04-01-2014, 12:17 PM
#481
Mineral Bluff
, Georgia
As posted in another thread, here's our SOB rig:
2014 CampLite 21BHS behind a 2011 Ford Flex with the EcoBoost engine and factory receiver.
Andy from CanAm was nice enough to be our guru on equipment selection (I owe him a Mexican dinner!). He recommended the EAZ-Lift Elite with a Husky sway control. As installed:
Bear in mind I have never towed anything larger than a utility trailer. My impressions:
1) At first I honked down the sway control, using the ON-OFF lever, assuming I needed to tighten it all the way for the bottom adjustment to come into play. Towing was fine, but there was a godawful creaking/moaning when turning. Eventually backed off on the ON-OFF lever, and in Knoxville got a BBQ brush and removed the pad material that had transferred to the sliding portion. I backed off to just two turns in from initial contact on the ON-OFF lever and think I found a sweet spot where there's no sway and no noise.
2) I asked the dealer about tire pressures. I had put in the 37 psi recommended for my 20" wheel/tire combination. He said with the low profile tires, that pressure should be fine and I did not adjust it upwards. It felt fine, though I can see the logic of going a little higher to compensate for the tongue weight.
3) As asked in another thread, I'm wondering if drilling another hole in the hitch and moving it about 3" closer to the receiver would be worthwhile.
4) The Flex got around 21 or 22 mpg on the highway going up to IL. First leg with the trailer got 8.4 (!). That was into a 20 to 25 mph headwind. Later legs seemed to settle into about 12 to 12.5 mpg. I used 65 mph as my conservative upper limit.
5) Power was never an issue, and there are some pretty long grades between IL and N GA. Temp gauge never moved with outside temps around 40º.
6) The transmission on the Flex with EcoBoost seems ideal. Regular "D" worked fine on level ground. Putting it into "M" first puts it in "grade assist" which was fine for gently rolling terrain, always keeping the transmission in a slightly lower gear. A few times I went into Manual using the paddle shifters to downshift to fifth for uphills to keep around 2,000 rpm, then shifting to sixth on the downhills for about 1,600 rpm unless lower was needed for braking.
Anyway, I think we done good. First real outing will be at the SpringStream in a couple weeks. Looking forward to meeting a few of you guys and tossing ideas around!
04-01-2014, 12:57 PM
#482
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell
, Lousy-Anna
Your rig looks great!
I have done extensive testing for years regarding tire pressures and the effect of even slight rear end sag on towing and gas mileage.
One of the biggest things I've found regarding drag and its effect on mpg is tire pressure; I feel like I'm pulling a trailer with pillows for tires when tire pressures are lower. I hate that slushy wallowy feel; I like tight, sports-car handling with taut jostles over bumps, not bouncing and flailing. I have definitely learned over the years that this means towing with my trailer tires at their maximum pressure. I have had no trailer damage from doing so, and riding in the trailer in testing indicated that at least the Airstream rides super cushy as it is, even with 80lbs in my Michelin XP Rib tires. Even more important, I have found that my truck pulls easier with less rolling resistance with maximum cold pressure in the truck tires with nothing but benefits regarding the ride; when towing, it's not harsh or rough. Increasing the tire pressure increases the weight carrying ability and reduces heat...as well as reduces again the rolling resistance; you will be AMAZED at the increase in mpg while towing running your tires at maximum on both car and trailer.
