11-30-2008, 08:09 AM
#21
Aluminut
2004 25' Safari
Originally Posted by REDNAX
I, too, was a 20-yr owner of that car designed by GM as a fleet -- not police -- car and introduced in 1976 as a 1977 model. My Impala wagon had over 240,000 miles on it when sold, but that does not mean that ANY car (or truck) that is this age is not in need of a thorough going through. It is in need of it no matter who owned or how it was used. Age is age, and the make or model of the car is almost irrelevant. Age, time, takes its toll.
And, no, the final iteration of the car was not more reliable. Electrical small parts are notoriously unreliable in this line of cars in the final version. Etc.
But whether 13 or 17 years old, every system NEEDS to be gone through, as NOTHING is tougher on a vehicle than towing. (I would pay especial attention, mechanically, to the rear axle so that if it is questionable a junkyard piece can be procured for rebuilding as GM ball-bearing, semi-floating axles wear too quickly).
Note that nothing I recommended is "major" rebuilding. It may be laborious, but it does not include going through engine, transmission or the various major wiring harnesses (those are the "major" systems). It is a recommendation to search out the weak links in any system, and to go after -- immediately -- the two most often ignored by new owners of an old car: the cooling system (I would replace the whole of it, and then some) and the rubber bushings of the suspension and body mounts.
I would replace the steering pump, gearbox and other components as well, but most folks will not so I don't bother to recommend it.
To add to it, the air-conditioning system is most often in need of a complete re-build after 6-7 years on any car or truck, and, unfortunately, is the place most second and third owners "gimmick" a proper fix.
Of course, if the towing is easy and not too far from home, then none of this may make a difference.
This isn't exactly true. The 9C1 and 9C6 versions were specifically police and taxi versions of this civilian base. Since the late 70s, the B body has been a police and taxi vehicle, built to even more stout specs than the civi versions. This platform was chosen for 9C1 and 9C6 specifically due to it's 1/2 ton like similarities. Adding a bit more toys to it made it even more useful to the non-civi owners (police, taxi).
Yes, I fully agree any old car would need some work and some inspection, but if properly maintained, there is no way you need to replace body mount bushings, etc. And I will again have to respectfully disagree with you that the 1996 versions are the best versions of this platform out there, even better than the 95s. Of course if you compare the B to something else, perhaps you may be right, but sticking strictly B or D, the 96 was the machine to have. In addition, the same parts found in B and D could be found in other GM truck and car platforms, so anything you say about B or D could be true of any GM vehicle since GM did not make electrical connectors, A/C compressors, etc only for the B and D platforms.
I would fully agree that some of the components are not the best ones out there, but you also have to keep in mind that we're talking early to mid-90s GM. Few of their cars had super premium components, but again, these cars were offered at a price point. Me, I did do many mods to one of my 96s. The dual exhaust, though stainless was a poor grade stainless, I upgraded when the mufflers rusted out after 6 years here in the rust belt where salt is king of the roads in winter. Also replaced the Auburn limited slip with the Eaton posi. Replaced the front ball joints from the 9/16 to the police package 5/8 ball joints (required new police package front lower control arm). Police package power steering cooler, air dams, etc. I spent maybe and extra $2k on one of my the 96s. None was required, but I felt it worthwhile give I was going to try to tow 6300lbs of Airstream with it. In retrospect, I prob could have done far less or nothing at all and would have been fine, but the German in me, well, you can imagine.
I am not sure what your B put you through, but I have not had any A/C issue with either of my 2 1996s. All factory. My 1980 though did have A/C issues, but then again so did my fathers 1982 and 1991 Mercedes, so that isn't really saying all that much about the B platform. In addition, none of my Bs ever had any electrical connector or electrical issues. The 1980 had nearly 200k on it and only had the fluid in the diff changed once. The axles seals were starting to wear out, but after 25 years and some towing (about 3000lbs), it was pretty much expected.
As for parts, parts can be found ALL over the Internet both 3rd party (in some cases better than OEM) or still factory parts since these cars shared many driveline components with the truck line.
I will caution you that if you get into an accident, body parts, and I mean genuine GM parts are nearly gone if not gone. Most of the aftermarket body parts (fenders, etc) are junk.
In the end, having owned 3 copies of these cars, I can say that if properly maintained, and we're not talking anything more than normal service and wear and tear, these vehicles will more than be up to the tasks you throw at them. Of course any vehicle not maintained, abused and/or neglected, I would agree that major service work and replacements are most likely needed (ball joints, tie rods, wheel bearings, etc), but again, this would be with any vehicle, not just exclusive to a B or D body platform.
