08-20-2017, 08:19 AM
1999 28' Excella
New Orleans
, Louisiana
Cable TV and a 1999 Excella
We have never hooked to cable tv since we bought our Excella 5 years ago. Is there a place externally to hook it to a coax cable?
08-20-2017, 08:22 AM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Mine is in the electric cord storage area.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
08-20-2017, 08:33 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Based on how many I see with cables running through windows or out storage doors .... it didn't come with a nice easy cable hookup.
08-20-2017, 09:02 AM
1999 28' Excella
New Orleans
, Louisiana
There is a strange looking long bolt in the electric cord storage area but it does not looks like a hookup for a coaxial cable. Not sure what it is.
08-20-2017, 09:09 AM
1995 25' Excella
xxxxx
, xxxxxx
My 1995 has a cable hookup in the electric cord storage area as well.
08-20-2017, 09:14 AM
1999 28' Excella
New Orleans
, Louisiana
Left side of electric storage area? If so why is my connection strange..maybe I need some kind of extra attachment?
08-20-2017, 09:22 AM
1999 28' Excella
New Orleans
, Louisiana
Looking at the schematic and it appears to be city cable hookup ext. Maybe the connection was changed for satellite. The bolt that holds it on looks newer than the hookup.
08-20-2017, 09:29 AM
1995 25' Excella
xxxxx
, xxxxxx
08-20-2017, 09:31 AM
1999 28' Excella
New Orleans
, Louisiana
Thank you..we found it..yippee!
08-20-2017, 10:43 AM
1999 28' Excella
New Orleans
, Louisiana
Still more to learn..we have 3 coaxial cables in the trailer not including the antennae one. I tried the 2 that reach the tv with tv on cable setting..no deal so I guess next is a short cable and connector so I can try the last one. I am learning..guess that is good.
08-20-2017, 10:59 AM
1999 25' Excella
Western Springs
Hook your tv to the antenna booster and turn the booster off ( red light off ) re scan your channels on your tv you should be good to go
08-20-2017, 11:36 AM
1995 25' Excella
xxxxx
, xxxxxx
Actually, mine never worked. The TV works fine on antenna in either end of the trailer. I never could get mine to work on with cable hooked to the jack at the electrical cord. (Yes, booster was off) I messed with it a lot and figured I had a break in the coax somewhere not far from the hookup. I said the heck with it and drilled a hole in the floor in the living room cabinet right above the city water compartment. I put a short piece of cable in and hook up directly.
08-20-2017, 11:49 AM
1999 28' Excella
New Orleans
, Louisiana
If I hook the tv to antennae then when do I hook the cable back up? Guess I need step by step. We unhooked the antennae with the light off then hooked up the cable then scanned the tv channels with tv on cable setting.
08-20-2017, 07:06 PM
1999 28' Excella
New Orleans
, Louisiana
No help..thanks guys.
08-20-2017, 08:49 PM
1988 32' Excella
Robbinsville
, New Jersey
That Should be it. It's not that hard unless there is a problem. On my parents 93 the cable was cut between the body and frame.
Also if the signal is weak the cable may not work with the older non-digital wiring installed in Airstreams built before a certain year.
08-21-2017, 01:41 PM
1999 28' Excella
New Orleans
, Louisiana
Wavelength..thank you..my brain was slow to process. I was disconnecting the antennae and using these other cables inside which are probably for a satellite. So today I changed the setting on tv back and did what you said. Yes, it works..thank you again.
