05-07-2009, 08:51 AM
Stormywx
1985 25' Sovereign
Sarasota
Newby looking for best suv tv
Hello, Im looking to buy an suv for a (2000-2005) 25-28ft airstream (that we also dont have yet! ) I decided its better to get the TV first.... I have been looking online at Dodge Durango 5.7 Hemi, chevy suburban 1500/2500, and a Nissan Armada. We are looking at a 2004-2005. My questions are.
1. any opinions on these suv's
2. any other suggestions.
3. We will be traveling with 2 german shepherds
Thanks for any info ... gail
05-07-2009, 09:55 AM
More than one rivet loose
Los Alamos
, New Mexico
This subject has been discussed many times. In summary 25-28 is the change over from 1/2 ton to a true 3/4 ton Tow Vehicle. The longer your trailer the longer your wheel base should be. This is a safety of control issue. If you are going to do a lot of travelling with the a "28". You may want to consider a diesel. The age will determine weight. The weight will determine gas vs diesel.
I tow a 06 Classic 31, usually 8,000 lbs towing, with a Ford F-250 Powerstoke 6.0L Diesel. Usually loaded to around 9,000-10,000(max weight) when towing and hitch weight transferred.
Confused?
Michelle TAC MT-0
Sarah, Snowball
05-07-2009, 10:58 AM
1999 28' Excella
Frederick
, Maryland
A Ford Excursion (pref with a Diesel) or a Suburban 2500. Having a 3/4 ton vehicle will make the towing trips much more pleasurable. Of course, if you don't need the third seat, you could get a 3/4 ton extended or crew cab pickup with a cap/topper (like I have). I like transporting cargo such as my bikes, generator, gas etc in a different compartment not open to the passenger area. Also works out better when hauling items to the dump or in other messy situations. But then a pickup might not work out for you.
Good luck.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
05-07-2009, 02:11 PM
2008 27' Safari FB SE
Miami
We've towed our 31' Sovereign almost 40,000 miles over the past four years with a 2004 Nissan Titan (essentially the same frame/powertrain as the Armada) with no problems.
Ran today from near Kayenta, AZ to Moab, UT through some beautiful country with lots of 6-8% grades with nary a white knuckle.
mike
05-07-2009, 02:15 PM
Aluminut
2004 25' Safari
I'm with soyboy....I have an 04 Suburban 2500 and it is a phenomenal tow vehicle. Perfect for what you are looking at bringing with you.
05-07-2009, 02:16 PM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
I run a '99 durango with the 5.9 pulling a 23' 1970 safari. I've had good luck so far! Don't know what the 5.7 hemi difference might make.
I really would have to think about it before stepping up to a 28'. Thats got to be approaching the 7,000 capacity of a durango.
05-08-2009, 05:28 AM
Stormywx
1985 25' Sovereign
Sarasota
Thanks for the info everyone... hoping to find something in the next week or so. So , is a Hemi is as stong as a 3/4 ton? I had a conversation with an Armada owner who said his 4x4 could pull 9100 lbs but would not be good at stopping that kind of weight behind it???? guess thats why you get trailer brakes??? opinions on that?
05-08-2009, 06:33 AM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Welcome....oh boy do you have a LOT of reading to do.
Or; just get yourself a 3/4ton Burb (or Excursion) and save yourself some trouble...
Welcome, again, proceed cautiously.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
05-08-2009, 07:39 AM
1969 25' Tradewind
Irmo
, South Carolina
Do yourself a favor and listen to the folks who have posted already. Forget the idea of a Durango pulling a late model 28ft Airstream. Sure it may pull it, but not safely. For someone new to towing, loading a vehicle at or close to its maximum capacity is a recipe for disaster. Go find yourself a 2500 suburban or an Excursion and you will be ready to go and buy that first Airstream.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
05-08-2009, 08:56 AM
Peoria
We enjoy our Dodge 2500 Cummins Mega Cab. The huge cab is far roomier than our old SUV. A pickup with a large cab is like having an SUV and a pickup all in one. Tows like a dream and gets great mileage.
Janet & Leon
2007.5 Dodge 2500 5.9L Cummins 16+ mpg towing
4CU
05-08-2009, 10:01 AM
2007 27' Safari FB SE
Tracy
We pulled our 27 FB with a 3/4 ton Suburban with the 454 and it was fine. We went with the new Ford F250 Superduty Super Cab and it did make a lot of difference in the towing experience. 50% better mileage also. We added the Pace Edwards power retracting bed cover so I basically have a 6 1/2 foot trunk that is lockable. I store the generator and all sorts of other things I don't want prying eyes to see. The back seat is great for our one large dog or two very comfortable guests as that area is huge.
The dealer told me that I probably don't even need the load leveling hitch or the sway control but I use them anyway. Better safe than sorry.
Welcome and good luck.
2007 Safari FB SE LS
2008 F-250 Lariat Power Stroke Diesel Crew Cab
WBCCI 1538
To err is human. To arrrrrrr is pirate.
05-08-2009, 10:16 AM
The handy accountant
1976 27' Overlander
Scarborough
, Ontario
At the risk of opening up an oft-argued point, a 5.7 litre Hemi Durango would appear to be able to safely pull a 28' airstream.
The towing capacity of an 06 Durango hemi 4X2 is 8,950 pounds, 200 less for 4X4. http://www.fowlerdodge.com/quickQuot...de/durango.pdf.
