11-09-2013, 05:52 PM
#21
1968 26' Overlander
Grants Pass
, Oregon
I would not use anything other than DuraFlap mud flaps.
Mine are 7" off the ground. When I back up I do not need to worry about backing up against a parking guard, but when I am towing, they completely protect my trailer.
I tried the style on my hitch, and it threw more rocks up than it stopped. It was a pain to find somewhere to store it. When I set it on the ground the mud flaps curled, so then I had to take up wall space.
10-13-2016, 12:19 PM
#22
1973 31' Sovereign
Chaska
Rock Tamers for a '16 RAM
I have a 2016 RAM ecodiesel as a tow vehicle for our '73 31' AS. This is our first summer with it and I've noticed (newbie mistake) that some dings are showing up on the front...I need some Rock Tamers (or equivalent) to stop the rocks from hitting her!
Here's my problem...the '16 RAM has dual exhaust, I'm concerned the exhaust (especially from a diesel) will melt the rubber of the rock tamers?
Does anyone have experience with this? The Rock Tamers seem adjustable enough that I could adjust the arms down so the exhaust would go over the Rock Tamers. Anyone done this?
Thanks for your advice.
10-13-2016, 02:20 PM
#23
Oswego
If you can see the tires while standing behind the truck...from any height, the rocks WILL see your AS at some level.
This is how I cured the heat problem, including diesel DPF regeneration heat. Mods specific to your application would be necessary.
-Rich-
10-13-2016, 03:46 PM
#24
2016 30' Classic
The Beautiful Mountains Of Southwest
, Virginia
I like my Rock Tamers. The only problem that I have is that above 70 MPH, they straighten out behind the truck. I am trying to come up with some way of making them anti-sail, without ruining their looks? If you drive "slow" then they work fine.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
10-13-2016, 03:52 PM
#25
2020 Classic 33
Box Elder
, South Dakota
RT told me that as long as the flaps are at least 12 inches away from the exhaust you shouldn't have an issue. My GMC Denali damage one and I simply rotated the arms further behind the truck. Problem solved.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
10-13-2016, 05:14 PM
#26
1991 25' Excella
Stanfield
, Oregon
10-13-2016, 08:29 PM
#27
Rich and Kat
Alexandria
Alexandria
, Virginia
Same here! I think they're too flexible. We should contact the manufacturer and provide that feedback ... I can't believe they haven't heard this before ... but the material is simply too flexible (in my humble opinion). That said, they surely help ... but they could definitely be improved via increased rigidity!
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
10-13-2016, 08:47 PM
#28
Oswego
See my mod above. Top half is rigid. Bottom moves little while driving.
-Rich-
10-13-2016, 11:23 PM
#29
2017 25' International
Los Osos
Rock Tamers are $249 with free Amazon Prime shipping. https://www.amazon.com/Rock-Tamers-M.../dp/B006M9VIRM.
I just replaced a front corner plexi window shield that took a rock before I installed the Rock Tamers....... $650 shipped from Airstream via the Airstream dealer.
Easy choice.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
10-14-2016, 06:53 AM
#30
Rich and Kat
Alexandria
Alexandria
, Virginia
I prefer to support Sean at https://www.propridehitch.com/mudflaps/
Any small business owner that provides his personal cell phone number and is reachable over nights and weekends earns my unconditional loyalty for his providing unconditional support.
Even better, he sells them for $199
No brainer.
Rich
KB2ZMF Save
10-14-2016, 07:13 AM
#31
Rich and Kat
Alexandria
Alexandria
, Virginia
Rich/dznf0g, I saw that, thanks. Can you please add more pics? I'm trying to figure out what's happening on the opposite side ... it's not really clear.
I had contemplated something with stainless steel ... I had a piece sitting around here for 4 years ... doing some cleaning 2 or 3 weeks ago, I did the unthinkable and decided to get rid of it, even while knowing I might need it for the mudflaps. I swear, every time I ditch something, I need it within a month's time.
