Old 10-10-2010, 01:05 PM   #1
Dan Kachele
1995 34' Limited
Avon , Indiana
Sticky Ceiling
Just bought a 1986 Airstream that is in near perfect condition except for the ceiling, it is sticky front to back and regular detergent or something like mean green, 409 or spray 9 wont touch it. Has anybody got a fix on this problem.
dachele is offline   Reply With Quote
Old 10-10-2010, 01:08 PM   #2
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
We found that a good degreaser works well; I had Oil-Eater from Costco and that took care of the problem. Use gloves, of course, and don't inhale the spray mist.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 10-10-2010, 01:15 PM   #3
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Trader Joe's has a organic cleaner with sage & pine we use all the time. Great stuff!
Mike Leary is offline   Reply With Quote
Old 10-10-2010, 01:24 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have had success, both with Greased Lightning, and also with Coleman Lantern fuel.
Always try to test any cleaner somewhere where it won't show first.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-10-2010, 01:24 PM   #5
_
greetings dachele and welcome.
there are 100s of threads here on this very common topic below are a few really useful 1s.
http://www.airforums.com/forums/sear...archid=2012423
short answer is that this is largely a characteristic of older VINYLs...
and cleaning (beyond the basics) if pointless.
any chemical that REALLY would remove the tackiness will dry/damage the vinyl.
__________
1. try an auto detailing product for dashes or vinyl,
this will make the surface NOT sticky and add gloss.
or
2. try future vinyl FLOOR WAX which will do the same thing,
but may last longer.
expect to reapply 1-3 times a year depending on heat and use.
cheers
2air'
Old 10-10-2010, 10:06 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
I use Westley's whitewall tire cleaner with a Scotchbrite sponge, wearing rubber gloves. I wipe it with a dry cotton towel after scrubbing.
Old 10-10-2010, 11:11 PM   #7
69AirDream's Avatar
1969 27' Overlander
Springfield , Missouri
I had the same problem and found several people on the forum recommend Krud Kutter. I tried it and it worked. Available at Lowe's.
69AirDream is offline   Reply With Quote
Old 10-11-2010, 07:09 AM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
We have used Super Clean degreaser. We found it at Wal-Mart in the automotive section. Just sprayed it on full strength, and wiped with a wet rag several times to rinse.
Best Regards,
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 10-11-2010, 07:13 AM   #9
Wabbiteer's Avatar
Jupiter , Florida
I tried everything in the book and have quit playing with small solvents or special cleansers - Hot Spic'n Span and a coarse nylon bristle scrub brush makes it like new and makes an even appearance from panel to panel.
It is messy and you'll remember muscles you had forgotten plus you'll have to have a dozen wiper towels and change them often but it simply works, on old nasty trailers some places will need two or three treatments. I used a bucket but you could use a small sprayer or blot it on with a sponge - scrub till the surface brightens - wipe it off with dry towel, repeat if necessary - then a clean damp towel wipe down to rinse the detergents off.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
I have sticky ceiling jump Upholstery, Blinds, Walls & Interior Finishes 30 12-05-2009 12:44 PM
Sticky Steps audiobox Doors & Locks 2 04-13-2007 09:58 AM
sticky walls arodriguez60 General Interior Topics 18 07-24-2005 11:01 PM
sticky? eubank Forum Admin, News and Member Account Info 2 01-18-2005 01:18 PM
