Old 10-25-2007, 09:55 PM   #1
1961 24' Tradewind
Squamish , B.C
Missing Vulkem
Im pulling the window frames on my 61 Tradewind and I noticed the bottom of the frames have'nt been sealed just the top and sides . Was this done so the window can breath and when I replace it should I seal all 4 sides.
Craig Murphy is offline   Reply With Quote
Old 10-26-2007, 03:22 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Usually that's done so any moisture that does get in can drain out. At least that's true on buildings, I'd assume it's true for AS, but others would know for sure.
Old 10-26-2007, 09:51 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The windows that I have removed have had no sealant between the frames and the skin, just a foam gasket with the inside sealed. On replacement I cleaned off all the old sealant and foam then reinstalled the frames "wet" with sealant between the frame and skin around the whole perimeter of the window. I see no reason that the bottom should be allowed to breath. Water would wick up into an unsealed seam and eventuality cause corrosion in the seam. IMHO
Old 10-27-2007, 10:37 PM   #4
1961 24' Tradewind
Squamish , B.C
Thanks for the info. I think I will seal the hole frame , to keep the trailer as watertight as possible.
Vulkem? Annemac 2005 - 2010 Safari 3 05-17-2007 02:34 PM
Vulkem '70verlander Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 08-25-2006 04:32 AM
Vulkem??? Happycampers Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 08-10-2003 09:27 AM
Vulkem rnabors Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-08-2003 07:40 AM
vulkem art Our Community 1 04-13-2003 07:16 AM
