Originally Posted by Lothlorian
When I bought my airstream the door had a latch and padlock on it. It came with the trailer. I plan someday to get the orginal door lock fixed but that project is on the back burner. We have been using the padlock on the latch so people cannot break in. It works well.
I want to know how people lock their airstreams from in the inside when you are sleeping. Has anybody come up with a make shift lock for when you are inside so nobody can break in at night. I am going to post a picture of the type of lock we have on the outside. That will stay on until I am ready to fix the door correctly.
Brian
Brian.
There is a huge
SAFETY FACTOR with your exterior lock.
Anybody, at any time, for any reason, can put a pin or a small stick the that lock.
Should you happen to be on the inside, you will not be able to open the entrance door. But, you could open the window, push out the screen, and remove the pin or stick.
BUT if they put some type of lock in that hasp hole, you will probably find that you have a bigger problem than you wish to have.
Fix the entrance door lock, and, get rid of that hasp.
