05-01-2008, 09:31 AM
Livingston
, Montana
Is covered storage necessary?
Hi everybody, Newbie first-poster here. I don't have an AS yet, but want one bad. I read some threads here; it seems many (most?) store their AS inside or in a carport. My question is, is this really necessary? I have space at my place, but it is not covered. Should I factor the cost of a carport or pole barn into my AS budget (which may not make it as it is!). I live in Livingston, Montana. We get some snow, but less than 20" of preciptation per year. It gets plenty cold.
THANKS!
Getting tons of good info on this site!
05-01-2008, 09:48 AM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
We keep our Caravel outside. Inside would be nice. It would stay cleaner parked inside, but outside is OK if it is secure. We have cardboard covers for the inside of the windows to prevent sun rot. There is a large motor home parked on the sunny side, so we don't bother with tire covers.
05-01-2008, 10:12 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
We too store ours outside without a problem.
Ideally, I would love to store them indoors and heated and sometime that may be feasible...but not here, not now. You didn't mention if you are looking for a current/newer or vintage.
Like Jim mentioned, the biggest downside is that it gets dirty and if you are talking vintage, that means more frequent polishing. Fortunately, our climate is very dry here, so the oxidation process is slower than in high humidty areas.
We use the silver bubble insulation in the windows & skylights to protect from sun damage and open it up, go inside and check on it periodically through the winter months to look for hints of leaks (or creatures) before they get out of control...I'm happy to report we haven't found any of either!
Shari
05-01-2008, 10:22 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Not Really
WELCOME TO WALLY WORLD
Both A/S we've owned have been kept outside.
Keep the skin clean, waxed/sealed and you should be fine. Cold/dry, not so
bad, high humidity, salt air, moderate temps not good.
The only concessions we make here in snowy Buffalo,
remove wheels/tires and batteries.
cover a/c and all roof vents and skylight.
Just follow the owners manual as far as Winter storage goes and you'll be
fine.
2006 30' Classic S/O
Mohrsville
, Pennsylvania
We store ours outside, but would love a 40' X 40' pole barn to store them both, but that ain't in the budget right now . I polish mine at least three times a season and wash before and after each camping outing and the finishes seem to be holding up nicely. During winter months I set sticky mouse traps in case any of the critters get inside (none yet...knock wood). I also make a weekly inspection trip to the end of our property where they are stored. It is a short walk, but can be interesting in the snow.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
05-01-2008, 11:20 AM
2020 30’ Globetrotter
2001 30' Excella
Phoenix
Ours is stored in a public storage facility with a roof. Here in AZ it makes a very big difference in the ambient temperature inside the AS. We can tell a big difference when we have it home and in the sun. Ours only gets sun exposure in the mornings and everything else is shaded all day.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
05-01-2008, 11:54 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Welcome from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
We store Lucy outside when she's not on an adventure.
We'd like to have covered storage, but don't right now.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
05-01-2008, 12:08 PM
2008 27' Safari FB SE
Cumberland
, RI
I'm lucky enough to have a 40'x20' RV port, or as others here have called it here an airhanger. It works out great for shade, working on and polishing in any weather etc. If you have a choice and can swing it I recommend it highly. We ordered ours from TNT in So. Carolina. It was $4500 installed about 5-6 years ago. They did a great job and it looks great. I have a few pics in my thread "picked up new safari today" if you want to check it out. Good luck and welcome.
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
WBCCI #1199 - AIR #23847
NEU
LIFE IS GOOD
05-01-2008, 01:02 PM
Cyclist
2007 28' International CCD
Windermere
Living in Fla we get high humidity, lots of rain, and scorching sun. I worry about seals and plastic covers.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
05-01-2008, 01:03 PM
St. Cloud
Hi GroovePoppa -- Welcome to AIR Forums!
You can make do with either option. Getting Airstreamin' when you are ready is the most important issue. New or used, I wouldn't hesitate to get your Airstream and over the next couple years figure out how you want to prolong its good condition going forward.
