Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 09-16-2007, 05:07 PM   #1
Crawdad
Crawdad's Avatar
Profile:  1998 30' Limited
garden Ridge , Texas
Leaky Airstream
I recently purchased a 1998 30 foot classic and it leaks water around the curved windows in the front of the trailer. I have been told by a very reliable source that the water is likely coming in from the top of the trailer. I just found out that some of the front top segments have been replaced on my trailer(before I bought it) and I did not know it. They used olympic rivets which I am told are not really waterproof. I have been advised to put silicone sealant on each of the rivets in an effort to seal them off. Have any of you had any experience with this kind of deal? Thanks for your feedback.
Rudy
Crawdad is offline   Reply With Quote
Old 09-16-2007, 06:10 PM   #2
Moonstruck
Commercial Vendor
Moonstruck's Avatar
Profile:  1986 31' Sovereign
Sherfield English , Hampshire
Hi Rudy,
thought about this! Think it might look messy putting silicone sealant on the rivets. I'd go for applying super glue around the rivets to seal them.
Marc
www.silvertwinkie.co.uk
Moonstruck is offline   Reply With Quote
Old 09-16-2007, 06:16 PM   #3
The Flintstones
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
From what I have read one should never use silicone ever.. super glue may work or maybe Parbond as it is thinner and has the ability to seep into the area to be sealed. Good luck
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 09-16-2007, 06:24 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I would use Acryl-R, it is the recomended seam sealer from airstream. It will seep into and seal the leaks. If properly installed the Olynpic Rivets should not leak.
http://[IMG]http://store.airstre....jpg[/IMG]
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 09-16-2007, 06:28 PM   #5
Kevbo10
Profile:  2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
\\ MASSIVE SNIP //
Rudy
mr rudy,
the windows are "radiused", not curved or round...
look at the roof vent(s) first...
and
Acryl-R is the ONLY thing i'd use...
just sayin,
kevin
Kevbo10 is offline   Reply With Quote
Old 09-16-2007, 06:40 PM   #6
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Yep!
You guys got the picture!!!!!
Acryl-R is what the factory (and yours truly) use to seal and re-seal the seams of the Airstreams. Great stuff, and with a little practice, you can get yourself in a Zen-like state and apply the stuff and never see where you did it!
As far as the Olympic rivets go, they should be waterproof as Richard said, but if you suspect them, a little shot of the Acryl-R will actually soak into the seam and give you further protection.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 09-16-2007, 08:52 PM   #7
SteveH
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
Where can a person buy Acryl-R?
SteveH is online now   Reply With Quote
Old 09-16-2007, 09:18 PM   #8
Crawdad
Crawdad's Avatar
Truthfully, the water shows up on the bottom of the radiused windows inside the trailer. I wondering if ther water is coming in where the metal frame and the glasss come together. Maybe I should try caulking with Acryl-r on the outside where the glass and the metal frame come together.
Old 09-17-2007, 01:14 AM   #9
lewster
Commercial Vendor
lewster's Avatar
You can get it direct from the factory, or any well stocked Airstream dealer.
AIR # 10325
Old 09-23-2007, 09:59 AM   #10
huskyfan
Profile:  2006 25' Safari
Copper Falls , Michigan
We have a 25' Safari. It has leaked in the front window, rear escape window and door from the beginning. Jackson Center reset the door and fix that problem. They also replaced the rear window. It still leaks. The dealer fixed it too. It still leaks. The front window has been fixed by the dealer and Jackson Center. It still leaks.
Have heard the mantra - "its an airstream, of course it leaks" Is this true?? Do they all leak??
huskyfan is offline   Reply With Quote
Old 09-23-2007, 10:26 AM   #11
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Just to say
They all have the tendencies to leak, given time...
It's called, "Internal Water Therapy"...
53flyingcloud is online now   Reply With Quote
Old 09-23-2007, 12:04 PM   #12
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
I recently purchased a 1998 30 foot classic and it leaks water around the curved windows in the front of the trailer. I have been told by a very reliable source that the water is likely coming in from the top of the trailer. I just found out that some of the front top segments have been replaced on my trailer(before I bought it) and I did not know it. They used olympic rivets which I am told are not really waterproof. I have been advised to put silicone sealant on each of the rivets in an effort to seal them off. Have any of you had any experience with this kind of deal? Thanks for your feedback.Rudy
If you plan on keeping the trailer for a long time, then I would suggest that you use a long term fix to correct the leaks.
There is nothing wrong with using "olympic rivets" as long as they are used correctly.
You can drill out the rivets that were installed, and replace them correctly.
With the seams open, you can inject vulkem sealer.
Next, put a small circle of vulkem under the head of each rivet, insert it and pull it.
If you replaced all the rivets on the 3 segments on the front top of the trailer, it would take about 5 to 6 hours, from start to finish.
Materials costs are minor. Three hundred olympic rivets are $60.00, Two tubes of vulkem sealer. $20.00.
Shaving the rivets can be done several ways.
Should you take the permanent fix approach, that front end will never leak again.
Most importantly, if the fix is done correctly, it would take an expert to notice it.
Installing "any" sealer over the tops of the rivets will make the trailer look unsightly.
Further, if the rivets leak, then I would bet that a sealer was never put within the seams. Therefore in order to do that, you would still have to remove all the rivets.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
help with leaky roof!! fancy pants Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 05-21-2007 07:26 AM
Leaky rivets? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 04-07-2006 01:16 PM
Leaky Excella Steve Heywood 1997 -2001 Excella 13 02-19-2006 03:35 PM
leaky used 04 28 ccd annw Our Community 16 01-20-2006 10:40 PM
Leaky BW tank jaiman Waste Systems, Tanks & Totes 6 07-30-2005 08:04 AM
