Old 08-15-2011, 03:22 PM   #1
withidl's Avatar
2002 31' Classic
Houston , Texas
3,000+ Mile Trip with BMW X5 & 31’ ASCL
I’ve just completed subject trip wherein I drove about 1,300 from Houston, TX, to Tulsa, OK, then to Rockford, IL, (used Onan Microquiet 4000 genset overnight for 10 hours at Pilot truck stop) and on to Oshkosh, WI, for the EAA AirVenture 2011. Spent 9 days at AirVenture using the Onan Microquiet 4000 for A/C and Micorwave during the day because where I parked road dust prevented open window ventilation (put 63 hours on the genset using 23 gallons of gas for 0.365 gallons per hour). I then drove about 450 miles to Jackson Center, OH, for some Airstream Service work and visited relatives in the area (additional 400 extra miles with X5 un-tethered @ ~20 mpg). I returned to Houston, TX, on the way staying at a Flying J in St. Louis (ran genset for 10 hours), and then Tulsa, OK, for 6 days visiting relatives.
The following may be of interest / comparison for some:
  • Tow Vehicle: 2001 BMW X5 4.4i V8 with Sport Pkg. & Dinan making 300 hp & 350+ #/ft. of torque; curb weight 5,000#. Total miles after trip = 105,594 of which ~35,000 miles towing the ASCL.
  • ASCL: 2002 (build date May 2001) at GVWR of 8,300 pounds.
  • Hitch type = Hensley.
  • Approximate total miles traveled = ~ 3,000
  • Average speed while towing = ~ 51 mph.
  • Cruise control setting while towing was indicated 64 mph (GPS 61 mph).
  • Auto box “Manual” mode in 5th gear ~ 97% of the time; 4th gear ~ 3% of the time; torque converter un-locked 6% of the time.
  • Overall X5 mpg (EXACT basis X5 computer) = 11.8 (includes about 400 highway miles with X5 un-tethered @ ~ 20 mpg).
  • Approximate mpg while towing = 11.5.
  • X5 premium gasoline cost = $1,042.57 (~ $0.348 per mile).
  • Onan genset regular gasoline cost = $117.19 (~ $1.412 per hour).
withidl is offline   Reply With Quote
Old 08-15-2011, 03:27 PM   #2
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Do you know the actual weight of you AS? All very good info!!
Darkspeed is offline   Reply With Quote
Old 08-15-2011, 03:35 PM   #3
Road Ruler's Avatar
Images: 38
Thnxs for the update. Good info!
Old 08-15-2011, 06:06 PM   #4
nilesrob's Avatar
Hampton , New Hampshire
Images: 12
Sounds interesting! Couple of questions, though.
- Did you do anything with the X5 suspension?
- Sorry, but ASCL??
- Have you traveled at any elevation (mountains) and if so how were the results?
Brad (The Slowsky's)
2019 Airstream Classic 30RBT, 2021 Ford F350 King Ranch 4X4 w/6.7L Diesel, Hensley, ACI #1313
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 08-15-2011, 06:10 PM   #5
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
Hello there
This is Paula. We were your terraport neighbors in Jackson Center with the shiny trailer......wow your statistics are mind boggeling......glad you had a safe trip.....we went by the Hensley place near Flint but chose to go see our grandchildren instead......so much to do, so little time....we are now in Chicago....have Madison, Minneapolis and Omaha before going home to California.....nice to have met you, paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 08-15-2011, 06:30 PM   #6
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Nice one Withidl, loved the stats.
Just did 4,200 miles to Florida and back, by way of New Orleans, towing the 28' International Serenity with the 2011 3.5 litre Sienna. Trying to maintain 60-65mph we averaged about 12 mpg, which I was quite happy with. The AS behaved, even though the A/C took a beating, and the Sienna was great, even with three and a half people and a ton of stuff. Our only glitches were a flat (slow, fortunately) on the Sienna and a broken camera lens!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
https://sites.google.com/view/towedhaul/home
MrUKToad is offline   Reply With Quote
Old 08-15-2011, 06:52 PM   #7
2007 27' Safari FB SE
Cape Coral , Florida
Great info, thanks.
Where did you carry the genset while towing, and where did you place it while it was operating?
cmreumund is offline   Reply With Quote
Old 08-15-2011, 07:42 PM   #8
withidl's Avatar
2002 31' Classic
Houston , Texas
OEM UVW = 7239#
LPG = 60#
10 gallons fresh H2O = 83#
Interior modifications (aprox.) = 100#
Approximate food, clothing, etc. = 300#
Genset, fuel tank & 5 gallons gas = 250#
Total = 8032#
I took on full water (500#) and full gasoline (150#) a few miles from the camp site so the ASCL GVW was 8,582# at the camp site (282# above its GVWR of 8,300#)
Old 08-15-2011, 07:49 PM   #9
Road Ruler's Avatar
Images: 38
Not long ago we were traveling on 90 out of Buffalo. The rig kept creeping up to 70 MPH. Finally set the cruise control to keep it at 60. The 3.5 engine size seems to be a good size for towing. Ford thinks so too with their new 3.5EB.