11-30-2008, 09:43 AM
#22
lafayette
, Indiana
Thank you for your observations. I have driven old Mercedes for over twenty years and appreciate their engineering and quality. I generally sneer at anything american made but have owned seven suburbans and the later ones especially I found to be very reliable and well built. My current dodge with the cummins has been pretty good overall too. I suspected that these large wagons would be very comparable to the half ton trucks. I generally preferred the 3/4 ton trucks for towing but now a vehicle which is less capable but more fuel effecient makes sense to me.
12-01-2008, 03:32 AM
#23
2019 22' Sport
High River
, Alberta
Originally Posted by t walgamuth
Are you saying you set up a trailer with no leveling devices and use a front drive mini van to tow it with?
Are you saying you know of folks who towed awards with a roadmaster and had unsatisfactory results?
My award is a 30'
I don't believe Andy was saying that. He did say that the Roadmaster would require excessive tension on the weight distributing bars to properly transfer weight to the front tires of the car. I'd guess you'd be looking at 1000 lb bars to properly transfer 50% of less than 500 lbs of hitch weight. And yes, the Award is derived from a European design and they don't design for weight-distributing there. With a short rear overhang vehicle like a Freestar (which has a longer wheelbase than the Roadmaster as well) lighter bars would do the job just fine, and the strain on the trailer frame would be considerably less - and probably acceptable. I would defer to Andy's judgement and 35+ years' experience on exactly what setup to use.
I would personally take the Freestar over the Roadmaster. My main reason would be my observations of the handling of a Roadmaster I rode in about 10 years ago. The very soft suspension created significant understeer and the car was a handful in moderate curves. I consider them basically unsafe. (I tend to tar Crown Vics with the same brush. ) However, the regular B-bodies (LeSabre, Caprice, etc.) were generally OK, and quite good with heavy-duty suspension, i.e. rear sway bar. The best of the bunch were the Impala SSs, like Silvertwinkie's. Great fun to drive, and very stable, except that towing is compromised by that very long (by today's standards) rear overhang and solid rear axle. I test-drove a rear-drive Chrysler 300 a couple of years ago, and its steering and handling reminded me of the Impala SS.
Do you still have an M-B? If so, what model? An E-Class or larger is generally rated for 2000 kg/4400 lbs or more in Europe.
12-01-2008, 04:13 AM
#24
lafayette
, Indiana
I have three 123 bodies. An 82 300cd with a four speed conversion, an 83 240d us with a euro 300d and a five speed, and an 84 euro 280e. They are rated for 3000 with brakes on the trailer. In europe they would probably use one to haul the award for sure.
As for the buick, with the light hitch weight and all I cannot see how tough it would be to tow a 4200# trailer. I might want some stiffer springs in the back. You wold not need to transfer all that much weight to the front....whatever worked for a minivan would surely work on a rear driver.
I cannot imagine towing something so large with a front drive minivan. That seems dangerous to me.
The Buick weighs 5500# (can that be right?).
I'll have to go look at the books in my trailer and see what it says about the hitch. It has a knob on the side for an anti sway device.
I was hoping to use the cam style lever hitch that I used with my big excella. That thing was the berries!
12-01-2008, 07:15 AM
#25
St. Catharines
, South Western Ontario
Good day walgamuth.. I too had a big 450 SEL Mercedes way back in the late 70's. Very stable, precise , and rock solid vehicle. I could never go back to the soft mushy feel of the large domestic vehicles after that ride.
I also have experience towing a 4,500lb Airstream with a Nissan mini van. It was surprisingly very stable and relaxing when towing. Worked great for us for many years with the mechanics being reliable and dependable.
The big Buick wagon would have about the same wheel base to overhang ratio as one of those old Ford Explorer SUV's and we know how sketchy those vehicles were for towing. Sure they could be made to work for towing but with a number of mods and set up by towing pro's.
I think if you were to do and A-B comparison between the Roadmaster and the Freestar set up to tow your Award you would quickly realize the huge advantage of the Freestar in handling and control.
12-01-2008, 10:23 AM
#26
2019 22' Sport
High River
, Alberta
The Roadmaster would have plenty of power - that's not an issue. The real issue is whether the car would be stable enough to be safe and comfortable. More tension on a weight distributing hitch would be needed to effect weight transfer to the front tires with a Roadmaster because it has a much longer overhang than a Freestar.