There are just 'costs' to storing out in the sun. Jack Canavera's 2004 Classic's air conditioner cover turned punky and had to be replaced after 3 seasons or so out of doors; I believe he stores under cover now. With us having a newer unit I sure want to store in a garage.
Covers for hand cranked passive roof vents (not Fantastic Fan covers) that Airstream has used in the last handful of years are awfully ultraviolet sensitive -- so much so that when it goes bad most folks would just install a 2nd Fantastic Fan or other powered vent. All Airstreams with clearcoat on the skin will have problems after too few years -- that would just be accelerated by storing outside; eg, what's it feel like putting your bare leg up against an aluminum boat or canoe at midday in June.
We'll give you the secret handshake when you tell us you've made the purchase!
05-01-2008, 01:16 PM
Hernando
, Mississippi
We poured a slab and built a 32X14 shed for our Classic. I worry about hail here in MS during storm season (which lately has been 12 months out of 12 months). It also keeps the sun off the top, most of the side, and out of the windows. We are adding a wall 3/4 the way up soon, so it will be practically 'inside'. We added water, 30 amp power and a sewer dump to make it really nice.
Not cheap, but thought to be worth the investment to protect our investment.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
05-01-2008, 01:17 PM
Austin
He's not kidding, they won't give you the secret handshake until you own one, I've tried...
05-01-2008, 02:46 PM
1973 31' Excella 500
Marysville
Hello Groovepapa,
I've heard that you should not tarp an Airstream as that will fog the clear coat. So if you do store it outside don't tarp it. Can anyone validate this?
05-01-2008, 02:55 PM
Livingston
, Montana
Thanks for the info everyone-I will proceed with "the dream" and I'll be hittin' you up for the secret handshake someday (maybe soon?).
05-01-2008, 03:04 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by Not Done
Hello Groovepapa,
Not sure about fog'n the clearcoat.
But know for sure that if you LAY a cover over anything, car, boat or rv
moisture WILL get between the cover and unit, which is never a good thing.
Plus the wind can cause significant damage with a poorly fitted cover.
Ask me how I know...BTDT.
05-01-2008, 03:29 PM
2016 23' International
Centennial
Mine is outside in Colorado, where it's generally dry, however, I have built a shelter over it from one of those portable garage kits (plastic garage) that you buy at Checker Auto parts. My thought is that our frequent spring hail storms can beat the heck out of the portable garage and not hurt the airstream. We will see what happens.
Steve "Centennial Man"
05-01-2008, 03:36 PM
1954 22' Safari
Deerfield
This is a great thread - I'm thinking we'll do the tire covers (never heard of anyone taking their tires off before like Robert Cross! That's an interesting one and probably not a bad way to go.
We're storing outside and near a bunch of overhanging trees, actually. I'm hoping we can get permission to erect a metal pole/nylon canopy, like the kind you see at art fairs.
If anyone has a lead on that type of canopy I think it'd be a good fit in people without the "indoor storage" kind of budget.
05-01-2008, 06:27 PM
1999 23' Safari
Perrysburg
, Ann Arbor
Re tarping:
My owner's manual specifically says not to ... but the reason is that if it flaps in a breeze, etc., will scratch the surface / clearcoat, etc. Mine lives indoors when not "out" and the POs kept it inside also. It's nine years old and looks like new to my eye.
05-02-2008, 05:58 AM
Centennial
Brad....I bought mine at Checker Auto Parts for $100 on sale. I anchored it in buckets of cement to give it the weight it needs to anchor it down. The roof is high enough that the material doesn't "flap" on the trailer and cause any scratches. It protects her from sun, snow and we will see how it does in hail storms.
05-02-2008, 06:27 AM
2000 34' Excella
Tucson
Outside. But lots of sun damagage. Had to replace all plastic on the roof this season as I was starting to lose stuff when on the road. Inside would be cleaner as well, but the main thing is that it sure would be nice to get it out of the sun.
