Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 11-23-2008, 07:05 PM   #21
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Originally Posted by goransons View Post
...As far as ribs conducting heat/cold etc I'm sure they do, when we get snow and have the heat on in the trailer, after some time on the outside you can see the ribs only (not where the fiberglass is) but we've never noticed much difference on the inside.
In humid climates or very cold weather, the inside skin adjacent to the ribs have been seen to sweat or have a frost line (from breath moisture). So the ribs really do conduct quite a bit. That's one reason that it's not so productive to do "special" insulation, unless you also tape all the ribs and stringers with foam tape--don't if even doing that makes the "special" insultation, eg, bubble, worth it. I think the local improvement in R-value gets lost in the noise due to the ribs, leaks, etc.
Zep
Zep@Charmedquark.net
Old 11-23-2008, 07:07 PM   #22
Alumanutz's Avatar
1966 22' Safari
Chico , California
My 66 has thick black stuff sprayed on the end caps. The sides don't have it. They sell the truck bed coating at the auto parts store as a roll/brush on. I don't know if it is compatible with aluminum.
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Old 11-23-2008, 08:25 PM   #23
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Alumanutz, you're correct, thats how mine is, end caps, and actually a couple spots around the door, but that might have been a repair at some point. I'd call a trusted body shop and ask about it. I think I recall people spraying the front banana wraps with that stuff in some threads I read in the last year. Might search those and find out how it held up. Certainly being outdoors, and pelted with road debris would be harder on it that inside the walls I would think.
goransons is offline   Reply With Quote
Old 11-23-2008, 08:31 PM   #24
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you look at the picture of my trailer after a light snow, you can see the snow has melted right at the rib lines.
Richard
Plywood Thickness Sundance Repairing/Replacing Floor &/or Frame 7 07-22-2007 07:09 AM
wall thickness chas trotter General Repair Forum 2 07-20-2007 06:25 PM
Floor thickness??? BB 55 Bubble Repairing/Replacing Floor &/or Frame 1 03-18-2006 07:10 PM
Thickness of interior panels? crgintx Ribs, Skins & Rivets 4 10-17-2004 07:06 PM
Skin thickness Steve St. J Ribs, Skins & Rivets 1 09-23-2003 10:57 AM