5500 lbs is probably the Gross Vehicle Weight Rating of the Roadmaster. I'd expect a curb weight of 4200 to 4300 lbs - a 1200 to 1300 lb payload capacity makes sense. I can't remember exact numbers, but a Freestar has a similar curb weight and about 300 lbs more payload capacity.
Cam style lever hitch? If it is a Reese dual cam, the hitch weight of the Award may not be sufficient to make it work. A friction sway control (or a pair of them) might be the best option, especially if you decide not to use a weight distributing hitch.
You might PM Andrew T about the merits of using one of your existing cars. He has set them up in the past. (There's an interesting photo of a W140 with a 34' Airstream on his website.) If the 300D is a turbo (I'm guessing it is), torque would be quite sufficient. The 280e should be adequate for an aerodynamic trailer as well. The 240D would obviously not have the horsepower to overcome the aero drag of a full height trailer.
12-01-2008, 04:40 PM
#28
lafayette
, Indiana
All of my benzes are 123 body style and rated only for 3000# for a trailer with brakes. Surely you aren't suggesting my benzes are more appropriate to tow my 30' Award with than a Roadmaster.
I fail to see how a leveling hitch would require more tension on a vehicle with a long overhang. In this case the leveling bars are prying against the front wheels as the fulcrum. Side to side motion would be more with a long overhang though, I see that.
I towed for a couple of decades with a friction anti sway device and I do not have a very high opinion of them. On my 29' avion I had two and to stop the swaying I had them clamped down so hard they started peeling off the edges of the device.
I am not interested in buying a relatively new mini van to use to tow my trailer. I can see if you want a dual purpose vehicle and will not be taking long trips that a mini van would be a good choice, but front drive especially with towing is not my cup of tea.
I am looking for an inexpensive tow dedicated vehicle, and I see my choices as one of these behemouth wagons or an older diesel pickup or suburban. I think I see that I can buy a lot nicer condition wagon for my money than pickup.
I do appreciate all the suggestions. I think that there is a whole different philosophy in the great white north about vehicles in general. Smaller is better, unlike our gas guzzling over consuming Yank attitudes.
I will never forget seeing a canadian towing about a 40' fifth wheel with a half ton ford. The single tires on that little truck were looking very worried to me, but he assured me that it towed the humongous trailer like jewel.
12-01-2008, 04:52 PM
#29
Retired.
, At Large
If you decide on getting a wagon (though I'd try to keep the truck), probably the single best upgrade is to switch to the 3.73 gears in the rear end. It would only make about 1 mpg difference in fuel mileage, but a world of difference towing.
12-01-2008, 09:02 PM
#30
lafayette
, Indiana
Well, I will keep that in mind. I will try it out first to see how it feels to me.
Thanks for all the comments and observations! I have learned a lot, especially about the Award TT.
12-01-2008, 09:46 PM
#31
2019 22' Sport
High River
, Alberta
1. On reflection, I think I'd be more comfortable with a W124, or maybe a 126. Suspension advances and lower profile tires would make a difference. Also, the 3 litre and larger engines would perform better.
2. I see your point, and I had go check out some old posts at the Open Roads Forum to come up with a response. The fulcrum is really the rear axle, and the WDH bars are removing tongue weight from the rear axle and moving it to the front. A longer rear overhang amplifies the tongue weight, and more tension is required to remove it. You want weight on the front tires to restore steering feel and stability, and to force the front tires to do their share in resisting trailer yaw (sway). Very small adjustments in tension can make significant differences in how a combination performs. Also, you generally want more tension with a car or SUV than with a pickup, since a pickup is designed to carry a significant load and will normally handle and ride better with some additional weight on the rear axle.
3. I would respectfully suggest that if you had the friction bars clamped down that tight, your hitch setup needed more work. I use a pair of friction bars as insurance, not to achieve stability. On winding roads at speeds of less than 50 mph or so, I actually back the friction bars off a turn so the car's steering will return normally. Winding roads are very enjoyable that way.
4. If you are prepared to spend the money for a dedicated tow vehicle, a 1500 series Suburban is probably your best bet. Set up will be very easy, with off the shelf parts, no custom fabrication required. Towing fuel economy will be similar to the Roadmaster.
5. There is more to an effective tow vehicle than size and weight.
12-02-2008, 04:44 AM
#32
lafayette
, Indiana
Thanks for your thoughts.