Are you observing any material fatigue given the reinforcement limits the flex to a smaller area? I'd think that flex'ing the rubber in the same place, over and over will trash the rubber soon.
I will say that while driving in the rain, the amount of tire spray from the truck's wake is SIGNIFICANTLY reduced in comparison to other vehicles I see. Plus, it helps that I left them pretty long... I didn't need to cut them at all with my 3500's high suspension. I probably have 2-1/2" of clearance. Will try to post pics at some point ... I've only pulled my trailer on the highway and on some secondary roads, for a total of about 600 miles, but I have not seen any dings on my trailer yet ... Too early to tell, but I strongly believe that they will mitigate potential for dings to the trailer, at least for pebbles that kick-up from my own tires... Can't do anything about what comes from other vehicles/tractor trailers.
Rich
KB2ZMF Save
10-14-2016, 07:37 AM
#32
Oswego
I have had mine in that configuration for almost 6 years and about 26K miles. Other than normal wear and tear, I see no ill effects from the mods. Note that my flaps are in two sections, both bolted to the horizontal rod. The upper section is rigid, but not the lower.
-Rich-
10-14-2016, 09:52 PM
#33
1968 26' Overlander
Grants Pass
, Oregon
I have now had the extra long Duraflap mud flaps for over 5 years.
They still look like new, and my trailer is still dent free.
I do not need to remove them and put them away. I do not have to worry about backing into curbs and parking guards.
I am buying a new to me truck, and I plan to add the duraflap mud flaps to it right away.
10-15-2016, 06:04 AM
#34
2015 30' FB FC Bunk
Ayer
, Massachusetts
Rock Tamers all the way. They are huge and effective when towing, then come off when not towing.
10-15-2016, 07:49 AM
#35
2012 25' Flying Cloud
Battle Lake
We use no more than the optional mud flaps on our EcoDiesel. We tow long distances, there are a few minor dings in the stainless steel segment protectors bit that's why they are there. Nothing in the propane cover. We have a ding high on our trailer and another in the plastic stone guards, those came from meeting other vehicles on the road kicking stones up.
Doug and Cheryl
10-20-2016, 06:25 AM
#36
2002 30' Classic S/O
Garden Valley
, Idaho
DuraFlaps have been my choice for 20 years and are the best out there. Why would you want to take off your mud flaps?
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
10-20-2016, 06:51 AM
#37
2007 27' Safari FB SE
LONDON
, ON
10th year with Rock Tamers
Other than a bit of softening from the exhaust heat on the inside of one flap, we are really pleased how they've kept stones off our Stream for 10 years.
It took me a while but I finally found a guy with a plasma cutter and stainless steel to make the logo for our Rock Tamers. We love the look.
10-20-2016, 07:34 AM
#38
2017 25' Flying Cloud
Fayetteville
, Arkansas
Love the logo!
We have been towing with Rock Tamers for 10 plus years. No issues with heat from our diesel exhaust. And, more importantly, the prevention of damage and road dirt/debris has exceeded expectation.
Do you think your craftsman would be interested in duplicating more?
FishByFly
because I catch fish on a fly...
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
Past: 2005 30' Safari Bunkhouse
Past: 1986 28' Excella Twin
FishByFly
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
10-25-2016, 01:27 PM
#39
2016 27' Flying Cloud
Quebec
, Quebec
Originally Posted by au_ee
Does anyone have the Rock Tamers Mud Flaps? Last year we got stuck going on a Wyoming road that was under repair. They had stripped the pavement down to the gravel/mud subsurface. After 5 miles of this mess the front of our trailer was covered in mud. After cleaning it up we also found several dings. I'd like to prevent future occurances and would like to see if the Rock Tamers are effective in keeping rocks and debris off the trailer.
I got them. They are a necessity to protect your investment. They are ugly but they work. I will send you pictures this coming Saturday.
10-25-2016, 01:42 PM
#40
I use Rocktamers, but I take them off when I'm driving all day on paved highways.
I pull over and slip them on if i'm driving any distance on gravel.
