Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 03-22-2003, 03:03 PM   #1
ipso_facto
Profile:
Electric tongue jack not extending
I cannot extend my electric tongue jack down to raise the trailer. The motor in it is running as if normal but the actual jack is not moving at all. Why is this going on? My unit is a 86 Excella.
Could this be related to the fact that I am not plugged into the shore power?
I checked the battery and it is "Good".
Also the trailer is not level at all side to side, could this be related to the problem?
Is there a way to manually lower the jack?
How often do these jacks break?
ipso_facto is offline   Reply With Quote
Old 03-22-2003, 03:42 PM   #2
femuse
Profile:
If the motor is running, it sounds like a gear problem.
Nothing to do with how level the trailer is or on shore power: it's always running on 12v.
Some have a manual bypass. The one on our 1974 looks original and still working OK.
femuse is offline   Reply With Quote
Old 03-22-2003, 04:09 PM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
There is a clutch in many of the tounge jacks. Yours may be MIA.
If you remove the head of the jack (the motor assembly) There should be a slot in the top of the screw portion on the jack itself. You my have a small crank handle that came with your unit and you have yet to find what it fits. It fits in this slot so you can manually raise or lower the jack. You can also test the motor/clutch by grounding the head assembly and flipping the switch. You should see something turning inside.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-22-2003, 04:34 PM   #4
j54mark
Profile:
If you pull the head, be aware that the motor is "timed" to the drivetrain. You can't just plop it back on anywhere. My manual has instructions, but it is 50 miles away right now.
Mark
Old 03-22-2003, 04:48 PM   #5
ipso_facto
Profile:
That's what it was. I was able to take off the cover - barely, the bolts were rusty (but carb. cleaner helped). The main gear inside, the biggest one right in the middle is really worn. I took it out, looked at it and put it back in. It's really worn in one spot but most of it looks good. I saw that the other gear gets stuck right in this worn-out spot and they lack the friction to turn.
I was able to get it moving and lower the jack about a foot down. But once it hit the ground, the gears started slipping again.
It seems like a 25c repair. Where can I get this gear, made out of metal ideally?
(It seems like this one is made out of plastic although I wonder if they had reasons for that)
PS
I did not remove the head of the jack. Just the cover.
Old 03-25-2003, 11:58 AM   #6
ipso_facto
Profile:
I looked in the manual and here is what I found:
It is H&H Power Jack.
The part number is 10051. It is called 2nd/3rd Gear set.
http://www.barkermfg.com/product_pag...wer_jacks.html
Best news is, they make a metal upgrade instead of that fragile plastic gear.
1986 Excella, 32' - FOR SALE ON EBAY, AUCTION # 160034864277
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
Electric Jack Dbraw Jacks, Stabilizers, Lifting and Leveling 17 05-22-2006 05:33 PM
Disabling Tongue Jack Cracker Jacks, Stabilizers, Lifting and Leveling 10 11-14-2003 11:32 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
