Old 10-24-2008, 06:07 PM   #1
Lifting to fit larger wheels and tires
Can my 2005 16' Bambi be slightly lifted so I can fit a larger tire? I've looked at the axle mounting, and the only adjustment I can see looks like it would lower the trailer a bit rather than lifting. But I may be looking at it wrong.
Any ideas or directions? I have searched for this topic, but could not find any relevant threads.
Thanks, Ed
kd7trx is offline   Reply With Quote
Old 10-24-2008, 06:16 PM   #2
"Cloudsplitter"
2003 25' Classic
And the reason for that would be.....
ROBERT CROSS is online now   Reply With Quote
Old 10-24-2008, 07:06 PM   #3
SteveH's Avatar
Common Sense , Texas
Thanks, Ed
If the axle mounts on your trailer like mine does, the only way would be to fabricate a sort of spacer plate.
Regards,
Steve
Old 10-25-2008, 05:48 AM   #4
Kevin245's Avatar
Be Careful
My experience has shown that height adjustments in the upward direction change the COG (center of gravity) can cause handing issues. Some good...Some not so good. Conditions such as instability, sway problems and possible changes in braking behavior are the not so good ones.
Regards,
Kevin
William C. Swinney
Old 10-25-2008, 07:07 AM   #5
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Larger Tires
Call Robert at Roger Williams Airstream 800-378-5883.
They started the 16" wheel and tire modification.
You change the arm angle from 25 too 35 degree down.
I have this mod. and have not had any problems with cog are braking.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 10-25-2008, 07:55 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
Are you sure you need the raise the trailer? I have put 225 75 16 tires on my trailer and have 5 in. of clearance. More important is make sure the wheels you are considering have the right off set or you will have a problem with the edge of the wheel well.
2004 Excursion 4x4
Will these wheels fit my 1976 Argosy??? AndyPenny Wheels, Hubs & Bearings 3 03-02-2008 02:57 PM
Help re wheels and tires. Richard Booth Member Introductions 9 09-21-2007 08:31 PM
Need wheels and tires for my 65 GT? tinman Tires 3 06-13-2006 08:45 PM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
New Wheels and Tires HELP Craftsman Wheels, Hubs & Bearings 5 10-27-2004 03:32 PM
