07-25-2017, 09:22 AM
1968 26' Overlander
Sioux Falls
, South Dakota
How to secure quarter round?
Just last week I installed my new flooring (click together vinyl planks) and now it's time for the molding. I bought quarter round that matches the flooring but I'm aprehensive. What is the best way to secure it? My thinking at the moment is I can't nail it to the walls like in a house because the aluminum panels won't hold a nail, if I screw it in the screw heads will show and it will look weird, and I can't nail it to the floor because that's supposed to float. Should I glue it? I was thinking of using silicone adhesive to glue it to the walls/uprights.
What have you all done?
07-25-2017, 09:34 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you go with glue, consider the need to only glue one side of the quarter round. If it gets on both sides, you loose the "float". Waxing the floor boards before gluing to the wall is one way to do this. There are a number of other ways.
07-25-2017, 09:38 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I used the fake foam moulding and some glue on the joints and sometimes to The walls nd small air nails to the flooring. The flooring floats, but it does not float much since the trailer is only 8 ft wide.
07-25-2017, 10:29 AM
Tampa
I used (at home) some white fast set construction adhesive.
I had a place where I needed to replace a base board, but couldn't nail it properly. OMG! that adhesive set up 30 seconds, and the next day I probably couldn't have pried it off.
I agree, maybe put a bit of wax paper on the floor and only use adhesive on the side facing the wall. I later used it to repair patio stones.
I don't recall the brand, but there's many out there.
07-25-2017, 11:15 AM
2008 27' International FB
Venice
Don't forget to use real wood. Do not use the fake picture tape covered foam. Does not hold up in the Airstream environment. Ask me why I know!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
07-25-2017, 11:19 AM
1969 29' Ambassador
brooksville
How about automotive two sided tape for emblems and body molding?
Also, they make plastic quarter round that if flexible and paintable. Though I'm a fan of natural wood.
07-25-2017, 11:24 AM
I use this for odd applications that require fast bonding.
http://www.gorillatough.com/gorilla-...SAAEgL7CvD_BwE
William C. Swinney
07-25-2017, 01:07 PM
1969 29' Ambassador
brooksville
Grabs in 30 seconds, that's impressive!
07-25-2017, 02:50 PM
2005 31' Classic
Venice
Use only real wood and then cut & trim the raw wood. After all the cuts are made, take it outside the trailer & stain it with a oil stain to match. I used construction adhesive and long thin brads from a nail/brad gun. Final step...a coat of clear polyurethane.
The prefinished molding does not hold up and comes loose...the method above has worked for three years so far.
07-25-2017, 02:53 PM
1955 22' Safari
Laredo
Double sided tape works well.
07-26-2017, 01:50 PM
1982 27' Excella
Huntsville
Flooring
A little off topic but I have carpet and carpet is not really the best for family camping. Generally when people replace the carpet what do they do about carpeted areas under cabinets and storage areas. Do they remove cabinets and replace the carpet or just leave the carpet in non visible areas?
07-26-2017, 07:54 PM
1969 29' Ambassador
brooksville
Cut it out everywhere you can reach. A little work and it should slide out.
02-24-2021, 07:29 AM
1973 Argosy 26
Gastonia
, North Carolina
Quarter round installation
I am currently renovating an argosy and i've reached the quarter round installation over a new floating floor. I was just wonder if anyone has an update on the methods used. I don't want to do this twice.
Thanks for any help.
Lea
02-24-2021, 07:35 AM
2008 27' Safari FB SE
Miami
I used flexible quarter round and 3M Double Sided tape. Don’t remember which part number. Worked fine.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
02-25-2021, 06:31 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Lea
Hi
Basics are still the same, you do *not* want it connected to the floor. Glue and/or nail it to the wall.