The GVWR for a 28' airstream is 7,300 max. (5,440 base weight plus 1,860 NCC). (from the weights and measures page of Airstream: Airstream Weights)
8,950 minus 7,300 = 1,600 pounds. This is the maximum allowable poundage for passengers plus whatever you're carrying in the pickup bed. That's assuming the 7,300 pound limit has been reached on the trailer.
The hemi has 335 HP and 370 ft/lb of torque. Is it really unsafe to be towing a 28' airstream with a Durango Hemi? I'd do it in a heartbeat, after hitching up the weight distribution bars, anti-sway controls, and brake controller.
Kevin
05-08-2009, 10:45 AM
Nipomo
Dodge and the 25-footers...
We've had what we consider a successful experience with a 2005 Dodge Durango Hemi and a 2006 Safari FB. Mileage over more than 30,000 miles of towing has been north of 13 mpg and on the flat we commonly get 15. We seldom exceed 60 mph, which accounts for the good mileage--on regular gas, I should add. Braking isn't an issue when the controller is set up properly to let the trailer take the proper amount of the load otherwise you could overburden the Dodge on steep downhills. We make of practice of hitting the downhills at below the speed limit anyway to minimize the potential drama. With the Equal-i-zer hitch there is no issue with passing trucks, cars, or buses. The Airstream is a dream to tow relative to SOBs.
Good luck with your search. Remember that the hp and torque specs vary by year. Our Durango has all the tow package goodies including all-wheel, 4-wheel drive and the standard rear axle ratio (the lower ratio option gives you the higher towing capacity but hurts gas mileage--be sure to get this info and decide what is best for you). If I had it to do over, I'd opt for the 2-wheel drive version to save the extra weight and complications that just make maintenance, routine and otherwise, a bit more expensive. I can't recall a single instance where the 4-wheel drive was needed.
If you want other info on this combination, search for other postings of ours and others.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
05-08-2009, 01:59 PM
Cincinnati
, Ohio
brakes
Something that you might want to consider is braking.
The diesel powered trucks all have HUGE twin caliper pistons with lots of stopping power. These trucks are designed by the manufacturer to pull loads of 15,000 lbs or more. Would that not add a considerable safety factor?
The Durango and Nissan will not have nearly the braking power.
Woody
05-08-2009, 02:09 PM
1997 34' Limited
Charlottetown
, Canada
Chrysler Aspen
Stay away from the Chrysler Aspen Limited with the Hemi, poor stability, mileage and overall waste of money.. Stick with GM and save yourself. Only good thing about Aspen is the look....well I guess you could leave it parked somewhere....lol
05-08-2009, 03:18 PM
St. Catharines
, South Western Ontario
Wb... You are comparing the Aspen with a Hemi Magnum. Big difference.
Could it be that you were spoiled with the Magnum and the Aspen handles like a typical SUV??
Interested in hearing more of your views on the differences in handling between the Magnum and the Aspen. thnxs
05-08-2009, 07:54 PM
1997 34' Limited
Charlottetown
, Canada
There are huge differences in the handling.. I'm not sure where to start other than I should have listened to my good buddy Andy at CanAM. It was my virgin trip today, just alittle spin down the highway to see what it was like. I took a passanger along with me who had also been in the dodge Magnum while towing and they said... geez, you can really feel the trailer in this truck compared to the Magnum. The only possitive with this SUV is i felt I picked up speed a wee bit faster than the car. weird as they both have the same engine. the Magnum (car) got 12mpg this thing on the road was barely getting 10mpg. Well, lessoned learned I will take the huge hit in two years and trade this jalopy err SUV in and get another car. the Magnum cost us 39K and this SUV cost us 57K and all i got was a back up camera to hitch up alone...WOW
05-08-2009, 09:48 PM
San Diego
Chevy Express
Consider the value of a full-sized van. We have a 12 passenger 2005 Chevy Express 3500 (1 ton.) We remove the two middle seats when towing our 2006 Safari 25' SE FB. The large back seat remains for the dogs. Gross capacity 10,000 lbs.
There's about 7' of open floor where the two middle seats were removed, where we keep a storage unit for our on-the-road stuff, dog stuff, campsite stuff, etc. Camp chairs and firewood go behind the back seat. There's even enough room to lay out an inflated mattress and nap when you're tag-teaming trying to drive across Texas!
When we aren't hooked up to our AS Silvia, Silvester (our van) is great at moving groups to family events, furniture for our oft-moving daughters, and home improvement tools and materials.
Best of all, compare the prices for a Chevy Express, GMC Savana or Ford van against the SUV prices.
John and Lynn,
Silvia ('06 25' Safari SE FB) and Silvester ('05 Chevy Express 3500)
05-09-2009, 12:21 AM
Salem
, Oregon
Breaking point, 25'
Hi, you have been given a lot of good advise; I will make it somewhat simple. If you decide on a 25'er a half ton will work just fine. If you decide on the 28'er I would recommend a 3/4 ton tow vehicle. Even though a half ton might be within the weight limits of a 28'er You have to consider the fact that a larger trailer is a larger sail in the wind. [My opinion, others may disagree]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-09-2009, 08:36 AM
Putnam
, Connecticut
Crew Cab pickup gives you a "dirty" place to carry stuff you don't want in your SUV. Of course if you are a very neat person, don't carry a generator and don't carry extra stuff an SUV will work great. You'll also save some money. Do the math on the weight. You'll likely go with a 2500HD 6 Liter. Of course the best way to go is a Duramax. Goes good, stops good also. Stopping is really important at the bottom of a long hill.
