Old 02-13-2007, 12:18 PM   #1
altamont's Avatar
Profile:  2007 27' Safari FB SE
Tracy , California
How much towing capacity do I need?
I am using my 96 Suburban 2500 4X4 to tow my 2007 Safari SE FB with a GVWR of about 7500 lbs. If I am using a load leveling hitch, to I need a vehicle rated at 7500 pounds or can I get by with a bit less? Right now, my TV is rated at 10200 and I have no problems but the TV is getting a bit long in the tooth for my wifes comfort.
altamont is offline   Reply With Quote
Old 02-13-2007, 12:27 PM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I believe that you are now at a good place in TT to TV ratio. My personal comfort zone is the 75% range. I tow a 25' FB with a 2500 Sub. I have also pulled it with our '04 Tahoe. It works, but it's just not as comfortable. You might not be happy with a half ton TV towing a 27 footer.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 02-13-2007, 12:34 PM   #3
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
I agree. What you have is great. I'm not sure I'd go less. I too have a Suburban 3/4 and it's perfect for our 25'. I would imagine it would be the same for a 27'. Besides, towing with a 1/2 Burb or truck isn't gonna save you any $$ in terms of maint or fuel. Might be a bit softer ride, but to me, the upgrades of a 3/4 well outweigh the slightly firmer ride.
Old 02-13-2007, 12:36 PM   #4
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
I think it is a great combination, except that I think you and I should trade trailers.
Pat
pmclemore is offline   Reply With Quote
Old 02-13-2007, 12:37 PM   #5
AZstreamin's Avatar
Profile:  2005 30' Safari
Chandler , Arizona
Does this mean the Mrs is giving you the green light to buy a new truck. Lots of nice new trucks out right now.......
AZstreamin
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."- Mark Twain
AZstreamin is offline   Reply With Quote
Old 02-13-2007, 12:44 PM   #6
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Send a message via AIM to Condoluminum
Get Ready...
Altamont-
You've asked a "charged" question, and should see lots of responses... In meantime, you could try "search" feature above, and look for tow vehicle or tow capacity threads, and get a preview of all the opinions previously shared here...
I'll try to summarize, since we have slightly lighter trailer, and recently did an upgrade...
There are "Half Ton" trucks and SUV's (Suburbans and Expedition/Excursions) rated to tow 7200#, so you might get away with that.. Most posters here recommend getting tow vehicle with tow capacity such that trailer is 80% or less of rated number, since tow capacity also must include passengers and luggage and hitch parts as well as the trailer and contents.
A few argue you can equal or exceed tow capacity with trailer GVWR, assuming you'll tow with empty tanks and trailer below its max gross weight.. I feel that could work in Iowa, but not here in California, where you have to deal with passes like Donner or Grapevine or Siskayou's or even Cuesta to get to beach or southern CA or Nevada...
I think wheelbase is important, and would opt for long wheelbase truck or SUV like Suburban or Excursion. I also think truck should WEIGH close to 80% of trailer GVWR so that if truck and trailer get into tug of war, truck has chance of winning.. (Search on accident reports for more details..)
One option is to consider a "fund" for maintenance and invest in the old "Burb, though lack of airbags and CD players and soundproofing might not work for spouse.. In spirit of "Vintage" members here, you can do a lot to fix up an old Suburban for a lot less than cost of a new truck.
Finally, you also have option now (especially when gas prices spike) of finding clean late model used Suburban or Excursion for less than $20K, with tow capacity of ~8K#, and low mileage. There are big trucks from commuters who can't afford the run from Tracy to San Jose anymore for sale in mid-teens, as 2002 to 2004 models. Unfortunately, this also means your used Suburban isn't worth much on resale market... Check dealers and craigs list from Livermore to Stockton to Modesto for bargains... We bought a 2002 Excursion with 40K miles and full tow pkg, including 4.11 rear axle for $17K a year ago to pull our 6500# trailer.