The 124 and 126 are both rated for 3000# towing with a braked trailer, IIRC. I have owned several of both models, and while they might work, I would not want to use them for towing a nearly 5000# trailer loaded.
While I agree with you that the long tail will make the vehicle more sway prone, I disagree that with leveling bars the rear wheels are the fulcrum. The rear of the car is the load being lifted, the front is the fulcrum. Draw your lever and place your load. The front gains weight by lifting and removing weight from the rear. (It will put more load on the trailer wheels too while you are at it).
I agree that a 1500 sub would be fine.
I have towed with saab, volvo wagon, 1500 subs, 2500 subs, one ton ford van, and my 2500 dodge....with straight load only hitches, and with leveling bars, friction anti sway devices and the reese cam style hitch with anti sway built in. I am looking to buy an inexpensive vehicle to tow my camper and my utility trailer with my autocross car on it. I am probably going to give the buick a whirl. I have found one with 92K miles on it for $2500 and if it doesn't work out as well as I think, I am not out much.
I don't think I will be in any hurry to sell the dodge though. It really is the ideal tow vehicle in so many ways. I am looking at eleminating the payment though at the present.
I really hate the fake wood on the side though!
12-02-2008, 10:58 AM
#33
2019 22' Sport
High River
, Alberta
I see your point about the fulcrum. I think there's more than one pivot, though. Weight distribution is a fairly complex topic. Here's a link that can provide many hours of interesting reading, if you're so inclined:
RV.Net Open Roads Forum: Towing: Weight Distribution (WD) Hitch --- How it Works
I would have expected a somewhat higher tow rating for the 123 bodies. Even a new C-Class has a tow rating of 4000 lbs, and an E-Class 4200 to 4400. These are fairly heavy duty tow cars in Europe. Of course, these are EU ratings, not affected by US litigation or warranty concerns.
You mentioned you have an autocross car too. So you have the skills to make the Buick handle properly if you put some thought and money into it. I wish you success with your Buick "Woody"!
12-02-2008, 06:34 PM
#34
lafayette
, Indiana
Thanks. The fulcrum thing is complicated. When using a straight bumper hitch with no load leveling devices the rear wheels would be the fulcrum. When it comes to sway the rear wheels are the fulcrum too. I will take a gander at the above site.
Thanks again.
This evening I spotted a 94 chevy wagon at a neaby town on a small lot. It looks like it should be about the right price and it already has the spun aluminum moon wheel covers! Now all I need is a set of mooneyes for the rear window!
Oh and it doesn't have any fake wood!
12-02-2008, 07:41 PM
#35
1975 Argosy 24
Collierville
, Tennessee
I have a 96 Roadmaster Estate Wagon and I love it. All you have to do to take care of the marshmallow suspension on some roadie models is take off the stock dynaride suspension and put Monroe severe service on and suddenly you have a pretty doggone good handling behemoth. One other thing that wasn't mentioned that lends the roadie to be a good tow vehicle is the low center of gravity.
Check out the Buick Roadmaster forum and you can get any info you need, there are a few people on there that tow with a roadie. One guy tows a 30' AS with his roadie sedan.
You could also look for a caprice wagon of same vintage, the roadie, caprice and I believe Deville are all the same. You can't beat that LT1 motor. 2500.00 hundred is a very good deal for one w/92,000 miles as long as all else is okay. Have fun.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
12-02-2008, 08:48 PM
#36
lafayette
, Indiana
thanks very much! I'll check out the roadmaster forum.
12-03-2008, 03:48 AM
#37
lafayette
, Indiana
Are you speaking of monroe springs or is that just a shock package?
12-03-2008, 02:10 PM
#38
1959 18' "Footer"
1964 26' Overlander
birmingham
, Alabama
I too, tow our '64 overlander with a 96 roadmaster wagon. we just returned from our 10th trip with this set up and it performed as well as always.
I usually get right at 10mpg consistently... unless I knock it down to about 60mph and then have gotten as much as 11.5!
We are actually about to relist it for sale if anyone is interested only because we've gotten a full sized van.
I've never had a problem with handling or power or comfort.
Doug
12-04-2008, 09:27 PM
#39
1975 Argosy 24
Collierville
, Tennessee
The Monroe severe service are shocks. You can upgrade the springs by getting a set of the Caprice police package springs, just a stiffer spring the same size.
Heinlein
12-05-2008, 03:46 AM
#40
lafayette
, Indiana
Thanks very much!