Old 08-15-2011, 07:50 PM   #10
withidl's Avatar
2002 31' Classic
Houston , Texas
- Sorry, but ASCL??
The X5 has the optional OEM "Sport Suspension" which is stiffer, has more negative camber on the rear wheels, 19" wheels, low profile tires with a width of 255 mm front and 285 mm rear.
ASCL = Airstream Classic Limited
I've been over the continental divide 3 times and only remember having to use 2nd gear 2 or 3 times.
Old 08-15-2011, 07:59 PM   #11
withidl's Avatar
2002 31' Classic
Houston , Texas
Paula, I almost offered to swap you even for your "shiny" rig, but maintained my discipline. I really do appreciate your welcoming me into it with my camera as it really is something special that all should experience!
Old 08-15-2011, 08:10 PM   #12
withidl's Avatar
2002 31' Classic
Houston , Texas
Originally Posted by cmreumund View Post
Great info, thanks.
The genset and fuel tank are onboard (CanAm RV dealer install). You can see it at the following Airstream Forums links:
Page 2 http://www.airforums.com/forums/f448...s-68808-2.html
Page 4 http://www.airforums.com/forums/f448...s-68808-4.html
Old 04-27-2012, 06:35 AM   #13
cheswick , Pennsylvania
Mornin'
I am new to this forum and new to Airstreams...but excited...
I am about to tow a 1974 31' AS with my 2005 X5.
Could you please tell me specifics about and modifications to your X5? What type of hitch did you use? Any brake issues on the AS? Did you use a stabilizer hitch and sway bars with that much weight?
(I know that these might be stupid questions...I simply know so little about what I am doing...)
Thanks so much for any response...
bamboo is offline   Reply With Quote
Old 10-16-2012, 08:51 AM   #14
withidl's Avatar
2002 31' Classic
Houston , Texas
I'm Better Late Than Never?
Originally Posted by bamboo View Post
Mornin'
Bamboo, sorry for the delayed response, but I just did a query on my logon ID and found this post that I hadn’t answered (it’s best to send a personal message on an old post because once it drops off the “Portal” screen awareness ceases).
  • Type of hitch used – I personally installed the BMW OEM hitch; 35,000 miles without a problem (it is NOT reinforced).
  • My X5 is a 2001 4.4i with Sport Package and Dinan engine and transmission mods.
  • Brake Controller – I use a Warner controller which mounts to the brake pedal which allows me to control the trailer brakes by “toeing” the upper part of the pedal which pivots at the bottom; no issues.
  • Hitch interface – I use a Hensley hitch interface which incorporates absolute mechanical no-sway and weight distribution adjusted by “jack screws”.
  • Questions – There are NO stupid questions!
Were you able to tow your 1974 AS 31’ without incident?
Old 10-17-2012, 08:10 PM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Where do you store your generator?
Old 10-19-2012, 08:57 AM   #16
withidl's Avatar
2002 31' Classic
Houston , Texas
Picture = 1K Words
The genset is in the curb side rear storeage compartment under a twin bed as follows: http://www.airforums.com/forums/f448...s-68808-4.html
Go back to page #2 of the post for more detailed photos of the interior and fuel tank location.
Old 10-20-2012, 05:10 AM   #17
Vintage Kin
Fort Worth , Texas
Nice report. Good to see average mph as it is as useful as average mpg when trying to make comparisons across vehicle spec, climate, terrain and leaving some fudge factors for driver skill or emphasis during use. Highs or lows don't really mean much, it is averages that count!
51-mph also correlates with sensible daily travel times (rest breaks, fuel + food, stops, etc), so as an overall judge of the way the driver is using his time it also says quite a bit about whatever else he reports. Context.
A nice rig (for those who haven't taken the time to read all the OP's posts: recommended).
Thanks.
Old 10-21-2012, 12:04 AM   #18
withidl's Avatar
2002 31' Classic
Houston , Texas
Thanks.
Your good words are appreciated!
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1960 - 1964 Overlander 17 03-01-2015 05:17 PM
30-day west coast trip. must see? adwriter73 On The Road... 32 09-14-2011 11:22 AM
Crater Lake trip 2011 sharbours On The Road... 4 08-12-2011 09:19 PM
BMW X5 OEM Hitch says NO WD device - Help valmog Hitches, Couplers & Balls 8 07-12-2011 11:15 AM
Outer Banks Trip Memorial Day 2011 FLMarine On The Road... 3 06-29-2011 04:58 AM