I have found that even the slightest bit of rear end sag seems to greatly increase frontal drag when towing with a low profile vehicle (I use a Chevy SSR). Making sure your weight is distributed evenly is imperative not only for handling but also for wind resistance; that slight sag combined with a slight raise on the front of the trailer makes a BIG difference. I see that your Flex is slightly sagging in the rear. It is slight, but it is there. Getting a hitch exactly right is a time-consuming and lengthy process, with a little trial and error thrown in. I "thought" I had mine dialed in a couple times until I finally found the exact combo; I get between 12mpg (towing at 70-75) to 16/17mpg (towing 55-60) pulling my 19ft Bambi with my truck, and it is a 400+hp LS2 V8. The best way to set up a hitch is not only with a truck scale but also with a good old-fashioned yardstick. Ideally you want the same drop front and rear on your tow vehicle, but variables surely exist. I find I get the best mpg and more importantly the best POWER when my wind resistance is reduced and both front and rear axles on my truck drop 1/2"; I have no sag, the truck retains the factory "rake" which seems to reduce the wind buffering effect on the front of the trailer. It seems by your pics that you could use more lift on your hitch to transfer a bit more weight to your front axle; but, you may have to lower your head on the shank if this raises the front of the trailer too high as it already may have a slight tendency for that; any increased lift on the front of the trailer is going to increase that wind resistance. Ideally, everything should be level, with an EQUAL drop on both car axles...and, if anything, a slight dipping of the FRONT of the trailer rather than the rear. But again...you should be able to get the trailer nearly perfectly level with an equal drop front and rear on the tow vehicle.
As you've learned, WIND is your biggest enemy...NOTHING robs power like wind. And, when you combine wind with the devastating effects altitude and ethanol have on horsepower, going up climbs against wind will make you feel like your tow vehicle is broken. And, as you've seen, WIND kills gas mileage more than ANYTHING else. Don't worry about terrible mileage if you're going straight into steady hard wind...it will make a HUUUUUUUUUUUUUGE effect.
Regarding drilling a hole to get your hitch closer to the car...DO IT!!! This makes a HUGE difference in handling and stability. I have all Trailer Life magazines to the early 60's, and they stress this in nearly every issue; the closer the ball to the rear axle, the greater the stability and handling. I don't remember the formula, but there was some sort of exponential thing happening ha ha. You will notice a BIG difference doing this; I couldn't believe it when I drilled mine. My truck actually handles and drives BETTER towing my trailer than the truck alone now...
Hope this helps!
Jeff
04-01-2014, 01:05 PM
#483
Mineral Bluff
, Georgia
Wow! Thanks!!!
Here's another side view showing the slight sag:
Is this the sort of thing one might cure by jacking the rear up a bit more and letting an additional link "hang" - IOW one less link in the chains?
I will almost certainly take your advice on shortening the hitch - I'll let a machine shop handle it to get it right.
04-01-2014, 01:25 PM
#484
1968 22' Safari
The Swamps of Hell
, Lousy-Anna
That's one way of doing it...you may also experiment with angling the hitch head back toward the trailer. However, anything you do to lift the back of the car will also lift the front of the trailer...which is going to make the front of the trailer too high. You might want to start by lowering the head one hole in the shank and going from there. Like I said...it's very time consuming to get it exactly right, but it is very much worth it! Towing with a really well set-up hitch is the difference between worrying the whole way there vs just cruising along with a smile on your face.
04-01-2014, 03:00 PM
#485
St. Catharines
, South Western Ontario
Isn't that the truth!
04-01-2014, 05:01 PM
#486
Mineral Bluff
, Georgia
Great info.
My first project, maybe even tomorrow, will be to shorten the hitch by having another hole drilled.
3" may not sound like much, but its not an insignificant percentage of the distance from the ball to the axle. In addition, I know from Weight and Balance for aircraft that the "arm" that weight works upon makes a big difference - with the shorter arm there should be less "push" on the back of the car, and that can only help.
From there, maybe move the head down one notch before beginning with the sag measurements, then see what effect one less link in the chains make.
I'm unclear how angling the hitch head affects things. Could you explain it "for dummies" or maybe shoot me a link?
Had no idea that something so apparently simple could get so involved!
04-01-2014, 05:24 PM
#487
2013 30' Classic
Greenwood
, Mississippi
Tilting the hitch head backwards causes the weight bars to lift the trailer a little more/transfer a little more weight to the front axle of the tow vehicle.
