05-21-2010, 10:18 AM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
TV Mount
I wanted a mounting method that would allow me to quickly take the TV down and put it face down on the bed for towing. I decided an unobtrusive "slot" would be stable enough for using the TV and quick for dismount.
The "slot" itself is designed to be removed, leaving only two small screw holes behind. It's mounted using nutplates and aircraft screws, so it's plenty strong. Fabrication was complicated only by my desire that it look nice--basically it's two pieces of sheet metal with spacers at the end, plus some flush riveting. The rear piece is taller so that it protects the fridge wall as the TV mount is inserted and removed. The photo on the left shows a small piece of "L" channel inserted in the slot.
The reflections on the side of the frige make it hard to see exactly what's going on, but this is "slot" as it's mounted on the fridge wall. The wall is 0.032 alminum, so it's not very stiff in and of itself, but there is a 3/4" rib behind the wall (shown by the green line).
AZFLYCASTER PM'd me with a question about this topic, and included this link to some nifty mounts. I'm going to get two (of the other ones at the site)! It will only take a foot or so of "L" channel to adapt them to the "slot."
Zep
06-06-2010, 09:51 PM
2002 25' Safari
Dewey
Just to follow up what Zep said. This is the end result of my TV mounting. The TV will be detached when traveling leaving just the bracket on the wall. The TV can be rotated around the partition and will then be viewable from the front area for the trailer. When not in use the power cord and signal cable will be in an overhead out of site.
Richard
11-22-2010, 12:11 PM
1965 26' Overlander
Scottsdale
, Southwest
Hi Richard,
Shawn and I are looking to install a tv with the same mount in our AS same location as well. The only concern we are having is the very thin wall panel wood and how to reinforce. Also how do you hide it on the back side of the wall , where the bolts / reinforcements go, which is in the kitchen in ours? Did you guys put up some art or something to cover it? Also where did you purchase your mount?
Thanks for your help.
11-22-2010, 01:04 PM
2006 19' International CCD
Olathe
, Kansas
Here is what we did so we could watch movies in bed and have it rotate and store over the fridge.
11-22-2010, 03:29 PM
2002 25' Safari
Dewey
Originally Posted by NicheVintage
Hi Richard,
I took a piece of oak (4"x16") and stained it to match my existing walls, then mounted it on the opposite side of the wall. It is held on (vertically) by 4 wood screws and the two screws on the mount. You can see the screws in the picture I posted earlier. There are a few things on the other side of the wall that help hide the wood as well, but I think it looks fine.
The arm and the TV were purchased at overstock.
Richard
11-22-2010, 06:20 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
The edges of the walls seem to be solid rather then hollow like the center of the walls.
Here are photos of how I mounted a 22" flat screen using a mount that allows the TV to swing from the front of the trailer to the side twins. I got a piece of 2"x1/8" by, I think 6 or 8 feet long at Home Depot. From that piece I made the nice shiny plate to go on the galley/living room side. and a piece to go on the back side of the wall, sandwiching the wall between. That distributes the weight of the TV and hanging bracket down the length of the wall. In one of the photos you can see the longer piece on the bedroom side of the wall.
For travel I mounted four flat drawer handles to the wall and use straps with Velcro to hold the TV against the wall when going down the road. Everything from Home Depot. All was done two years and six thousand miles ago.
11-22-2010, 06:40 PM
R n B
1965 17' Caravel
1961 24' Tradewind
Ephrata
For our 65 Caravel I used a mount that we purchased at Fred Meyer for $40. The tab at the top when pushed in releases the TV portion of the bracket so the TV can be lifted vertically to remove the TV from the wall. The bracket swivels and tilts.
11-22-2010, 09:10 PM
1965 26' Overlander
Scottsdale
, Southwest
Jim - How thick is your wall panel? Ours is only 1/4" max... It appears from your two shots that you did an allen bolt on the living side with a nut on the backside. I just wonder if this system would work in that old vintage mahogany that I have...
11-22-2010, 09:40 PM
1965 17' Caravel
1983 27' Excella
The wall in this trailer is about 3/4" thick. 1/8"skin on each side and about 1/2" hollow with 1/2" thick wood supports inside every so often.
I wouldn't use this method on your 1/4" thick solid wall.
I would glue and screw a panel to the back side of your wall to strengthen and spread the weight. A panel perhaps a foot square and 3/8" thick, painted or stained to agree with the back side of the wall. I would glue this panel in place so as to spread the stress over the whole area. That can be done by holding it in place with the mounting bolts for the TV bracket. You will want to through-bolt the bracket.
