Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 01-01-2016, 06:00 PM   #1
Pygmypoacher's Avatar
Black Diamond , Washington
Vista View window restoration - '79
I only found one location on the www that showed someone restoring these windows, retaining the double panes. Which is what I wanted to do. The thought of breaking the inner pane was like considering pulling my own tooth... Ugh. Here's where I'm at so far.
You can kind of see the two steel pieces that are used to lock the frame together. They rust and corrode where you can't tap them apart. I cut the bars and the frame separated easily.
ID:	254943Click image for larger version
ID:	254944Click image for larger version
ID:	254945Click image for larger version
ID:	254946Click image for larger version
ID:	254947Click image for larger version
ID:	254948Click image for larger version
ID:	254949Click image for larger version
ID:	254950Click image for larger version
Only thing that worked to remove the uv protectant and tinting was a fresh razor blade. The butyl came off easily with a putty knife.
Pygmypoacher is offline   Reply With Quote
Old 01-01-2016, 06:02 PM   #2
ID:	254953Click image for larger version
ID:	254954Click image for larger version
ID:	254955Click image for larger version
Old 01-01-2016, 06:05 PM   #3
Now I'm soaking the trim end to get the metal pieces out. Will make new ones from aluminum.
Old 01-01-2016, 06:36 PM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
If you check in the forums here you will find that many owners, myself included, have done what you are doing. It is time consuming but well worth the effort. I did every window in my 1976 Sovereign and only had one that the seal leaked after redoing. There are many pictures and ideas on this forum of how to do almost everything. A wealth of knowledge is here!! Happy New Year! Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 01-01-2016, 07:00 PM   #5
Thanks Chris. I must have missed the posts. How did you get the steel wedges out of the two channels?
Old 01-01-2016, 07:45 PM   #6
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Didn't worry about them. They are only there to align the window and hold it together prior to original installation. I just installed back in the exact same location and used the Oly rivets to align the window in the original spot I marked the frame prior to disassembly so everything went back the way it was removed. Biggest problem I had was finding the vinyl gaskets that go around the outer edge of the window. Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
Old 01-01-2016, 10:31 PM   #7
Thanks Chris.
Old 01-01-2016, 10:34 PM   #8
Here's the work Chris did on his Vista's. This happens to be the one www post I was able to find prior to starting my restore. Thanks Chris.
http://www.airforums.com/forums/showthread.php?t=80814
Vista View Window Questions
Old 01-02-2016, 05:43 PM   #9
Two completed. Will trim the olympics when the vulkem is dry. I appreciate Chris's guidance on the joiner pieces.
ID:	254992Click image for larger version
Old 01-03-2016, 08:15 AM   #10
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
They look good!! Much easier to do with the interior removed. It looks like the opening windows will also need to be redone as well. I found them easier, but it helps to have two people to put them back in the top hinge track. Just curious as to what is the caulking looking stuff on the roof to the right of the Vista's? Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
Old 01-03-2016, 01:04 PM   #11
I had cleaned and lightly sanded the aluminum around the windows. At the angle of the photo and direction of the sanding it just looks darker. I'd dressed the vulkem in close to window.
Old 01-03-2016, 02:37 PM   #12
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I was actually trying to figure out what that was on the roof about a foot to the right and higher up. It looks like a patch of some type. Just curious, as I haven't seen that on the roof of an airstream before!!! Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
Old 01-03-2016, 10:53 PM   #13
Ah, I patched the fridge vent. Instead of an eagle I went with a duck. Cut a bear for the intake below. My patches are all animals. More in my post on the Exterior/skin/rivet area. Click image for larger version
ID:	255059Click image for larger version
Old 01-04-2016, 06:05 PM   #14
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
That explains things. Looks cute!! Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
Old 01-05-2016, 03:34 PM   #15
Sunnysideup's Avatar
1988 34' Excella
Rocky Mount , North Carolina
I love the look of this! You should patent it. I don't think we can do it on our A/S but it sure looks gorgeous! It was suggested to us to put a flying flag decal on the side of ours to cover where the side is no longer perfect due to some po who wasn't paying attention to where they were going. Don't suppose anybody knows where we could get one??
Sunnysideup is offline   Reply With Quote
Old 12-15-2018, 06:25 PM   #16
1977 31' Sovereign
Moab , Utah
Hi there!
I have a 1977 AS and I am at the beginning stages of restoring the windows. I have removed all of the opening windows, but have had a hard time finding a video or much information on removing the vista's. All of the upper vista windows are missing their plexiglass, and if its not super important I would rather not bother with replacing it.
Am I correct to think I need to remove the vista's entirely from the shell in order to properly restore them? I would like to do so without breaking the plexi on the intact ones. From your pictures it appears you cut the aluminum frame of the vista's to get them off. Is this correct? And how did you get them back together on the finished window?
Did you remove your vista's by removing the outer rivets? And then can you walk me through the steps you took to dismantle the windows in order to clean them, re-seal and put them back together?
I understand replacing the black gasket, clearly old and cracked, and re-sealing the outside, but I wonder how hard it is to find that rubber piece that fits around both panes against the metal?
These forums are great! But a lot of combing is necessary to find straightforward information so I'm searching for something concise. Thanks for your advice.
Satchien is offline   Reply With Quote
Old 12-16-2018, 12:10 AM   #17
Originally Posted by Satchien View Post
Hi there!
There's a link in post #8 above that has detailed steps.
Vista View window repair/replacement 83Excella Windows & Screens 16 03-05-2021 08:03 PM
Vista View window repair Bluegirl Windows & Screens 9 03-10-2017 11:38 AM
1973 Vista View Restoration Tripp Windows & Screens 12 11-17-2011 12:11 AM
Removing Vista View window on '68 Overlander 68Overlander Windows & Screens 2 06-27-2006 05:21 PM
Need help with my Vista View window. TBKP's Overlander Windows & Screens 1 07-05-2003 07:58 PM
