Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 09-30-2015, 11:51 AM   #21
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
What Al and Missy said. On an unmodified AS the answer is no. Your cable connection outside runs to the front of the trailer thru the skin and connects to both TVs. The Antenna works off the same set of wires and is activated by tuning the antenna on by the front TV, pushing in a little button. When that button is pushed in the cable part of the system is essentially turned off and you cannot have both on at the same time. Easy to switch back and forth, however.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 09-30-2015, 11:26 PM   #22
2015 25' FB Flying Cloud
Mosier , Oregon
Thanks for the help guys. On the new Samsungs it appeared that the TV was capable of finding both cable and over the air broadcasts simultaneously from the scan menu but that is Probably from multiple inputs as was stated.
GorgeGuy is offline   Reply With Quote
Old 10-01-2015, 08:29 AM   #23
AStreamNerds's Avatar
Manassas , Virginia
The reason for this is because you can use your antenna on the roof to scan for local channels and a cable connection to the outside to scan for CATV channels. There is a button on the jack behind one of my screens that you use to turn off the amp. The amp is used for roof antenna and won't work with CATV connection on outside.
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 05-03-2017, 02:12 PM   #24
2013 25' FB Flying Cloud
Denver , Colorado
Thanks Al & Missy! I kept going outside to try to get a better connection of my cable connection! And then I pushed the Antennae booster button and just like that - no more static!
Originally Posted by Al and Missy View Post
IF your trailer (newer) is like mine, there is a button on the plate where the TV connects or on another plate somewhere in the trailer that must be pressed so that the green LED is OFF. That switches the TV from the antenna (LED ON) to cable (LED OFF). Then you must use the menu system in your TV to scan for channels. There is an option in the scan menus to choose between antenna and cable. Most cable systems require that to be set for cable but some small private systems do not.
Al
Jennisey is offline   Reply With Quote
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Question about the Porter Cable random orbital Eagle & Bear Cleaning, Stripping & Polishing 3 12-01-2012 07:08 AM
1970 31ft sovereign international battery cable question travalota Batteries, Univolts, Converters & Inverters 1 09-27-2011 06:53 PM
Another Newb Question-Power Cable? jambie 2005 and newer - Bambi all models 1 03-08-2011 09:24 AM
Cable tv question TexasStars Electrical - Systems, Generators, Batteries & Solar 4 10-23-2003 04:35 PM
