11-26-2009, 09:49 PM
i have moved north to VIRGINIA CITY
, Nevada
Question about 4x4 TV ...
I am not considering a 4x4 TV becuase of the money added to the price of the truck ... AND because i wont be in any ice and snow or bad weather...and i am certainly not going off road with it.
my question is..... do i NEED 4x4 for any reason if i am not going to be in bad weather? wont towing with it on bring down the fuel mileage?
i want to keep the price of this truck down as much as i can but i dont want to be stupid about anything.
at this point i am trying to get an idea of what i have to spend to have peace of mind that when i am towing... the truck will be able to do its job with no worries.
i am leaning towards a diesel... to keep for a long time.
is dodge better than ford for that?
thanks for your opinions.
11-26-2009, 10:00 PM
1984 29' Sovereign
Savannah
, Missouri
AnnieD,
Recently, my brother-in-law and I were driving in his 2x4 Dodge pick-up(2500 series diesel) off road on slightly hilly grassy slope. We got stuck and had to have a tractor pull us up to level land!@ I would have never thought it could happen but, it did. Just to show you, if it can happen..it generally will.
Good luck on your ultimate choice.
My personal choice would be:
GM then Dodge and after that...GM.
Ford, over the years has been way too inconsistent and quirky for me.
WBCCI 5292 AIR 807
NEU #64
New England Unit
11-26-2009, 10:26 PM
_
11-26-2009, 10:45 PM
1993 34' Excella
1962 16' Bambi
New Haven
, Connecticut
for 4x4
if you do any amount of airstreaming the day will come where you will venture off the pavement - even if it is only on to grass. now if the grass gets wet (dew, rain) the slipping and sliding will occur. i have seen more than a couple of 2x4 tv's with airstream in tow have to get towed off the grass.
my vote is for 4x4.
11-26-2009, 11:14 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings AnnieD!
I have had a number of tow vehicles, and only three of them have had four wheel drive. My '84 Jeep Grand Wagoneer was an excellent tow vehicle and its four wheel drive was trouble-free -- fuel mileage was atrocious both solo and when towing -- single digits much of the time. My second four wheel drive tow vehicle was a '95 Chevrolet K1500 Club Cab Silverado (purchased new by me), its four wheel drive was the single biggest trouble causer on what was otherwise an average tow vehicle. My current '99 GMC K2500 Suburban also was ordered by me with four wheel drive -- I am losing about 2 MPG under all driving conditions -- and it has been the most trouble prone part on an otherwise trouble-free vehicle for 200,000 miles and counting.
My experience has been that yes, the fuel mileage under all conditions will be reduced. With the exception of the Jeep the four wheel drive has been the most trouble-prone parts on my other two four-wheel drive tow vehicles. I am at the point of having the four wheel drive disabled on my Suburban to avoid spending another $1,500 to $2,500 on a four wheel drive system that rarely goes for more than 12,000 miles without needing at least $1,000 in repairs. The same was true with my second four wheel drive vehicle and was a big part of why it was traded on the Suburban with only 49,000 miles on the odometer. If I buy another primary tow vehicle, it will not have four wheel drive -- a locking rear differential is a far more valuable option (IMHO).
My suggestion would be to carefully compare ownership costs over time to see if the diesel really makes sense for your intended use. I have never owned a diesel, but one of the reasons that I passed on the diesel when I ordered my '99 Suburban was that we didn't have a mechanic with a proven track record maintaining and repairing diesels. The extra cost of oil changes and regular maintenance was also a consideration.
When I ran the figures for my situation, I learned that it was basically a wash cost wise. I keep my vehicles for many thousands of miles in most cases, and my computations indicated that I would have to replace my gas fueled V8 once during the lifetime of one typical diesel motor -- the cost of replacing my Suburban's gasoline V8 was approximately the price difference between the V8 gas Suburban that I ordered and the diesel Suburban. At 200,000 miles, my theory is holding up well . . . the motor has no issues and uses no more than 1 quart of oil between changes -- my mechanic believes that the motor will likely make very close to 300,000 miles before I will need to start thinking about a new GoodWrench motor.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
11-26-2009, 11:36 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
Since you live in Nevada and are probably surrounded by desert on all four sides...
