OK here is the challenge.
You have multiple land line or wireless or both phones in your house/garage/shop etc. Same line, same phone number, AT&T in my case.
No speaker phones or anything special.
You want to pick up the phone in the garage and dictate to your wife,daughter,son,hubby etc in the den to dictate 25 minutes of notes you are observing while under your 59 Edsel or whatever.
You cannot phone the den because you cannot call your own number from one phone to another. So you arrange for your partner to pick up the phone after giving you time to dial any digit or digits to do away with the dial tone.
All is fine for a few seconds, but lo the phone either starts squauking or a robot comes on and says if you'd like to make a call hang up and ...you all get the drift.
Is there a way to maintain the silent blank slate for any prolonged length of time? It seems this used to be possible with some trick. I called the operator she said she had no idea. She had 16 yrs experience.
Customer service said same thing. Said probably could not be done. 5 yrs exp she had.
Also do any know how to make your own phone ring? Maybe that's the answer to above puzzle. This used to be possible (at least to make it ring)?
I know I could use a cell phone and eliminate this need, but that is not what I want to do here.
Oh boy, memories! I used to work for the telephone company. We used to have what we called a "2 Line PBX" service. We would install a red push button on all the phones at the residence or business. You would push the button and it would make all the phones ring on that line. Then you could pick up the receiver and hold a conversation with one of the other phones on your line. That was back when all the central offices were mechanical switching.
Fast forward to present day electronic central offices. What they "can" do now is make your private line into a "two party line", with only one line on it. What you would then do is dial your own phone number. You will get a recording saying that you have dialed a party on your own line and must hang up. Then your phone will ring. When the person on the extension picks up the phone, it obviously stops ringing, then you pick up your phone and you can converse.
I did have this on my line in Ohio, because we had a barn several hundred feet away from the house. I also had friends that worked at the phone company, that made this happen. You may well try and explain this to your phone company and they may think you are on crack. But it can be done if the switch has party line capability.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
I remember back in the 70's there was a way to ring your own number...But i'm too old to remember. Besides we ditched our landline in January 2007...The kids are all mobile and it never got used...
Just curious...Who has a Wife or kids they can dictate too these days? If it does not involve the use of SMS, IM, or Email...mine won't even acknowledge it.
Best of Luck,
Kevin
__________________ Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
The two hand set wireless phone that we have has a paging system that works like what you want. My is labeled INTERCOM. Panasonic is the make.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s. Yes, four kids and two adults in the thing. Happy wife, happy life.
I wonder if you had call waiting, and called yourself, your intended target could then pick up the phone after the beep. It's worth a try, but I don't guarantee it'll work as hoped.
Don't work any more. I used to call my number from my phone, get a busy signal, hang up and the phone would ring. I could pick up and talk to the other phone.
Just yell and ask her to bring paper and pen. You could ask her to hold the light while you read and write. ha
Years ago (1960) we used to be able to dial 1191 then hang up and the phone would ring. This way we could talk to the second phone. It hasn't worked like that for a long time now.
You used to be able to dial your own number, listen for the busy signal to go off for 2 (or maybe it was 3) times, then hang up, then your phone would ring, then you (and anyone else on that line)could pick it up and the line would be open. Haven't done that for a long time, but from the responses to this post, I suspect that doesn't work anymore. Those old Wireless Intercom devices by Radio Shack (and other) work quite well for short distances (between house & barn, ect.)and can be had for pennies at yard sales and such.
__________________ "Reality Is The Leading Cause Of Stress"
"There are only five great men in the world and three of them are hamburgers."
Don't use the telephone company (regardless of which it is).
The phones recommended above with the intercom switches or buttons are your best bet. Basically they have some "centrex" (central office) functions built into them.
Of course if you're upgrading your cell phones you can choose something with "push to talk". It's costly so if you don't need push to talk for something else - such as your job - you'll save a lot of money with walkie-talkies.
Phone sets are pretty cheap and if you've got a decent thrift shop in your area you might even find them there.
Paula
Today is a gift. That's why they call it "the present"
Another option, if you can find it, is to dial the local telephone company's "silent termination" number. Typically every exchange will have both a milliwatt test tone (often, the prefix plus 0020) and a silent term. An old line telephone installer in your neighborhood will be able to tell you. Few exchanges support the ringback codes that we used to use, probably because they haven't figured out a way to charge you for using them.