I'll let others chime in on diesel v. gas discussions. You are either willing to trade some noise and vibration for fuel mileage and torque, or not... If vehicle only used for towing, choice gets a little easier, but not much...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-13-2007, 12:58 PM   #7
2airishuman's Avatar
Profile:
the answer to your question is...NO.
using a weight distributing (load leveling) hitch in NO WAY changes the requirement for adequate towing capacity.
w/d doesn't increase the towing capacity.
w/d does redistribute mass to the front axle/tires and does reduce the 'lever effect' of the hitch/ball point on the rear axle/tires
without w/d gear most receivers are maxed out at 500lbs, while a few rate to 750lb tongue weight.
so as trailer tongue weight climbs above 500lbs, w/d gear goes from 'useful' to 'essential' to 'required'
the issue of 'tow rating' for the tv relative to gross weight of your trailer is separate and multifactored.
the questions of 'how much towing capacity do i need?' and 'does a w/d hitch reduce tow capacity requirements?' are often confused.
it seems even sales folks will suggest..."if you get a w/d hitch you can tow more"
this is a misleading truth, because IF the tongue weight is 500lbs or more w/d gear does allow one to tow more...
tongue weight.
but total trailer weight still cannot exceed the agreed/arbitrary/factory tv capacity.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 02-13-2007, 01:29 PM   #8
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
yeah, it says right on my hitch: max weight: 5000lbs. 10,000lbs with w/d.
so I can tow 10,000lbs!!!
yeah. IF I take that receiver off, and mount it to a 3/4 ton truck. LOL!
seriously: very common mistake. people look at what it says on the HITCH, and think that is the rating for the TRUCK.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 02-13-2007, 03:45 PM   #9
altamont's Avatar
Tracy , California
Good info from all. Thanks
Right now, the only problem I have is with the wife and her not trusting an older vehicle. Truthfully, our Burb only has 98k miles and always has been well maintained. Gas cost is not an issue and I do like the ride. In fact, it rides better towing the AS than by itself!
So I might "buy" some miles by getting a newer unit but I will stay with the 3/4 ton with either the 7.4 or 8.1 liter engine as that size seems to work really well. An Allison tranny would be a bonus.
Old 02-13-2007, 04:17 PM   #10
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Welcome aboard!
Lucky man!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 02-13-2007, 04:23 PM   #11
Profile:  2007 25' Safari FB SE
Juniper Hills , The Great Mojave Desert
You could renew that unit with a crate eng, tran and undercarriage bushings. Spend some money on the interior. You'll have a near new burb that feels new and will look new on the inside.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is online now   Reply With Quote
Old 02-13-2007, 04:55 PM   #12
altamont's Avatar
Tracy , California
Believe it or not, the paint is pretty much perfect (GM ?), the interior has some wear on the leather which I had replaced and the engine burns no oil to speak of. I put on new Bilstein shocks (heartly recommend them) and I replaced the tires and the wheels within the last year. I think that is what is making me nervous as we have EVERYTING to go wrong now.
Old 02-13-2007, 05:14 PM   #13
dbradhstream's Avatar
Profile:  2006 28' Safari SE
Winter Park , Florida
My 1/2 ton does a good job towing our 28'er, but it's at its max, and being in Florida I have never had to tow it more than 50' above sea level. I'm hoping to hold out a couple of years until Chevy comes out with a Suburban with the new clean diesel engine they're supposedly working on - I've heard it will be the '09 model. Point is, as a Suburban fan not in desperate need of a new ride right this minute, sounds like maybe you would be a candidate to wait for that as well. Assuming Chevy is actually going to produce such a vehicle ...
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Old 02-13-2007, 05:21 PM   #14
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Refurb appears to be my middle name
Originally Posted by Goin camping
You could renew that unit ... Spend some money on the interior. You'll have a near new burb that ... will look new on the inside.
That's what I did with my '84 7.4 l, Suburban C20. Had the tranny rebuilt too. Motor is still kickin' butt at 189,000 miles.
I agree with Condoluminum's observation that you asked a "charged question". Here's something else to consider - Everyone else's potential overkill with what they tow with, and your comfort level with what you drove to the party. Overkill is great for campground conversation, but sux for a daily driver.
Tom
Towing Capacity of 1995 30' Land Yacht Motorhome autoist General Motorhome Topics 4 07-23-2004 01:51 PM
Towing Experience app Tow Vehicles 9 04-19-2004 10:51 PM
Towing capacity of 345 chopperbob General Motorhome Topics 5 12-01-2002 07:59 PM
Towing COArgosy78 1969 Overlander 5 09-05-2002 11:18 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 09:15 PM
