Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 02-02-2014, 02:23 PM   #21
laducky's Avatar
1978 28' Ambassador
Pacifica , California
Awesome! I wonder if everyone else has just been painting them and calling it good?
laducky is offline   Reply With Quote
Old 02-02-2014, 04:10 PM   #22
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
With 3d printing all the rage. I'm surprised someone isn't printing unobtainium parts.
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 02-02-2014, 04:56 PM   #23
1981 31' Excella II
New Market , Alabama
You thought of making a frame/surround out of aluminum Aerowood? You have the technology you can make it faster, stronger than before.
Perry
Originally Posted by Aerowood View Post
That's to rich for me.
Old 02-04-2014, 12:38 PM   #24
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
As a matter of fact I have given it some thought. No matter how I look at it, welding will most likely be required, I just don't think that I can stretch the corners without splitting the aluminum. Ive also though about making some forming blocks and using "O" materiel but the blocks would most likely cost more to fabricate then welding. I am still letting my mind work this over, but they WILL be aluminum in order to match the center window trim. Most likely what will happen is I will use some thinner, shorter leg extruded angle that I can stretch around the corner and then rivet a wider face piece to it. The welding option would be less work though, and look nicer.
Old 02-04-2014, 03:30 PM   #25
Update.
We have an old left and right single pane wing window closeouts.
They need to be jazzed up, and then molds made from them, for fiberglass replacements which will also be Gel coated ivory.
A couple more weeks and we should have them in stock.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-04-2014, 03:52 PM   #26
1981 31' Excella II
Well maybe Andy will come to the rescue. So Andy, you are going to make your own molds from original parts?
Perry
Old 02-04-2014, 04:14 PM   #27
Perry
Yes indeed.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-04-2014, 05:41 PM   #28
1981 31' Excella II
Good job Andy. There are lots of older trailers will those things falling apart. You should had plenty of business if your price is not too dear.
Perry
Old 02-04-2014, 07:05 PM   #29
laducky's Avatar
1978 28' Ambassador
Looking forward to seeing them! Thanks!
Old 03-06-2014, 04:11 PM   #30
close out
Updated close out that's almost ready.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-07-2014, 01:51 PM   #31
funkill's Avatar
Tucson , AZ
Images: 27
Please set aside one each LH/RH for me!
Also, I'm working on modifying NEW visa view window closeouts to fit. Quite a bit of work, and removal of material to accommodate but, so far, I think it will work well.
Laura
funkill is offline   Reply With Quote
Old 04-04-2014, 11:02 AM   #32
Perry
Perry.
We have outside contractors make some parts to our specs.
We will have the single pane wing window closeouts in a couple of more days.
Samples have been provided and approved.
The closeouts are thin fiberglass and are gel coated ivory color.
We assigned part numbers 34715 and 34717.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-05-2014, 03:23 PM   #33
funkill's Avatar
Tucson , AZ
Images: 27
Perry.
What's the chance they'll fit on the double pane? Need modification to work?
Laura
Old 04-05-2014, 09:19 PM   #34
Laura
We most likely will add the double pane wing window closeout sometime in the future, depending on the demand.
In the meantime, you can cut a little off the fiberglass that rests against the glass.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-14-2022, 10:51 PM   #35
1976 31' Sovereign
Nashville , Tennessee
Anyone know where I can get a set of these now?
zhunt003 is offline   Reply With Quote
Old 03-25-2023, 06:16 AM   #36
Bauxter's Avatar
Sunset Beach , North Carolina
Wing Window Trim
I am shopping for a pair myself. I think they are available again at Inland
https://inlandrv.com/product/airstre...ndow-closeout/
Bauxter is offline   Reply With Quote
Removing a 1971 Wing Window/ HELP Lumatic Windows & Screens 3 09-13-2007 08:16 PM
wing window aquarium HELP!!! Reg Windows & Screens 1 09-02-2006 10:23 AM
Rock guard for wing window? SilverToy Rock Guards, Segment & Window Protectors 5 05-11-2006 06:59 AM
Water in Wing Window! Navigator Windows & Screens 9 01-03-2004 09:07 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
