Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 05-11-2015, 08:19 PM   #1
V Pline's Avatar
1962 19' Globetrotter
DeWitt , Michigan
1961 Window Leaks @ top?
Working on making my 1961 Overlander water proof before installing flooring... But have discovered some wierd leaks at the TOP of the window. Seems wierd!! Anyone have words of wisdom?!! Any advice on sealers too?? This is our first project - I have the Herh Hallmark windows. THANKS!!
V Pline is offline   Reply With Quote
Old 05-14-2015, 05:12 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
I'm giving this a bump as we also have old Hehr windows. A better description might help, weird is kind of generic. Have you tried the hose to see where its coming in. Loose or unsealed rivets or actual window seals ?
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 05-14-2015, 06:07 PM   #3
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I struggled with leaks on mine. Then I sealed the around the rain gutters (or whatever you call them) over the top of the windows with Tempro. I haven't noticed a problem since.
Thalweg is offline   Reply With Quote
Old 05-15-2015, 06:05 PM   #4
V Pline's Avatar
DeWitt , Michigan
I will try the hose... and try to be more specific... and maybe a picture. I will check the windows and the gutters... Did not think of that...THANKS!
Old 05-15-2015, 08:09 PM   #5
Silver Hilton
Mark Wiltrakis's Avatar
1959 24' Tradewind
Astoria , Oregon
1+ to what Thalweg said. I had minor leaks onto the interior surface of both my front and back windows - none at all since I sealed the eyebrows above the windows with Acryl-R.
Mark Wiltrakis is offline   Reply With Quote
Old 05-15-2015, 08:40 PM   #6
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
One of my street side windows leaked like a sieve.
I sealed it, put in a new gasket and it still leaked.
Very frustrating to say the least.
When I removed the TV antenna from the roof and patched the hole left by the antenna my leaky window quit leaking. And has never leaked again.
Dingo Girl is offline   Reply With Quote
Old 05-15-2015, 08:49 PM   #7
reinergirl's Avatar
Hollis , New Hampshire
In my experience ANY of the end cap seams can cause the window to leak. I sealed my entire endcap before the leaks stopped. I think what happens is the water runs down the seam and exits at the window. Good luck!
reinergirl is offline   Reply With Quote
Old 10-22-2017, 12:41 PM   #8
Michael
Michael Meer's Avatar
1961 24' Tradewind
Kortenhoef , Noord Holland
Hello Thalweg,
I am struggling with the same problem as you guys, sealed top window frame replace dripcaps with putty tape and sealed dripcaps on top of, but still leaking waterClick image for larger version
Michael Meer is offline   Reply With Quote
Old 03-28-2018, 07:49 AM   #9
Michael
1961 24' Tradewind
Hi read your post, I have the same issue, did you seal the in or outside of the endcap. Water is coming in between the window frame. Click image for larger version
Old 03-29-2018, 06:07 PM   #10
Central , Mississippi
A pal has been fighting the same leak. He had loose rivets way up the endcap. As stated, water runs down between the segment overlaps and drips out at the top of the window.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
HiHoAgRV is offline   Reply With Quote
Old 03-30-2018, 09:56 AM   #11
Michael
1961 24' Tradewind
Thanks, for you support! Any idea how to find a leaking rivets? Thanks for the help!
Old 03-30-2018, 10:51 AM   #12
2007 22' International CCD
One way is to stick a small suction cup over the rivet. If it stays stuck, it’s not leaking. If it falls off quickly, it’s time for Captain Tolly’s Creeping Crack Cure....
Old 04-02-2018, 11:25 AM   #13
Michael
1961 24' Tradewind
Thanks just order captain tolly's creeping crack cure, never heard of it! Today I discovered that the major leaking is from the last panel on the outside probably the seam , I taped all the rivets with ducktape en water still coming in, last option the seam... In the front are some leaking rivets. Really appreciating you help, we looking for weeks to find the issue. For the seams what's the best product trempro 635 ? Thanks Michael
Old 04-02-2018, 02:34 PM   #14
Look at the thread about sealants. This covers all possible uses.
I have not had a leak issue(yet) so the best I can suggest is look at that thread...
1961 BAMBI :: 1961 Airstream BAMBI DUNSKI Airstream Registry Discussions 0 08-19-2011 08:31 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, and leaks again danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 09-08-2007 08:32 PM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
