Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Winter Living
Old 10-16-2016, 08:19 PM   #1
2006 30' Safari
portland , Oregon
Oregon Permanently Parked 30 Safari
I have a really good flat site next to my house with water sewer, gas, room for a large propane tank. I want to put it up on blocks, remove the tires, build a deck
about 20 feet square and use it as a guest place. I want to insulate the bottom and put skirting all around, making it good for year round living. I am looking for some advice on this plan.
Fidel
Fidel is offline   Reply With Quote
Old 10-16-2016, 08:21 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, Sounds like a good plan. Post photos when in place.
MICHAEL
Old 10-17-2016, 05:54 PM   #3
Vintage Kin
Fort Worth , Texas
Insect and rodents are the problem after water. Plan to be able to inspect every inch of exterior now and in future. At least annually.
1990 35' Silver Streak
2004 555 Cummins
Old 10-17-2016, 06:04 PM   #4
Sag Harbor , New York
Welcome to the forum Fidel!
In the eyes of the law, when you remove the tires, and put the AS on blocks, it will not longer be a "motor vehicle," but will instead become an "accessory structure" to your house, and thus subject to your local zoning and building codes.
In other words, you will be opening up a can of worms.
There are threads here which discuss zoning issues, For instance here:
http://www.airforums.com/forums/f483...ng-157629.html
You could also run your ideas by your attorney and other experts incl. builders and architects. If you are within the City of Portland proper, this project will be difficult to do under the radar, unless the site is very private and remote. Way out in the country you might have an easier time.
Good luck!
Peter
Old 10-18-2016, 11:38 AM   #5
kdickinson's Avatar
Taos , New Mexico
my input - based on experience and in support of OTRA's post above, best to check with the town or county first to be sure you can have what may in their eyes amount to a guest house or auxiliary building. Variances are hairy balls also and many towns define a hardship for a variance as "not self caused" meaning improper placement of a building is not justification for a variance for set-back code. At minimum there could be a building permit and inspection or two involved and at most you may have to navigate the maze of town building code to get it approved. I've seen others do something similar and make it real nice and then get fined and ultimately have to move it because it was not allowed by local code. The good news is the ability to place and modify the trailer is completely doable and may end up being the easy part ...
kdickinson is offline   Reply With Quote
Old 10-18-2016, 11:44 AM   #6
ericpeltier's Avatar
Superior , Colorado
You will have mice. Get a cat.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 10-18-2016, 12:26 PM   #7
2016 25' Flying Cloud
Friday Harbor , Washington
I have a living-in FC 25 'permanently' linked to water and power (not sewer) from a nearby owned building. Two months so far. I think I am on the 'edge' of residence codes, but feel certain should I remove the wheels, the relaxed code relative to RVs would be violated. I would have to move the trailer every 6 months to continue to qualify as an RV. I have another RV (lived in before) and have found it safe for a decade from rodents and ants applying ample poisons annually.
Rob Cope is offline   Reply With Quote
Permanently hooking up to septic system? Silverslug75 Waste Systems, Tanks & Totes 4 07-28-2009 03:27 PM
Tire Pressure - Permanently Parked Airstream willyd Tires 5 06-18-2008 01:17 PM
whos permanently parked and living in A/S? nyairdream Full-Timing 18 07-04-2006 08:50 PM
Need help parking my new '67 Land Yacht permanently sdickey Our Community 4 06-15-2004 10:18 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 08:49 AM
