Old 02-27-2004, 12:53 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Sikaflex 1a sealant
Everytime I want to do a small job on the trailer that needs vulkum I find my single tube is out or dried up.
I don't have a local place to get it so it's a pain to order it all the time.
I found my local Yardbirds started carring Sikaflex 1a in Aluminum color. It is a construction sealant polyurethane.
I seen this mentioned here before. Will it replace my need for vulkum?
-Tim
1960 International Ambassador 28'
2001 Silverado 2500HD CC 6.0L 4.10
Check out my book: Restoring a Dream
Check out my Airstream book for kids!: Airstream Adventures
theVAP - Airstream Podcast
Safari Tim is offline   Reply With Quote
Old 02-27-2004, 02:49 PM   #2
Images: 59
Sikaflex 1a
All I can tell you is:
Elongation
Sikaflex 1a = 500%
Vulkem 636 = 400%
Adhesion on aluminum
Sikaflex 1a = 3.4 N/mm
Vulkem 636 = 3.5 N/mm
Tensile stress
Sikaflex 1a = 1.37MPa
Vulkem 636 = 1.37 MPa
Shore A hardness
Sikaflex 1a = 35 to 45
Vulkem 636 = 25 to 30
And the price seems to be similar.
Sikaflex is approved by Canadian Food Inspection Agency, whereas Vulkem 636 is approved by USDA. In case you want to eat off it.
Old 02-27-2004, 03:22 PM   #3
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thumbs up Thanks Mark
Sounds like it should work based on the specs.
Has anyone been using it and been pleased with it?
-Tim
Old 02-27-2004, 04:00 PM   #4
JPAIRSTREAM's Avatar
1972 31' Sovereign
Images: 47
Sika flex is used at Airstream to seal the inside shell. Vulkem is no longer used to seal the inside of the trailer. If you go to the Airstream store you will see they sell it there..
This is FACT not fiction.....
JP
JPAIRSTREAM is offline   Reply With Quote
Old 02-27-2004, 04:12 PM   #5
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Just as an FYI Vulkem will last a long time if you put it in the freezer.
Ken J.
Ken J is offline   Reply With Quote
Old 02-27-2004, 04:37 PM   #6
Images: 59
More info
JP,
Tim's asked for the comparison between Sikaflex 1a, available locally, and Vulkem.
The material that Airstream sells is Sikaflex 221.
Here is the information on Sikaflex 221
Elongation = 600%
Adhesion = 4.4 N/mm
Tensile stress = 1.54 MPa
Shore A hardness 45 to 50
So if you want to buy it from Airstream, that's what you get.
This is opinion, not fact:
Is Sikaflex 1a is better than Vulkem 636? Barely.
Would it work? Probably.
Old 01-22-2015, 02:24 PM   #7
Paulizor's Avatar
2010 19' International
Felton , California
Sikaflex 1a can take day to even get tacky and a week to cure. Sikaflex 221 cures in a day.
Paulizor is offline   Reply With Quote
