11-29-2015, 10:03 PM
#21
1999 34' Excella
Hillsboro
Anyone here a "patent lawyer"??? I have an idea....about mitigating these leaks.
Peace and Blessings..
Channing
WBCCI# 30676
12-01-2015, 04:20 PM
#22
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I am. PM me.
@living.somewhere.yonder | Instagram
12-02-2015, 09:40 PM
#23
1972 31' Sovereign
felton
Originally Posted by dbj216
I used a little dish wash soap in a container of water. I used a foam brush to soak the vents, seams, exterior lights, window frames, and anything else that looks like a leak source. The soap solution bubbles up like mad when you brush it over a leak.
You can see exactly where the leak is, and a bit of sealant usually takes care of it.
However, a good moisture detector along the interior wall to floor seam is always the prudent thing to do every now and then.
David
i know plenty of sealant postings, but which did you use ?
12-03-2015, 07:11 PM
#24
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
There are several good sealants, but silicone based one isn't good for Airstreams.
I prefer the Acyl-R. I buy it from the Airstream.com store. I like it because it does a great job on seams. And I like to keep the "bead" small so I can see where the leak might be coming from. And the service techs at Jackson Center all had a can of it on their tool boxes.
Acyl-R wicks into the seam pretty good.
David
12-03-2015, 08:01 PM
#25
1986 25' Sovereign
2008 F350, 6.4L diesel
, Oak Harbor, WA
The guys at work use them, they say the ambient noise is the only reason they have troubles, in their case the machine room is full of noisy machines.
I think in our case we will be able to hear the transmitted sound.
The concept was developed back in the 80s. I won't try and explain it, but I would point out that the concept is much more than just sound wave transmission. It involved highly directional transmission, with a much higher speed of sound.
01-02-2016, 06:50 PM
#26
1986 25' Sovereign
, Oak Harbor, WA
OK, I have tried two ultrasonic leak detectors with generators.
Here is what I found:
The low cost one could find large leaks but not small ones, in a scale of 1-10 it could perform as good as the Amprobe ULD-100 when it was on it number 2 setting, not very sensitive.
The Amprobe ULD-100 seems to work well, not sure if it is good enough, I plan on running the soap bubble test and compare that way.
The one leak I was having trouble finding was found by the Amprobe, it was the seam for the front vent.
Steve
01-03-2016, 10:24 AM
#27
1986 34' Limited
1975 27' Overlander
Conifer
Very interesting experimentation with sonic "noise" leak testing. I had not heard of it before. Thanks for keeping us posted on how it works.
Are the units expensive?
David
01-03-2016, 10:37 AM
#28
1986 25' Sovereign
, Oak Harbor, WA
New they are, used the price is reasonable, I took a look this weekend and found two different sales of Amprobe 100 for about $50. Receiver only, but my guess is that if I keep looking I can eventually find a good deal on the the transmitter too.
However, I still need to prove that it works as well as the bubble test.