If you want piece of mind you may want to get 4X4. Many of your state parks are dirt or sand and sooner or later you'll be pulling onto a sand or dirt area. Thats when the 4X4 earns it's keep.
Our F250 4X4 diesel gets 17.9 empty and 14.8 while towing. We've used the 4X4 feature often as we boondock in the desert but we have had to use it when we didn't expect to also. Parking in a dirt lot on the highway to run into the store and other similar places.
Good luck with your decision.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
11-27-2009, 12:19 AM
2008 25' Safari FB SE
Land of fruits and nuts
Annie,
How much $$ are you looking to spend.
I would always recommend getting 4x4. If nothing more than I'd rather have it and not need it than need it and not have it. As an example, just two weeks ago, I was in the hospital, and my girl was driving my truck. She was driving on a paved road, not much bigger than 1 lane wide when a big 3/4 ton truck with a ginormous 5 wheel trailer coming the other way, she pulled off a little too far and the right front wheel fell in a large hole/ditch. She called me and I told her how to lock the hubs and put the truck in 4-digg. Truck pulled right out and saved a call to a tow truck.
I'm partial to Fords, specifically '99-'03 F250 Superduty 4x4 with the 7.3L Powerstroke Diesel. I picked up mine with slightly less than 150k miles, rebuilt tranny, well maintained, for $10k. I've now put about 25k more, trouble-free miles on her. You don't have to spend a ton of money to get a solid truck.
11-27-2009, 01:06 AM
, Nevada
WOW! thanks guys ! all this makes ALOT of sense. i can see where i would definitely be needing the 4 wheel drive. if i was pulling off the road or for whatever reason.
i dont know why i didnt think about that but thats true.... i can see where i would need it. and yes i am surounded by mountains and desert all around me in northern nevada....and in the winter i will be in the southern deserts of arizona and new mexico.... AND of course vegas. LOL
and you are right about the deserts and the 4 wheel drive.
so yeah.... i will keep that in mind when i get my rig.
as far as what i am looking to spend.... i dont know. i guess i am hoping to get what i need for the best price i can.
so many things to think about.
thanks SO much for the input.
11-27-2009, 07:22 AM
1999 23' Safari
Perrysburg
, Ann Arbor
Overlander64 is right about the locking rear differential. That alone will save you a lot of grief.
But I've had a bunch of times where 4WD saved me some unpleasantness, and especially when towing the A/S. For example, I recently encountered a situation trying to get into a camping spot in an Ontario Provincial Park that was both hilly and largely sandy. I started to get some wheelspin, even with a locker rear end. My three choices: a) go try to get a more level spot with a poorer view; b) go into the spot at high speed to keep momentum up ... risking bent aluminum, torn off dump valves, etc., or c) engage 4WD and gently pull into the spot with no fuss. The last option seemed to me to be the best, and it was. I probably didn't NEED 4WD, but it sure was nice.
I can say that after some hundreds of thousands of miles in 4WD vehicles, I have had exactly zero problems of any kind with the 4WD system ... BUT when they break, they are expensive to fix.
And 4WD is no cure for stupidity: I once got a Suburban stuck WAY off-road, where it was sitting on both differentials, with all four wheels spinning uselessly in two foot deep water. I won't explain how I did this, but I will say that the 4WD system didn't help a lick, and it took four strong guys an entire afternoon to get her unstuck. So if you get 4WD, consider it an "out" and not a way to try to go to that most appealing, furthest place you can (probably) get to!
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
In 20+yrs of Stream'n probably used 4wd less than a dozen times while towing, would I go w/out it?......nope. Peace of mind while 'dock'n.
IMHO...very good choice.
11-27-2009, 07:40 AM
Peoria
We went with Dodge for the Cummins diesel. Wow.
Janet & Leon
2007.5 Dodge 2500 5.9L Cummins 16+ mpg towing
4CU
11-27-2009, 08:16 AM
1971 25' Caravanner
scappoose
, Oregon
In the last thirty-five years, have only had one vehicle that was'nt 4x4.
Most all of my off-road use has been in desert conditions, and much of the time, I did'nt need 4x4, but what is nice, is the ability to slow things down to a "crawling speed" for ease of manuvering, especially backing up.