If the back side of the wall is in a closet, as it is in our '65 Caravel, painting or staining may not be necessary.
In any event, you will want to use some method to "sister" the wall in the area of the TV, otherwise I don't think the wall will last very long.
11-22-2010, 10:37 PM
1972 23' Safari
Houston
I'll add to the photo archives. 22' Vizio on swing arm bought at Costco. This one has a wing nut on the back that is easy to unscrew. Would store under bed in bin. (This was in the stolen Tradewind )
11-23-2010, 05:52 AM
Oswego
If you're interested in just a simple, flat mount which tilts and does not swivel, and lifts off easily for travel, Rockfish makes an inexpensive one. Got mine at BestBuy for about $35, if memory serves. I installed a 22" on the bedroom wall and just lift it off for travel.
11-23-2010, 05:53 AM
Oswego
Sorry, the brand is Rocketfish.
11-23-2010, 05:57 AM
Oswego
Rocketfish TV Low profile TV mount for most 13" to 26" flat panels Model#
RF-TVMLPT01
I backed it up with an aluminum plate as this wall contains a pocket door and the material is only 1/4".
11-23-2010, 06:03 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
We have the same TV mount as ASFLYCASTER. It is a great mount. It is aluminum and comes in silver and black with a powdercoat finish. The mount is made by VideoSecu and was $24.99 from Amazon.
It holds our 22" Visio. We don't remove it when we travel. We just secure it with 2 small bunge cords. We can watch it from the br area or swing it around and watch it from the Lr area. It operates off 12v, so we just power it from the batteries (33 watts). If we are boondocking it takes power from the batteries. When we are plugged into 120v it is still powered from the batteries that are recharged by the convertor. I will take some pictures and load them when I figure out how to do it.
Dan
Dan
11-23-2010, 06:56 AM
Oswego
I would also add, as a note for those of you who have this pocket door setup, that there is very little clearance between the back of the wall and the pocket door for a backing plate etc. Interference can cause scratches to the door. I used the self-adhesive floor protectors (the kind you use under furniture, etc.). They are available in many shapes and sizs. I chose the strips about 4" long and 1/2" wide. I ran several of them horizontally across the leading edge of the reinforcement plate to create a "padded ramp" for the door to slide on.
Also, you must remove the door and loosen the BR wall screws in order to allow room for your arms and hands to get in between the walls. If you have "Popeye" arms, you may have to get a small assistant to help.
11-23-2010, 10:50 PM
2006 34' Classic S/O
Lakewood
, New Jersey
I decided not to mount the flat screen, instead I found that my 26" sony would sit on the cabinet top attached to the credenza. My wife and I could both see the tv fine sitting in our recliners. While travelling i just put it on the bed, works fine for us
Happy Thanksgiving,
Reganzo
01-29-2011, 07:13 PM
1965 26' Overlander
Scottsdale
, Southwest
Thanks for all the suggestions, we followed what many did in terms of location and devised a plan for the back side of the mount to dual purpose as a magazine rack. Turned out decent and for the 15" TV seems to hold up and support quite well. Wifey came up with the idea and is comprised of some 2x2's. Rack only holds 4 or 5 mags but turned out decent!
Total cost $30 including the mount which we found on overstock.com.
01-29-2011, 08:40 PM
2002 25' Safari
Dewey
That looks great!
Are you guys going to be at DH5?
Richard
01-29-2011, 09:21 PM
1965 26' Overlander
Scottsdale
, Southwest
Thanks for the help on this one
As for DH5 we will be there half polished and all. We can't wait. I dropped the registration in the mail today.
01-30-2011, 05:34 AM
2002 25' Safari
Dewey
I could bring my Cyclo...
Richard
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
TV mount for 96 25 ft
jasper2222 |
Audio, Video & TV |
1 |
11-18-2009 01:08 PM |
TV Mount ?
TLH67 |
Audio, Video & TV |
5 |
11-13-2009 07:13 AM |
tv mount
millvalleyca |
General Repair Forum |
17 |
08-03-2008 12:00 PM |
Flush Mount or Surface Mount
Zac&Kristin |
Water Heaters, Filters & Pumps |
10 |
01-13-2008 06:59 PM |
Where to Mount CB ?
bubbleup |
Land Yacht/Legacy Motorhomes |
2 |
08-18-2006 10:29 PM |
