Old 06-03-2010, 08:31 AM   #1
2006 16' International CCD
Fresno , California
Jeep Wrangler with Modifications as a TV?
I have browsed on this site... and seen that people say a jeep wrangler is a bad tow vehicle. I called a dealership yesterday and was told that my Jeep "As Is" would pull a 16' sport all day long.
Jeep 4 door wrangler tow weight 3500lbs.
Granted at stock... I would be at the max rating on the 16 sport and I don't think that is a good idea. However what is the forums thoughts if I made modifications to the jeep.
Regearing the transmission to a lower ratio
Superchip to increase horsepower
Upgraded braking system
Transmission fan for cooling
Air intake system
Any input would be appreciated... as my family as outgrown the Teardrop.
Bluejaydave is offline   Reply With Quote
Old 06-03-2010, 08:47 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The thing to watch is stability. The Wrangler has a short wheelbase. If the Wrangler is lifted, then that may make matters worse.
I wouldn't be too concerned about weight, horsepower, gear ratios, and stuff. Spend your money on a good hitch, a transmission cooler, stiffer shocks and a MaxBrake.
Old 06-03-2010, 09:19 AM   #3
1960 22' Safari
in the wilderness , The great Mojave Desert
Don't forget you have to add in the weight for food, water, clothes, pots and pans and everything else you put in the trailer and it adds up fast. Also you have to add in the weight of the people, pets and supplies in the jeep.
There is an %80 rule of thumb that says you should only tow %80 of your vehicles capacity. How critical this is. I don't know.
I'd be more concerned with the narrow and and short wheelbase of the jeep. I fear you will be in the situation where the trailer will push the jeep. You will be going through mountains every time you leave the valley.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 06-03-2010, 09:42 AM   #4
Charlie M's Avatar
2017 25' Flying Cloud
Las Vegas , Nevada
Dave, with modifications to your Airstream you can do this.
Charlie M - WBCCI 4045
Charlie M is offline   Reply With Quote
Old 06-03-2010, 09:55 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Almost anything can pull a small Airstream, but as mentioned earlier, stability is the problem. You will encounter many forces, natural and man-made, that will push your rig around. The Jeep is simply not stable enough to handle them.
I can appreciate the desire for the Jeep in the backcountry. If you need it, forget the Airstream and pull the Jeep with a motorhome.
Old 06-03-2010, 10:06 AM   #6
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
BlueJay, I would never trust what comes out of a car dealers lips.
But you may want to post on one of the Jeep forums to find out what they might be towing. I see a lot of jeeps out here towing scamps and tabs. With the longer wheel base on the four door you may be all right.
mojo is offline   Reply With Quote
Old 06-03-2010, 10:07 AM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
The other alternative is to drive a truck and have a large 4 wheeler in the bed. Jeeps are great (I have a CJ-2a) but today's 4 wheelers will do anything off-road a Jeep will and are light enough and small enough to fit in the pickup bed.
Old 06-03-2010, 11:07 AM   #8
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
If you're going by the numbers, a 2008+ four-door Wrangler has a 116" wheelbase. That's the same as a current Tahoe. These late-model four-doors are quite a different animal than the nimble rock-crawlers.
mutcth is offline   Reply With Quote
Old 06-03-2010, 11:47 AM   #9
Fresno , California
I really appreciate the input so far. I have been surprised with the handling and driving comforts of this Jeep. I have caught myself cruising on the Freeway at 90 mph without notice. I think the late model jeeps have come a long way from the older ones.
Charlie M- Nice jeep... your post said if I made mods to the Airstream? Was that a typo or is there something I should now?
Mojo- I should have clearified as the dealership that told me I could pull the 16' sport was not a Jeep Dealership it was an Airstream Dealership. I have looked on jeep forums and they are towing trailers that weigh between 2900-3450lbs dry weight.
Mutchtch- The nice things about Jeeps- Is there are so many aftermarket modifications available...that the sky is the limit.