11-27-2009, 08:37 AM
St. Catharines
, South Western Ontario
I have been driving in Canada for over 40 years.
We have been towing for over 12 years.
Of the 100 or so campsites we have been in all have been either dirt, sand or grass.
Never owned a 4x4 and never needed one.
11-27-2009, 09:07 AM
2008 27' Safari FB SE
Miami
Speaking up for the 2x4 crowd -- we have towed our 31' Sovereign over 35000 miles the last 4 years into and out of all kinds of surfaces and have never gotten stuck.
I would think that for the price differential (not to mention potential maintenance costs)you might want to consider going with a 2x4 and using the savings to buy a good towing policy (which you should have anyway) for the next beaucoup years.
As for gas/diesel -- I would love to have a big honking diesel but I figure that by the time a diesel is just getting properly broken in (~200k miles), the rest of the truck will be looking pretty tired. So, I went with a gasser and have been very happy. The diesel will get you better mileage and, theoretically, lower per-mile fuel costs but you will pretty much have to drive to Mars and back to recoup the difference in up-front cost.
I would google the Powerstroke Diesel before I made any purchase decisions. It is my impression that there are a lot of unhappy owners out there...
Good luck!
mike
11-27-2009, 09:23 AM
St. Cloud
Some years back former mod Pahaska, reflecting on his developed campground ways, bought a 2WD pickup on the lot. He's gone back to a 4x4.
This last summer I was in a private "developed campground." They had odd places they stuck non-seasonals. Our slot dropped 3 feet in about 12 feet as it left the loop road. The site had nicely mowed but thick grass and I was sure glad I had the 4WD when I had to pull out of there.
The very day we picked up our Safari, a rain storm was sheeting the streets as I was stopped maybe 6-8 degrees uphill at a redlight in Manchester, Iowa. Mountainous Manchester? Nope... I tried starting out in 2WD and the truck wallowed sideways. Took my time, switched to 4WD and was easily underway.
And I really do prefer to dry camp in out-of-the-way Forest Service or state forest campgrounds. My choice is 4WD. Your results may vary...
11-27-2009, 10:01 AM
Corona
Generally speaking, 4 WD drive is great for off road and 2 WD drive is great for regular roads.
Of course, there can always be exceptions.
n
11-27-2009, 11:09 AM
Moderator Emeritus
1964 26' Overlander
Anna
I certainly concur that four wheel drive vehicles can be expensive to repair as I have only had one of three that wasn't. I bought all of the arguments for four-wheel-drive, and have had it in three tow vehicles. The only one in which is was trouble-free was my '84 Jeep Grand Wagoneer. With both of the other two, which were both purchased new by me, the four-wheel-drive was/is a source of constant problems and expense -- my current K2500 Suburban has had the following expneses with its four-wheel drive mechanicals:- 36,300 miles -- Electronic Control Module for Transfer Case -- Failed -- cost to repair if dealer hadn't pushed it through under warranty would have been $775.00.
- 48,000 miles -- Electronic Control Module for Transfer Case -- Failed -- covered under MFG parts warranty.
- 62,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $825.00 for replacement of module, and an additional $200.00 for replacement of Transfer Case output shaft seals.
- 76,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $750.00 for replacement of module.
- 94,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $750.00 for replacement of module, and an additional $550.00 to replace all of the grease seals in the Transfer Case.
- 105,000 miles -- Electronic Control Module for Transfer Case -- Failed -- covered under MFG parts warranty.
- 120,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $750.00 for replacement of module, and an additional $300 for new front differential seals.
- 136,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $750.00 for replacement of module.
- 155,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $750.00 for replacement of module.
- 180,000 miles -- Electronic Control Module for Transfer Case -- Failed -- $750.00 for replacement of module.
- 193,000 miles -- Electronic Control Module for Transfer Casee -- Failed -- $750.00 for replacement of module.
- 198,000 miles -- Transfer Case Rebuild or Replace needed -- deemed a danter to operate vehicle until repaired -- the worn parts could fail causing a loss of vehicle control -- estimated repair cost is between $1,300 and $3,300 depending upon whether I want my original transfer case rebuilt or a new Good Wrench transfer case. The decision has been made to disable the electronics of the system and remove the output shaft from the case and other related parts as necessary to remove it as a continuing maintenance problem -- estimate for disabling four wheel drive $850.00.
