Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 07-29-2017, 02:53 PM   #1
PianoTech
tjplus's Avatar
2017 27' Flying Cloud
Lansdale , Pennsylvania
New window fail
Yesterday before leaving our campsite we went through our usual pre-flight check making sure everything was turned off shut down Windows closed tightly. We drove for 3 hours pulled over to have lunch and realized that a window was missing. There were shards of shattered glass and the window struts as you can see in the picture but no window. Has anyone else had this issue? We are certain it was locked and the only thing we can figure on is Hardware failure. Click image for larger version
tjplus is offline   Reply With Quote
Old 07-29-2017, 04:36 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Spontaneous window combustion actually has several threads here on the forum. Not sure if they ever answered why it happened.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-29-2017, 06:20 PM   #3
Retired.
. , At Large
If it makes you feel any better, this has been going on since the mid 1960s with the exploding Corning windows.
Old 07-29-2017, 06:49 PM   #4
PianoTech
tjplus's Avatar
Thanks. I didn't know. I wonder what Airstream official position on this might be? We refused to let it ruin the remainder of our vacation.
Old 07-29-2017, 06:58 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Contact them and ask.
MICHAEL
Old 07-29-2017, 07:59 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Having worked in the glass industry for years. I learned that glass is always under stress. The annealing process is meant to reduce the stress.
Exploding glass items occur more often than you think. Any glass item can sit around for years then suddenly shatter.
Old 10-27-2017, 07:10 PM   #7
High Point , North Carolina
Did your latches seem overly tight? I worked for a glass company also and based on your being sure the window was latched, I can tell you it's entirely possible if it was latched too tight, a slight flexing of the trailer body could have been enough to shatter it. Those windows are made like tempered glass. Resistant to impact but not so against flex or edge deflection..
Rfriebele is offline   Reply With Quote
OP-ED: Why Clubs Fail - My Opinion mistermike WBCCI Forum 0 12-31-2009 05:47 AM
Super Jack limiter fail chrisd37 Jacks, Stabilizers, Lifting and Leveling 11 04-13-2009 03:52 PM
Goodyear Marathons from 06 and 07 fail... norsea Tires 10 03-03-2009 09:13 AM