That is why I am confused... if I take another vehicle that weighs the same amount as the Jeep, with the same wheel base, but this vehicle can tow 5000lbs, why can't I make the modification (Horsepower, gear ratio, etc.) to be in line with those specs and tow a 16' airstream?
Old 06-03-2010, 12:10 PM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
BJD,
I think you'll find that although the Jeep is a great truck, it has a 2k tow rating. Lightest late model Airstream that I am aware of weighs in at about 3,000lbs. Add fuel for the Jeep, passengers and cargo and you'll most likely have about a 1400lb actual tow rating. Wheelbase is not an issue with a 16' IMHO, however, I, like you modified the hell out of a 1996 Impala SS around the same wheelbase and with a far more powerful engine. I did everything: Rear and front control arm upgrades, spring and shock upgrades, rear gearing to 3.73, trans coolers, deep trans pans, trans reprogramming so I could tow in OD. In the end the car could pull a 34 footer in terms of power. Power was not the issue. This car had a 5k tow limit (as mine was an Impala SS clone based of the Caprice Classic). My 19' Bambi towed well and had no ill effects to the Impala, however after having done all these mods to the Impala, I decided to get a 25' Safari.
Long story short, my wheelbase was a little short for that 25er, but there too wasn't the bigger issue. The bigger issue is that the frame, body mounts, etc are designed to a certain level. Once I placed higher stresses on the frame with the heavier hitch weight, I started to get body mounts pull apart over time, and many of the engineered tolerances for bolts that connect key components started to fail way prematurely. Keep in mind I've been towing with "B" body cars since 1993 and this one performed like the others UNTIL I greatly exceeded the specifications, regardless what heavy duty upgrades I did. My guess is you'll be doing this too to a lesser extent. My guess is that you'd need about a 4k tow rating to haul the RV, passengers, cargo and fuel, which clearly you won't find in the Wrangler, at least going by the manufac specs and stated limits.
Bottom line, IMHO, if yer talking about spending the $$$ on an Airstream, why not simply get a different 4x4. Even the Tahoe would be a better choice, or an Impala SS.
Basic modding cannot overcome everything, particularly if the vehicle was never designed for such weights. About the only thing I think would keep you in the green would be a frame off rebuild beefing up everything.
BTW, this is where I got the 2k tow rating info from:
http://www.jeep.com/en/2010/wrangler/capability/towing/
Old 06-03-2010, 12:28 PM   #11
Fresno , California
This is the current set up. This teardrop is 13' in length and I was told weighed over 2000lbs. It tows great! Just the little one is not so little anymore and a bathroom on board would make the wife and daughter happy.
To clearify the Jeep that I have is rated for 3500lbs towing weight.
Airstream 16' Sport dry weight is around 2700-2800lbs with a max GRVW of 3500lbs.
Old 06-03-2010, 12:29 PM   #12
mutcth's Avatar
2007 23' Safari SE
Looking at the 2008 Wrangler's owners manual, it is rated at 3500 lbs with the right powertrain. Tongue weight is limited to 350 lbs.
Having said that, CanAm RV in Canada has set up newer Wranglers for towing, including installing reinforced hitches. Andy Thomson from CanAm posts occasionally to this forum. He mentions towing with a newer Wrangler in this thread. He should be able to give you an idea of how it performs and what would be necessary to achieve that.
Tom
Old 06-03-2010, 02:38 PM   #13
Charlie M's Avatar
Las Vegas , Nevada
Jeep Tow Vehicle
Just funnin' Dave. I took that photo (not my Jeep) last week. My nephew was a Chrysler Jeep engineer (lost his job in '08). He meets a group of retired Jeep engineers for some four wheeling at Moab, UT. It was my first experience and I really enjoyed it.
Old 06-03-2010, 04:19 PM   #14
Lost in America
mojo's Avatar
If you have your heart set on an Airstream and still want the off road capabilities, look at trading in the Jeep for a Touareg with air suspension. Rated to tow 7700lbs and can raise to 12" clearance. Plus locking center & rear diff.
