02-08-2011, 07:35 AM
Wise Elder
2010 30' Classic
South of the river
Frozen jug of pink stuff
Today it's -15 degrees (F) outside. I thought it would be a good day to recheck my ductwork modifications so I went out to the trailer.
I had an extra gallon jug of the pink RV antifreeze in the trailer, on the floor. I bought it from NAPA last fall. Freeze protection to -50, says so right on the bottle.
It was partially frozen.
Now it seems like this is a bad year for this kind of thing because I've had problems with windshield washer fluid freezeup which has never been a problem in the past. I wonder whether the manufacturers of these products are reformulating them for cost savings leaving the melting point higher than before.
I would caution those relying on the pink stuff that perhaps there might be something to be said for compressed air.
02-08-2011, 07:39 AM
2000 31' Land Yacht
Central
which brand? country of origin?
02-08-2011, 07:51 AM
1969 31' Sovereign
Broken Arrow
, Oklahoma
I have heard that RV antifreeze can turn to slush but will not freeze solid and burst pipes.
One of the reasons why they say "Do not dilute".
Garry
02-08-2011, 07:52 AM
Greeeneville
, Tennessee
I have seen a NOTE on some jugs of the "pink stuff" that indicate it may form a "slush-like" mix, but it will not freeze solid to cause damage.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
02-08-2011, 08:37 AM
Wise Elder
2010 30' Classic
South of the river
It's the store brand, Balkamp I think.
And yes it is slushy not solid.
That's probably fine for traps or something.
I wonder whether it might damage a sprayer, pump, or showerhead though.
02-08-2011, 08:50 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Pink stuff will slush up, Don't know if it can freeze solid, but it will be slushy at - 20 degrees. I have seen it slushy but not frozen
Even if it can freeze at some temp. as long as it doesn't EXPAND in the process there would not be a problem,
I have never had a plumbing problem using the stuff in 40 years, but I have had problems from blowing out lines as one or 2 drops of water in a toilet valve can do it in
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
02-08-2011, 08:51 AM
1966 22' Safari
Hilltop Lakes
Water is a most unusual fluid, in that it expands when it freezes. That's why it's so hard on pipes. If I remember what I learned in high school science classes, other liquids don't do this. They get smaller when they freeze.
Hopefully, your antifreeze has very little water in it and mostly some other stuff.
02-08-2011, 11:56 AM
2023 16' Basecamp
Chgo. N.W. Burb's
I had some from Menards ,Brand ?. Frozen in Garage. Since that I Blow lines out after pumping thru pink stuff! Should have room to expand in P traps.
