Old 03-22-2023, 09:01 AM   #1
2019 27' Globetrotter
St. Louis , Missouri
Front rock guard panoramic window seal repair
I’ve got 2 repair questions for my front rock guard windows on my 2019 Globetrotter 27 FBQ.
There’s a thin rubber gasket around the center window rock guard that continually falls out like the first attachment. I’ve pushed it back into place, but it continues falling out, which makes the rock guard window loose in its frame. Has anyone found a longer term solution for this gasket?
There’s a thicker black gasket (other attachment) that’s runs around the exterior frame of my front left window rock guard that’s also come loose. Do I need to replace the entire rubber piece around the window, or can I glue it back into place for now?
ID:	429371   Click image for larger version
flavortown is offline   Reply With Quote
Old 03-22-2023, 02:31 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Put a little glue on it
CRH is offline   Reply With Quote
Old 03-22-2023, 02:36 PM   #3
"Cloudsplitter"
YES
We used 3m weatherstrip cement sparingly applied into the cavity NOT on the strip, making sure the channel & strip are clean.
Brakleen is a good cleaner that evaporates quickly & won't damage the clearcoat.
15yrs SFSG
"You don't know where you've been until you leave, enjoy life" RLC
Old 03-22-2023, 02:47 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
I cut the corners on the skinny ones and shove em back in with a plastic putty knife.
A little glue like said above x2
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 03-23-2023, 11:35 AM   #5
1988 32' Excella
Robbinsville , New Jersey
This is what I did also. Problem seems to start with a little shrinkage that pulls the corners out, the glue probably isn't needed with the corners cut.
Old 03-24-2023, 09:01 PM   #6
wwitsman's Avatar
2019 16' Sport
Charleston , Illinois
I also have had this problem on a 2019 16RB. I removed, cleaned and reassembled all parts OK.
But some of the outside flat rubber was damaged.
What should I do to replace the outside flat rubber?
Is there a caulk or replacement material available?
A Carpenter's Son
wwitsman is offline   Reply With Quote
Old 03-24-2023, 10:02 PM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If the rubber has shrunk or hardened try replacing it. It's not expensive.
The rubber used to hold the plexiglass in place is sold in various diameters. Go to the nearest hardware store and get a pack of the next size up and try that if the original size still does not hold.
It's normal for the corners to pull out as the stuff shrinks over time, but if it doesn't stay put at all you can try larger.
Richard
11018
richard5933 is online now   Reply With Quote
Old 03-25-2023, 02:35 PM   #8
wwitsman's Avatar
2019 16' Sport
Flat outside weather strip
I need this flat weather strip from the window rock guard on my 16RB. Where can I get it?
A Carpenter's Son
Old 03-25-2023, 03:21 PM   #9
Greenjeans's Avatar
2020 16' Caravel
Garland , Texas
I use a screen roller tool to push mine back in. They stay in longer & it's an easy, quick job.
Eddie
Cosmic Turtle
2017 Tacoma
Greenjeans is offline   Reply With Quote
Old 03-25-2023, 09:38 PM   #10
1994 25' Excella
I don't believe what you're seeing is weatherstripping.
When the plexiglass comes from the factory it is covered with a protective film, and Airstream installs it into the frame of the rock guard before peeling off the film.
If my guess is correct, what you're looking at is the remnants of that protective film creeping out after someone peeled it off but didn't get all of it out. To my knowledge, the only 'weatherstripping' holding the plexiglass in place is the round splined rubber cord on the back side which is tucked into the aluminum channel.
Richard
11018
Old 03-25-2023, 09:47 PM   #11
dznf0g's Avatar
Oswego , Illinois
No guess, that's exactly what that is in the pic. It will also come out from under the edging on the stainless corner protectors eventually as well.
-Rich-
Old 03-25-2023, 09:57 PM   #12
TeddyK's Avatar
Boston , Ma
Look closely you’ll prob find clear blue plastic along some edges of stainless panels on fridge. Pp think it’s peeling, like the window it was never fully peeled
2005 25’ Safari Special Edition (International Package)
Sendel 16’s, Michelin Cross Climate, Shell on interior update (floor frame solid) Ampere Time lith batts, Victron Controls, Champion Dual Fuel 3400
WD Eaz-Lift 2 -1200lb bars 2-anti sway brakes
TeddyK is offline   Reply With Quote
Gasket # for seal: 2018 International Front Panoramic Window Leak moby_1851 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 08-29-2020 09:18 PM
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 03:00 PM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