Then you can get a 19' or 23' for your growing family. Kaching!
Old 06-03-2010, 04:54 PM   #15
1964 24' Tradewind
Calgary , Alberta
Our TV is the Jeep Liberty CRD (diesel). Not a super common vehicle, only sold in North America for 2005 and 2006, but, a fantastic tow vehicle. Rated for 5,500 lbs, with a weight distributing hitch and sway control, had no issues towing our 24 foot Tradewind through the mountains, even with the short wheelbase. Might be a vehicle to look into if you are interested in staying with a Jeep.
Blanchard is offline   Reply With Quote
Old 06-03-2010, 05:34 PM   #16
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I think you'd be fine... see (not that I totally recommend this) what Andrew T. friends tow with a Wrangler.. hard to see in the pic, but it's a 25ft'r. I think page 3 has the mods he did to it.
Marc
http://www.airforums.com/forums/f42/...eam-55607.html
Old 06-03-2010, 06:22 PM   #17
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
The 4 Door wrangler has 120 inch wheelbase from what I found on their website. I've been considering one as a future tow vehicle for our Caravel, which would be more in line with it's towing capacity. I would think that with a good hitch and sway control, you would be ok. Just don't lift it, you want a low center of gravity for stability. And look for a vintage AS if you want to save a little weight over the 16 Sport. A vintage Bambi or Caravel would cost you less and weigh less. We love our Caravel!
Stephanie
Old 06-03-2010, 06:46 PM   #18
Road Ruler's Avatar
Images: 38
The big plus with the Jeeps is their very short rear overhang. This gives you a very positive (desirable) wheelbase to overhang ratio comparable to many popular pickups and SUVs.
Modern vehicles are well built and with the proper attention to detail will give you years of reliable use as a TV. Our late model (7 year old) car drives like new with over 200 hours of towing and has yet to have an issue from being used as a tow vehicle*.
*Well actually it did suffer from a minor spring sag issue. A pair of $35. energy spring spacer isolators solved the problem.
Old 06-05-2010, 06:20 AM   #19
Denis4x4's Avatar
Durango , Colorado
I have a '10 Wrangler Unlimited with the factory tow package. Pulled my t@b over Wolf Creek and LaVeta pass without any problems. The t@b is about 2600# with a good supply of adult beverages. Friend tows a 19' CDI with a Touareg and likes to off road. Last year, he cut a tire on Cinnamon pass and it took us two days to find the correct replacement tire and somebody with the right kind of equipment to change it!
Denis4x4 is offline   Reply With Quote
Old 06-06-2010, 07:06 AM   #20
1994 21' Sovereign
Hollywood , Florida
I also have a 2008 Wrangler Unlimited with tow package. Just purchased a 94 Sovereign 21ft. Have been doing a lot of reading about towing. I am not going to buy a new tow vehicle. I will get a good anti-sway weight distributing hitch which will increase my TW and total capacity to 4k. Even then im over the recommended weight. But, the chassis will be fine and im not going far with it. The same jeep in europe is rated to tow 5k. remember back in the day regular cars used to tow these things all over the country loaded down like crazy. I think I can make it. By the way I will take off one propane tank to save weight and of course tow with the trailer completely empty.
stonewhite08 is offline   Reply With Quote
Tow a Bambi with a Wrangler? JMD 2005 and newer - Bambi all models 28 08-03-2016 08:25 AM
FB modifications Denis4x4 2005 - 2010 Safari 13 10-15-2010 09:50 PM
2008 Jeep Wrangler Sahara <-> 1973 Airstream 25' Trade Wind Land Yacht GVWR: 5800Lbs. sysgenss Tow Vehicles 12 08-07-2009 09:00 PM
Towing with a Jeep Wrangler Jeeper Tow Vehicles 17 05-22-2008 10:20 PM
What modifications have you done to your A/S? John Our Community 50 03-30-2003 10:25 PM
