10-21-2015, 01:17 PM
2011 27' FB Classic
Camp Hill
, Pennsylvania
Do you take your flatscreen tv out in winter??
Will the cold hurt my flatscreen tv? Should I take it out of my Airstream for winter? Thanx all.
10-21-2015, 02:01 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard....
Yes & yes
There really isn't any L in the LCD, but extreme cold for an extended period can damage the panel.
Why take the chance?
2008 25' Classic
Full Time
I've taken mine out and left it in over the last couple of season. Seems to survive the 0F degrees cold we had last winter. However, its probably best to remove it.
Kelvin
10-21-2015, 02:02 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I leave mine in and haven't had a problem.
2019 Ford Expedition Platinum
10-21-2015, 02:04 PM
2015 25' Flying Cloud
Bend
, Oregon
Should be fine. If in doubt the TV manufacturer usually list operational and storage temperatures in the specs in the manual.
10-21-2015, 02:08 PM
2002 19' Bambi
Northwestern Ontario
, - on the backside of the map and just above the big green spot
Leave ours in overwinter - no problems.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
10-21-2015, 03:18 PM
Bend
, Oregon
The samsung in my 2015 is good to use at 50F and can be stored at -4F. See pic attached.
10-21-2015, 03:41 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Nope. I've found the more stuff I leave in it the easier it is to pull chocks in January and head to Florida! Everything you remove you gotta reinstall....and I can't imagine you could do much damage to a flat screen from cold weather. They surely ship them in the winter in unheated trucks.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
10-22-2015, 08:21 AM
2011 27' FB Classic
Camp Hill
, Pennsylvania
My logic for leaving it in is that I don't have a good safe place to store it in the house. Also the odds of it getting broken in transit are higher. I will check my owners manual about storage temperatures but at this point I am leaving it in the AS. Unless someone makes a convincing argument otherwise.
10-22-2015, 08:39 AM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
If you leave it in, the best thing to do is make sure it has fully warmed up before you turn it on. The frost can cause condensation that could short out if not fully dried out first.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
10-22-2015, 09:44 AM
Oswego
Mine live in my basement over winter.
-Rich-
10-22-2015, 09:47 AM
1993 34' Excella
, Maryland
Mine stay in the trailer year round. So far, no problem in the last 10 years.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
10-22-2015, 10:56 AM
1977 31' Excella 500
Berkeley Springs
, West Virginia
What Shacksman said.
The directions with my Panasonic said not to OPERATE it below 45 degrees or so. Said nothing at all about storing it cold. They haul them in cold truck trailers all the time, store them in warehouses that aren't always hot, etc.
Had mine out for two very cold winters and it's been fine. I just warm the trailer up and let it heat soak for a half hour or so before turning the TV on.
Best of luck,
- Jim
10-22-2015, 03:55 PM
2002 19' Bambi
I think if you head down to any of your local RV dealers tomorrow you will find that every trailer with a TV installed at the factory will remain in the unit over winter.
(Oscar Wilde)
10-31-2015, 07:38 AM
1994 34' Excella
Kalamazoo
, Michigan
LED tvs can be stored and operated at sub zero temps. That's like the display panel in a lot of cars...
10-31-2015, 08:39 AM
I'm In
, Kentucky
I've left my old LCD, pre-digital, in the AS for 2 winters, no problem
My neighbor has a 45" LCD mounted over the back door of his house, under an open air roof, been there for 2 winters now, it seems to be fine.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
10-31-2015, 08:44 AM
Oswego
Not cold related. Mine are removed, along with anything else of value for theft reduction.
I put a little sign in the window, "all electronics and valuables removed for storage".
I also have a nest cam installed as well as a Nest provided notification sign in the window.
-Rich-
10-31-2015, 10:09 AM
Normal
Never taken ours out, never had a problem.
Maggie
