Old 02-13-2015, 08:47 AM   #1
1974 27' Overlander
North Granby , Connecticut
What are these??
Hi all,
I have a question about these two holes and flex pipes that go under the sub floor. What are they for?
I have completely removed the interior so i can lift the shell to replace the damaged sub floor. Here are some photos of what it looked like before i started the disassembly. Any comments welcomed.
Big G
Name:	inside TT removel airstream 005.JPG
ID:	232328   Click image for larger version
Name:	inside TT removel airstream 004.JPG
Name:	inside TT removel airstream 002.JPG
ID:	232330   Click image for larger version
ID:	232332   Click image for larger version
Big G is offline   Reply With Quote
Old 02-13-2015, 08:53 AM   #2
1974 27' Overlander
Twisp , Washington
Hard to tell just where they were located from your pics, but my trailer had similar flex pipes feeding from the heat duct to the waste tanks. I suppose the idea was to keep them from freezing when camping in cold weather, but with one way air flow, i.e. no return air provision, I can't see them as being terribly effective. I don't intend re-installing them when I put my trailer back together. Later.
Dave
daved20319 is offline   Reply With Quote
Old 02-13-2015, 08:57 AM   #3
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Sometimes those ducts work to draw warm air from the interior to the furnace intake. They are one-way, but they do work to keep the tanks from freezing. Check for this design feature before you decide to eliminate them.
Old 02-13-2015, 10:02 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
If that flex hose is in the bathroom area, it may have been attached to a little exhaust fan and used to evacuate the toxic bathroom funk.
Old 02-13-2015, 10:22 AM   #5
1974 27' Overlander
Hi Belegedhel Thank you for your in put. These holes are between the road side and curb side back closets and the rear bath room. The road side one is near the water heater and the black water vent stack that runs up through the closet and the other one looks like it is in the bottom of the curb side closet.
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
What do you think about these forums? Andy R Our Community 11 10-28-2006 06:56 PM
Have you ever seen one of these Dave Bowers On The Road... 7 01-11-2003 12:37 PM
can you ID these trailers? john hd Our Community 24 12-14-2002 09:48 AM
What are these........ wires for? niftypkg Electrical - Systems, Generators, Batteries & Solar 2 10-13-2002 01:21 PM
