would also run synthetic ATF and change according to the manufacturer's suggestion or earlier.
Flush or not? If you have the money and you know the dealer does it right then I would probably do that. I don't have the extra money so would change often, no flush and let the new and old fluids get acquainted.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
03-04-2004, 10:32 PM
trans fluid change
Kevin is correct in the way he has his transmission serviced. The best way to service your trans is the 2 step process of flushing the system then dropping pan for inspection and filter change. Just doing the flush will replace all fluids but cannot completely clean the filter. Dropping the pan without flushing doesn't replace all the fluids even if (like fords) the torque converter has a drain plug. It is strongly recommended to use the correct factory fluids rather than market brand fluids, factory fluids contain additives especially design for the vehicle.
I own a shop and have done tranny services for over 12 years. I have serviced vehicles for the first time that had over 100k miles and had no problems with them. However I do tell the customer they may experience trouble because of the mileage. Because, yes over time the build up a 'crud' maybe all that's keeping the tranny together anymore.
Bottom line, trans should be serviced every 15,000 miles under severe conditions or 30,000 under normal driving conditions. (severe would be towing) No matter what your owers manual states as recommended mileage. (after all the manufacturer doesn't want it to last for ever, they want to sell you a new vehicle) The fluid breaks down and the filters get blocked. The more you maintain your trans the longer it will last. With proper maintance transmissions will last well over 250k miles. Make sure you have an external trans cooler (of adequate size) and a good temp gauge.
Lastly, if you had to choose between a flush or dropping the pan method, if you service on a regular basis then dropping the pan is the better choice to make. Hope this helps.
whistler
Disclaimer: I did not write this because I'm in the business, it's just the smart thing to do. (besides I can make more $ putting in new transmissons!!!!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Allison trans?
poqn2slots |
Mechanics Corner - Engines, Transmission & More... |
1 |
09-02-2006 11:13 PM |
Auto trans help
Nick Danger |
13 |
09-20-2004 03:59 PM |
Trans Yoke Loosening Up
swebster |
26 |
06-02-2004 08:17 AM |
Trans-continental trip
winner |
On The Road... |
6 |
10-27-2002 08:49 AM |
Trans service
ALANSD |
8 |
08-30-2002 12:24 PM |
