Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 11-07-2012, 08:29 PM   #1
1975 31' Sovereign
Tupelo , Mississippi
'75 Sovereign front window
in the process of replacing the glass in the front center window, while removing the frame the "L" shaped steel bracket in the corner of the frame broke. Anybody no where I can get a replacement?
Nolehoe is offline   Reply With Quote
Old 11-07-2012, 08:58 PM   #2
Retired.
. , At Large
you would find one in a new window, or a used replacement window.
Old 11-08-2012, 03:48 PM   #3
1975 31' Sovereign
That would be like buying a new truck because I bent a rim. guess ill have to fabricate one
Old 11-08-2012, 04:05 PM   #4
Some hardware stores offer corner brackets made of steel which may work for your issue. A pic of the broken piece may help identify a replacement for you.
Rich the Viking
VIKING is offline   Reply With Quote
Old 11-08-2012, 04:06 PM   #5
Ottawa , ON
While it's unlikely the AS plant has it, what could it hurt to ask?
Coming back to reality, perhaps a larger wrecker, like Colaws, might have it...
Old 11-08-2012, 04:07 PM   #6
Airstream will not sell parts like that.
What kind of glass are using?
What kind of gasket for the glass are you using?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-08-2012, 09:36 PM   #7
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Could you post a picture, as I may have one. I've got a complete front window frame in the basement.
Old 11-08-2012, 09:59 PM   #8
1975 31' Sovereign
Old 11-08-2012, 10:11 PM   #9
Aerowood's Avatar
Arvada , Colorado
Is that the frame around the window itself. Can you dimension it for me as I most likely can just make one.
Old 11-09-2012, 08:11 AM   #10
1975 31' Sovereign
Yes it is the frame that houses the glass, I'll probably just make one
Old 11-09-2012, 09:48 AM   #11
Aerowood's Avatar
Arvada , Colorado
I have the riveted on internal frame
sovereign
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 16 01-14-2022 01:42 AM
1975 Sovereign right front window Jim in Pima Windows, Doors, Locks & Vents 3 04-24-2011 07:51 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