You are changing the "fulcrum" point for the "lever".
Tilting the hitch head back creates a greater angle where the weight bars are inserted into the hitch head, causing the other end of the weight bar that attaches to the trailer tongue to hang lower, so when you put the chains in the saddles it has a greater effect.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
04-01-2014, 05:33 PM
#488
1968 22' Safari
The Swamps of Hell
, Lousy-Anna
It's very simple...the more you angle the hitch head back (toward the trailer), more weight is transferred to the front axle. If you angle it forward (toward the car), less weight is transferred to the front of the car.
Different hitch heads use different methods to do this; some use washers where you have to dismantle the entire thing every time you want to change the angle, others use a notched system (such as the Husky Centerline, which I use).
Scroll down on these instructions for your hitch to see how to angle and level the hitch, car, and trailer:
http://manuals.adventurerv.net/Eaz-L...structions.pdf
04-01-2014, 05:34 PM
#489
Wallaby Builder
Deggendorf
, Bavaria
Peugeot Partner 90hp/1600 cc Diesel and 1977 Eriba Troll O
This is our fullsize rig.
Car empty weight 1450 kg, tow limit 1100 kg.
Aluminum Trailer weight 700 kg empty and 900 kg max. weight.
Tom from Bavaria
Ford Focus TDCI Pininfarina Convertible and 14' Eriba Troll
Honda ST 1100 and 7' Airstream Calypso
04-01-2014, 07:00 PM
#490
Mineral Bluff
, Georgia
Thanks for the explanation - it's clearer now. I was overlooking the fact that tilting the head tilted the pivot points of the arms as well.
And thanks for the reminder about the instructions. I already have them on my iPad and will review them before messing with anything.
04-01-2014, 10:59 PM
#491
2013 25' FB Flying Cloud
Longmont
Two observations on FastEddieB's rig
FastEddieB,
I also have an EAZLift Elite hitch with Husky friction bars. This is my second WDH, because the first did not give us good results. The second hitch was installed by Can-Am, using my pre-existing shank. Andy T's crew drilled a new hole in the shank, 3 1/4 inches from the original, and cut a couple inches off the back end. Since I was changing the hitch at the same time, I can't say that I noticed any difference in the way the rig handled. But obviously Andy T. thinks it matters.
Second, one thing took me by surprise. When making a tight U turn (going forward), the forward socket of the friction bar gets pinched (and bent) against the coupler of my AS. That's my limit on tight turning, not bumping the corner of the trailer with the corner of my tow vehicle. I suggest you try a U turn or complete 360 with someone watching closely to see what your turning limit is. I think you have a shorter turning circle on your Flex than I have on my TV, and you may have to learn to moderate your turns.
04-02-2014, 04:50 AM
#492
2013 30' Classic
Greenwood
, Mississippi
With one sway control, usually on the right or curb side, you can make a slightly tighter left turn than right turn.
TAC #MS-10
Airforums #70955
04-02-2014, 05:54 AM
#493
Mineral Bluff
, Georgia
Thanks!
When I had to choose left or right for the sway control mounting, it seemed like a toss up and I went with right for no particular reason I can recall.
But if "pinching" is ever a factor, it seems like the right side would be preferred.
Why? Well, the vast majority of tight U-turns are going to be to the left, where the sway control is extended rather than compressed.
But if we do shorten the hitch, I will definitely be cognizant of the potential hazard in hard right turns until we head out to a parking lot to play around.
If it's an issue, I have a tarp bungee in place which could easily support the sway control if I need to jump out and disconnect one end leaving the other in place.
Thanks again.
04-02-2014, 06:12 AM
#494
Mantua
, Ohio
For backing, releasing the sway may be necessary, and is easy to do. Jim
04-02-2014, 06:13 AM
#495
2011 28' International
Chatham
, Ontario
Thanks!
Thanks again.