At this point, the four-wheel-drive system has cost $6,925.00 in repairs and it will take another $850.00 +/- to disable the four wheel drive and return the vehicle to operation. I could have easily called AAA or Good Sam Road Service for tows many times for the amount the system has cost in repairs not to mention the decreased fuel economy.
My Suburban's four-wheel drive has never had operable four wheel drive when it was "needed" after its second year. I have yet to have needed a tow to get out of any situation with my Airstream or Argosy -- its locking rear differential has come to the rescue every time. My towing has been mostly in the Rocky Mountain region, and I have attended all but two of the International Rallys since 1998 (actually used 4-WD to get into this rally (1998), but many were ok without it and I don't believe that I would have gotten stuck without it given the rear locking differential), and have only had operable 4-WD for one of the International Rallys.
I would suggest careful consideration before choosing a four wheel drive tow vehicle. I thought that I had done my homework when I purchased my Suburban with four wheel drive. Aat this point, after 200,000 miles (and 11 years) there has only been one time when I "may" have needed four wheel drive when towing either the Airstream or Argosy, and given what the system has cost for repairs -- a tow truck would have been very inexpensive by comparison. I can see now that I do not need four-wheel drive often enough to make it a worthy option -- the locking rear differential is on my mandatory option list.
Kevin
Kevin D. Allen
AIR #827
11-27-2009, 11:15 AM
Corona
Kevin
After the first failure, it looks like the repairs lasted about 15,000 miles, more or less. What a bummer.
Was it always the same repair shop?
t2
11-27-2009, 11:32 AM
Master of Universe
Grand Junction
Annie, looks like you're doing the right things—looking at all options.
Some years ago we went to rafting with some people who had their own large professional raft. I don't remember what kind of SUV they had, but it was a 4wd. As we left the parking area, raft in tow, we had a fairly steep incline maybe 100' long. Part way up the wheels started to spin and the driver switched to 4wd. Then there was no problem. This was a dry, though sandy and rocky road (sand on rocks is very slick). We've been to CG's with fairly steep inclines that were dirt, sand and rocks. But as mike suggested a few posts ago, a tow policy would be cheaper, though much less convenient.
Since you are thinking about vintage, not so old or anything, older trailers are generally lighter and you may not need a 3/4 ton truck or a diesel. If you want to keep a truck for a long, long time, reliability is a priority. My experience is that vehicles start to look old at about 6 years, so that's when I try to sell them so I can still get a good price (this may be a rationalization since I really want a new truck every 15 minutes), so I don't care if the engine can go to the moon a few times.
Consumer Reports in their annual auto issue has a section on best and worst used trucks and cars plus reliability ratings for just about anything on the market. I think it's reprinted in the annual Buying Guide. The auto issue comes out in a few months, but you can get last year's at the library, or just go out a buy the Buying Guide. You can, and I think you probably are, read all the tow vehicle threads and Linkmaster 2air has provided a few links.
We tow a trailer with a GVWR of 7,300 lbs. with a 2007 4wd 1/2 ton Tundra (gas, 5.7 l, 401 lbs. torque) and have no problems. Others tow heavier trailers with the 2nd generation Tundra and are happy. We buy for reliability. I don't want to fix motor vehicles anymore, and RV's need constant work, so at least one part of the rig is trouble free.
Gene
11-27-2009, 11:56 AM
Two Harbors
Kevin...either you got a "lemon" or you abuse your vehicle ...I am assuming you got a lemon and something was not "right" with your 4 wheel "system" from the start.
I have had four 4 wheel drive vehicles since mid 80's and have not had ANY repairs on the four wheel drive part of the vehicle...other than normal oil/grease maintenance. One of mine was a GM and the other three Toyotas. Not sure either your very troubled experience OR my problem free experience provides evidence of the "normal" maintenance costs of the four wheel drive portion of a vehicle.
While I have not had too many times I "needed" 4 wd...I sure have appreciated when I needed it and likely will always have 4 wd on one of my vehicles...FWIW Tom
Kevin
