Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 09-13-2007, 07:23 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Removing a 1971 Wing Window/ HELP
Before I bugger it up, I would like to ask some advice. I need to remove and replace my single pane 71 wing window. I have 73 and a 74 service manuals (double pane), but not a 71. The 73 and 74 manuals describe significantly different procedures.
It seems though one of the first steps should be remove the "splice bar" which is shown in figure 9 in both manuals in the "Shell" section. The written instructions mentions removing the "exterior vertical tie bar" but does not use the term "splice bar" found in the diagram. Are they the same? The written part of the 74 instructions does not say anything about either a splice bar or a tie bar.
Can someone out there tell me how to remove this vertical bar that covers the frame between the wing and center windows, hopefully so I can reuse it, and where I can get a new one if I need a new one to replace it.
Is there somone out there who has a 71 service manual who can send me a copy of the relevant instructions?
Old 09-13-2007, 07:32 PM   #2
Remove the bar any way that you can. Destroy it if necessary.
You will find it very corroded, therefore useless.
New bars are not available, but not to worry.
No one uses that bar anymore.
Simply apply enough Vulkem sealer on the backside of the complete window, and along the straight edge.
If necessary, apply additional vulkem on the vertical seam when finished. Remove the excess.
Make sure you use plenty of vulkem.
DO NOT scrimp with the sealer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-13-2007, 08:01 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
Thanx Andy,
Let's see if I got this right. Your recommendation is VULKEM, right?
Eureka, I just figured it out! The duct tape on my wing window separating the interior from the exterior is grey. Vulkem is grey. Duct tape is sticky and gooey, Vulkem is sticky and gooey. Therefore applying syllogistic logic Vulkem is liquid duct tape.
Old 09-13-2007, 08:16 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I think 72 is the first service manual. I have that - did 72 have double pane windows.
71 Safari Wing Window replacements don't fit 1971safari Member Introductions 16 06-04-2011 02:17 PM
wing window aquarium HELP!!! Reg Windows & Screens 1 09-02-2006 10:23 AM
Rock guard for wing window? SilverToy Rock Guards, Segment & Window Protectors 5 05-11-2006 06:59 AM
Water in Wing Window! Navigator Windows & Screens 9 01-03-2004 09:07 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