Following an unfortunate late night incident involving a tight backing up manouevre, an umbilical cord connector and a friction anti-sway bar, I tend to remove the bars before backing into a tight space these days. It only takes a few seconds so it's no big deal, and it allows a slightly tighter turn.
04-02-2014, 06:38 AM
#496
2013 30' Classic
Greenwood
, Mississippi
What he said.
Just remove it before backing in to a camp site or backing in at home.
Another reason I like my Equal-i-zer...
TAC #MS-10
Airforums #70955
04-02-2014, 03:30 PM
#497
Mineral Bluff
, Georgia
Played around just a bit this afternoon, kinda quick and dirty.
I pushed the hitch in all the way and scored where the new hole will go. Probably get it drilled tomorrow. Several inches of clearance remain for the rear hatch.
Measured the bumper height of the Flex, with just a few tools in the back:
Rear: 24 3/8"
Front: 22 3/8"
Hooked up the trailer with the two links hanging.
Remeasured:
Rear: 22 3/4" (1.625" drop)
Front: 22 3/4" (.375" raise)
So that confirms the visible sag seen in the photos.
Tried shortening the chains one link:
Remeasured:
Rear: 23 1/2" (.875" drop)
Front: 22 1/4" (.125" drop)
Car looked a lot flatter than before:
If you look at the level on the tongue, the trailer seems very close to level - maybe a tiny bit nose up.
Note, there was about a 1/2" drop in height from the hangar to the asphalt. Doesn't seem like that should make a huge difference.
Did not change the tilt. It looks fairly straightforward to do so:
That arrangement with the adjusting wheel looks different from the setup shown in the EAZ-Lift installation manual.
Anyway, am I on the right track?
04-02-2014, 04:01 PM
#498
2019 23' International
La Habra
If you can tilt the head, I would do that instead of tighting the chains because you want the bars to flex some so the combination won't ride stiff. If you can lower the ball to the next hole, you might be able to level the trailer or nose down as was suggested earlier.
Good luck and then go weigh the combination.
2019 GMC Sierra Denali
2019 23CB International
04-02-2014, 04:12 PM
#499
1966 26' Overlander
Woodstock
, Georgia
I angled my hitch ball back one more spacer after last weekends experience.The sway bar arrived today, I just have to drill the holes. Two of the hole from the old Reese set up align thankfully.
Been shopping tires, trying to decide which to buy. Goodyear and I have never been friends but I am open to the one Andy T mentioned.
04-02-2014, 04:37 PM
#500
1968 22' Safari
The Swamps of Hell
, Lousy-Anna
Rear: 24 3/8"
Front: 22 3/8"
Remeasured:
Remeasured:
You are on the right track, and I realize you are playing around with it right now and that is how you learn.
***It is of utmost importance that you do all your set-up and measuring on the flattest ground possible. Otherwise, there really is no point...you have to eliminate the variables as much as you can.***
Again, I would have started by lowering the head on the shank and angling it back a little. You do NOT want the trailer high in the front; that is what can cause a deadly sway situation. Anything you do to lift weight off of the rear of the car to the front is going to RAISE the front of the trailer.
Don't be afraid to measure the ground-to-trailer frame at the front and back as well; this will give you a good idea of how level the trailer is. On the Airstream I measure from the ground to the top of the A-frame hitch in the front and from the ground to the top of the frame leading to the bumper in the rear. Eyes can be deceiving. Under no circumstances do you want the front of the trailer higher than the rear.
In the end, you want your spring bars as level as possible to your A-frame; this is what tilting the head does. When you have the right ultimate combo, you will have a nearly level drop on all axles of the car and the trailer will be level (or a TINY amount nose-down) with the spring bars being very close to level with the A-frame.
It's all trial and error...you've gotta keep taking it apart until it's right. But no matter what, you have to lower the shank one hole and make up for it with angling the head and adjusting the chains accordingly.
It WILL be worth it.
